01-08-2016, 01:09 PM | #1 |
641
Rep 1,029
$249 SPECIAL -- Walnut blast is a MUST on your N54!! (w/ pics!)
Call us now to schedule your appointment! (800) 438-2808 So last week we started our Intake Valve Walnut Blast Special and got lots of interest. For this reason we have made our walnut blast service an everyday special of Only $250 over at SSR Performance in Orange County, CA. We've gotten an insane amount of interest! Customers are coming in from North LA, Corona, Riverside, and even San Diego. It's very obvious why people are so anxious (if you're not, you probably should be) to get this done on their N54 motors when you take a little peek inside... Here is a photo of the intake valves we did. Before the cleaning the customer was noticing slow throttle response on WOT and a bumpy idle (if you're tuned, it is even MORE vital you get this done). It doesn't take a genius to see why after taking a look inside... Since the N54 is a direct injection motor, the intake valves are only in contact with air and blowby gases from the crankcase breathing circuit, in which substantial quantities of fuel and oil can be found. This is opposed to non-direct injection motors in which fuel passes over the valves and acts as a cleaning agent so that the build of of carbon deposits does not occur. After several thousand miles of driving (approx. every 30k is when this service is recommended) deposits of carbonised fuel and oil in the intake tract can become fused on, as well as on the intake valves themselves. This process is often referred to as "carbonising", as you see in the photo above. After some TLC (plus some sweat and elbow grease) from our team, these intake valves were looking like new... Every customer is left with a HUGE smile on their face when they see the before and after of their intake valves. :happy It takes about 2.5 hours per vehicle. This specific customer was very happy with the whole process. He messaged us the next day and couldn't stop raving about how much better his car feels at idle, as well as the very noticeable increase in throttle response. So if you have an N54 BMW with over 30k miles and have never had this done before today, hopefully this thread will show you the importance of why it is so vital that your direct injection motor get this service done as soon as possible. Sadly, there is no other way around it. If you have any questions about the process feel free to PM, email, or call us today! Get your Walnut Blast done for only $240 SPECIAL Setup an appointment today, contact us anytime and we will make sure we work with you to setup an appropriate time and get your intake valves looking like new again! Last edited by SSR Performance; 10-03-2019 at 04:02 PM.. |
02-08-2016, 10:32 PM | #2 |
641
Rep 1,029
Hey guys! It's your last week to be able to get this $250 Special on our Walnut Blast for your N54 or N55 motor! Come one come all! Feel free to contact us at (800) 438-2808 or info@SSR-Performance.com to schedule an appointment today!
02-08-2016, 11:38 PM | #4 |
641
Rep 1,029
The N51 is not a direct injection engine and so it will not have carbon buildup anywhere close to those of the n54's pictured above. Fuel actually passes over the valves in the n51 engine which helps keep them clean. That being said to keep your valves and ports as clean as possible, it is best to use top tier gasoline (something with detergents like techron) and use some fuel additives/ cleaner every now and again.
02-11-2016, 12:34 AM | #5 |
31
Rep 117
SSR Performance! Thank you for the information. I appreciate your professionalism. I'm a rookie in the world of BMW so thanks for not being harsh on me for not knowing much about the N51.
02-12-2016, 02:39 PM | #6 |
641
Rep 1,029
02-23-2016, 04:06 PM | #7 |
641
Rep 1,029
Although our $250 walnut blast service is over, we are proud to be one of most competitive performance service providers in Socal, take advantage of our year round everyday special of $295!
02-23-2016, 06:27 PM | #9 |
641
Rep 1,029
The N55 uses valves as idle control and throttle stays open mostly. This means carbon does not tend to build up as much. So from the n55's we have seen, yes there is some build up, not in the same league as the n54's. Possibly for a high mileage n55 but other than that the new n55 and s55 engines are pretty efficient.
02-26-2016, 03:23 PM | #10 |
641
Rep 1,029
Couple appointments left for this weekend, take advantage and get your intake valves cleaned or performance parts installed at our special rates!
03-01-2016, 06:38 PM | #11 |
641
Rep 1,029
Here are some of our awesome customers from the past weekend!! Taking advantage of our $295 Walnut Blast Special!!
Call to schedule your appointment for an N54 / N55 Walnut Blast or to get your performance parts installed at our special rates TODAY! Phone: (800) 438-2802 Email: info@SSR-Performance.com Last edited by SSR Performance; 03-18-2020 at 01:44 PM.. |
03-08-2016, 12:30 PM | #15 | |
641
Rep 1,029
While we do not carry the BMS catch can, we do install them |
03-27-2016, 07:31 PM | #18 |
Rep 1,850
If you track your car or drive it on the autobahn at high speed for long periods of time you probably don't need this service. This was my DI track car at 72K, BPY FSI 2L. Everyone had horror stories and pics of intake valves gummed up way worse than in the OP but if you run your engine at consistently high RPM you won't have an issue with buildup getting to the point where it causes issues.
03-30-2016, 04:28 PM | #19 | |
641
Rep 1,029
03-31-2016, 10:39 AM | #20 | |
エアーマンが倒せない
279
Rep 2,041
03-31-2016, 04:07 PM | #21 |
Rep 1,850
04-05-2016, 07:30 PM | #22 |
エアーマンが倒せない
279
Rep 2,041
I track occasionally, but my 135i is my daily driver. Do you think this will benefit me?
intake valve cleaning, maintenance, n54, n55, oil leak, repair, shop, socal, specials, ssr performance, walnut blast |
