Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Official E92 Bulb Code List
      01-13-2014, 08:23 PM   #111
N8N
N8N's Avatar
Drives: 2009 E92 335i 6MT
It's not a bulb but an LED; if those are out you need new light assemblies, or if you feel froggy take them apart and do some component level troubleshooting.
      01-22-2014, 12:15 PM   #112
E92-Lighting
E92-Lighting's Avatar
Drives: Next Generation LED Lighting
we would recommend LED's over halogen bulbs for angel eye upgrading.
      03-14-2014, 04:09 PM   #113
RumanAmin
RumanAmin's Avatar
Drives: BMW 325d M Sport (E92)
How do I figure out which lights/bulbs I've got? The only thing my car spec says is S522A Xenon Lights. I like the way mine look, just wish I could get something lot brighter/whiter.
      07-24-2014, 05:06 PM   #114
fatnhappy
YMB_F82
Drives: Yas Marina Blue M4
i have a 2011 e92 coupe with m sport does that mean i need m tech h11 bulb for fogs or h8?
      09-27-2014, 11:40 AM   #115
datbimmer
Wastegate Rattle
113
Drives: 335i m6t nav sport
For those who changed their interior LEDs, are we better off with normal 194 or flank ?
      10-17-2014, 10:32 PM   #116
E92-Lighting
H11
it depends on which LED bulb you want to change, normally 194 aka T10 is suffice
      01-19-2015, 11:30 AM   #117
datbimmer
Wastegate Rattle
113
Are the bulbs listed in OP for Pre-Lci ?
I need to replace brake lights in pre-lci tails and reverse and rear fogs, can someone confirm the right ones for PRE-LCI ? If anyone used LED, what did you use ?
      04-06-2015, 02:47 PM   #118
ReeferCheefer
ReeferCheefer's Avatar
Drives: 135i,335i,335xi,328dx, 535i
2008 E90 Montego  [0.00]
2022 s1000rr  [0.00]
2016 S1000RR  [0.00]
2011 535i xdrive  [0.00]
What is the code of the trunk mounted tail lights?
      04-23-2015, 03:06 PM   #119
datbimmer
Wastegate Rattle
113
Is W16W the right one for reverse pre-lci e92 ?
      06-28-2016, 11:37 PM   #120
Stage5Lurker
Drives: White Buffalo
LCI e92 Bulb list?
I have an LCI e92 and my AE's/DRLs are LED. From what I have been told and read here and there is that the bulbs for these lights are built in with the control module. I have checked realoem and other sights but they all tell me that the bulb is an h8. I believe this to be wrong. Anyone know of the part number for this? I have a set of AE's flickering and thought the bulb was failing but it now could be the cm and aes? I need help.
      11-09-2016, 02:15 PM   #121
Jamjedi79
Jamjedi79's Avatar
Drives: 2010 Alpine White 335i XDrive
Originally Posted by exmowner View Post
Hi I was wondering If it's possible to remove the amber/yellow bulb threw coding or If not does a replacement bulb exist?
After installing the lux v4's it's been bothering me.
Thanks to EAS for the picture!
Has anyone answered this question yet? I also have just changed my halo lights to the Lux and that damn amber LED is bugging me. Throwing my all white look way off lol. Can it be replaced or am I just stuck with it?
      01-28-2017, 04:07 PM   #122
RYANPUREWAL
RYANPUREWAL's Avatar
Drives: bmw 335i
thanks for the list
      05-11-2017, 01:55 PM   #123
Kas5gd
Drives: 2011 BMW 328i Coupe
E92 angle eyes bulb location
Hello all!
First time posting so pardon me if a commit some errors. I recently purchased my first BMW a couple months ago. It's a 2011 328i coupe and I'm trying to change the angle eyes bulbs. I did some research and I ordered the H8 led bulbs. When I search online on where the bulb is, every site tells me it's under the hood located under these two panels I have to pop open with a flathead. When I do that, all I see are the cornering light bulbs, no angel eyes. Can anyone please help me with this or point me in the right direction? Thank you
      08-04-2017, 02:04 PM   #124
azzurribaggio
19
Drives: 2004 330ci E46/2006 325i E90
Me: how much for a pair of D1s bulbs for my 2006 325i?
Dealer: $315......
