      03-28-2024, 07:09 PM   #1
nevetstoj
nevetstoj's Avatar
144
Drives: 2008 128i
PSA: Vibration Both Under Braking Accelerating in Steering Wheel
Hello all,
Just thought I would share a finding in relation to Reluctor rings on the axels and the ABS unit.
Symptoms: Vibration under braking and driving at speed, Random DSC kicking in
So I had previously used a washer and spaced out the wheel speed sensors in the rear when I got the car. Seemed to fix the random traction control intervention.
I had noticed recently that my steering wheel would shake at around 80kph with both brakes applied and just driving in a straight line. No codes at all with my scan tool. Also, the car would have what felt like trouble tracking in a straight line. I had checked the front arms, but everything is fine and there was no play.
I just summed it up to the winter wheels im on having lost a weight. HOWEVER, recently I was reading about the dsc module and the dtc mode (one click) and tested a theory. That being, if I drive around with dtc mode on, would the car overlook spastic variations in speed readings. Thus eliminating the vibration I was feeling both on the brakes and coasting?
YES, yes it did.
So, if anyone else out there has mysterious vibration they can not find after eliminating worn control arms, wheel and tire balance, look at your wheel speed sensors. I guess the car was getting inconsistent readings from the wheel speed sensors and varying the application of brake pressure in attempt to keep the car in a straight line, both on and off the brakes.
Cleaned all the wheel speed sensors and replaced one that had been making contact with the axel.
No more vibrations.
Hope this helps someone!
Appreciate 4
      04-06-2024, 11:44 PM   #2
MAMSport
MAMSport's Avatar
94
Drives: '13 128i M-Sport coupe
Interesting. I'll check out the wheel speed sensors. I get vibration under braking from 40+ mph, felt in the steering wheel.
E9x M3 front & rear suspension arms; BMW Performance brakes upgraded to drilled rotors in rear; BMW performance shifter; BMW Performance Exhaust; Wave Trac LSD with modified 'nannies'; BMW Euro Intake box; BMW Aluminum Strut Tower bar; ECS front and rear sway bars; 3 stage intake with BPC software; BMW style 78, 17 x 8" wheels with Bridgestone RE 980AS 225/45-17 tires; Koni Special Active struts/shocks, E9x M3 RTABs.
      04-08-2024, 04:15 PM   #3
nevetstoj
nevetstoj's Avatar
144
Drives: 2008 128i
Hopefully it works!
      04-23-2024, 09:34 PM   #4
MAMSport
MAMSport's Avatar
94
going to have my indy check the suspension pieces out tomorrow. BMW CCA undercarriage tech session local to me. The upgraded parts now have over 80k miles and may be showing some wear?
      04-28-2024, 01:32 AM   #5
MAMSport
MAMSport's Avatar
94
Suspension arms and bushings given clear bill of health. No cracks in the ///M bushings on the ///M arms. Next step to try braking again. I haven't noticed anything unusual, and either I am used to the vibration or it has gone away (after multiple attempts to rebed pads).
      04-29-2024, 02:54 PM   #6
nevetstoj
nevetstoj's Avatar
144
Drives: 2008 128i
Same with me, nothing was worn and everything is balanced, rotors and pads I replaced.
When I tried bedding in the brakes the vibration would only get worse for the remainder of the drive and then be frine for a day or so then it would come back.
If the speed sensors are okay, the only other thing I saw on the e90forum was that is you have the car off and wiggle the steering wheel left and right and hear a faint click/knock then it could be the balljoints off the steering rack into the knuckle.