Me: ( picking up my lower jaw from the ground )
      08-20-2017, 11:49 PM   #125
winner
Drives: e91 325xi
I have BMW E91 325xi (2006, Motor type is N52). Sometimes, when I started my car, motor fault lamp didnt light up (and go out)... My last car everytime, when I started my car, lamp light on about 1-2sec... Can somebody tell me, its normal? or fault? I hope, that somebody understand this.
      09-07-2017, 08:45 AM   #126
TheONE24
TheONE24's Avatar
Drives: 2016 M4/F82 MGM/SO
2016 BMW M4  [0.00]
09 BMW E92  [0.00]
Now that I've bought the wrong outer brake light bulbs twice for my Pre LCI E92 by reading this post can we get someone who has a good idea of what bulbs for what generation we can use? Any volunteers? OP maybe an update/edit on current info? This was mentioned 5 pages in but the 2 outer brake lights are not the same as the inner brake light bulbs.
      10-23-2017, 10:51 PM   #127
1DogRescuer
Drives: '07 E92 328i Cpe AT, Sport Pkg
I share the general frustration here. I’d prefer to PRE-Purchase the bulbs intended for changing (front end); but, because there are so many varied (opinions) on what bulb is in what location.
01/2007 E92 bi-Xenons, fogs, CRAPPY AEs
Bentley shows certain bulb (pg. 630-17) as High Beam (H7 55w), when I believe that the space indicated is actually the Cornering Light .... but is it still H7 for MY application ? RealOEM COMPLETELY contradicts Bentley, too. The Table from OP is Awesome, but that makes THREE different bulb specs ( for certain spots). I don’t even bother with looking for FACTS at the stealership. Sylviania site, and SuperBrightLEDs also with erroneous vehicle-SPECIFIC application.
Another example, I’m almost Certain that my Bumper is non-M tec, but my Fogs don’t look like many pics that I’ve seen for “plain” Bumper.
I’m trying to get very similar color temp (kelvin) for AEs, Cornering, bi-Xenons, and Fogs. Aiming for 4500-5000k. Yet, I’m still left scratching my head on which bulbs I ACTUALLY have (so that I can pre-purchase) ... :~[
I absolutely will NOT use HID bulbs in non-HID housings, which will likely compound my goal of (matched) kelvins. I’ll have halogens (which get HOT), HID, and possibly LEDs (if I can find a decent sub $100 AE option).
Anyway, that’s my rant ..... Sorry
      05-13-2018, 06:44 PM   #128
NZ-M340ixDrive
New Zealand
27
Drives: 2020 M340i xDrive
Resurrected thread.
So many contradictions
Buying fog lights want to know am I H8 or H11
Been told
By a very reliable source I’m H8
I have a 2009 335i M sport.
Now this list states that I would be H11.
Sylvania states I’m H8.
Please could someone clarify
Thanks again
      08-19-2018, 03:01 PM   #129
Theanomally
Drives: Bmw
E93 rear brake lights
Hi guys.Got a problem with my 2008 E93.
On the drivers side,one of the brake light bulbs blown.When I took light apart it looks like they are soldered bulbs to board.Anyone else come across this?
The bulb in question just crumbled when I tried to remove and as far as I can tell it seemed soldered.Tried not moving the other bulb as not wanting to break the contact.I can't seem to locate the bulbs anywhere.They are PH16w 8B25GG.
It's like the bulb is in a black enclosure and you can remove but I'm sure the pins go through and are soldered..
I'm a bit stuck as to what to do next..
Any help?
      09-02-2018, 12:02 AM   #130
luisfmart
Drives: 09 E92 328i
Originally Posted by Benji335i View Post
Resurrected thread.
Been told
Thanks again
H11 is for the M-tech option that became available in 2011. M sport is a package before then. Your fogs are H8.
      09-06-2018, 01:04 PM   #131
Daniel08E93
Daniel08E93's Avatar
Drives: 2008 335i E93
Any help?
Just saw this and was in the same pickle you were in. If one bulb goes out you have to replace the whole piece. look here https://www.e90post.com/forums/showthread.php?t=1524112
      03-03-2019, 02:48 PM   #132
Mister_R
R
Mister_R's Avatar
Drives: 335i M-Sport Cabrio (E93)
Most the same for pre-LCI e93?
