03-16-2018, 09:51 AM | #177 |
Rep 2,598
03-18-2018, 05:46 PM | #178 |
Rep 30
It rubs at full lock but it's not doing much damage. I would still go down a profile to 235/35 on the fronts. But the rims and tyre combo have transformed the handling of the car. It turns in a lot sharper than on the standard 18 inch run flats. 437Ms are also a lot lighter, you can really notice the difference.
03-18-2018, 06:15 PM | #179 |
58
Rep 154
03-18-2018, 06:56 PM | #180 |
Rep 2,598
03-19-2018, 07:18 PM | #181 |
58
Rep 154
Here they are but pics don't do this setup justice. Its like these wheels where made for this car. The 235/40/19s with 265/35/19s in rear are a absolute perfect fit and no rubbing at all.
Will try to post some better pics. this is right after install with dirty tires. |
03-19-2018, 07:28 PM | #182 |
Rep 2,598
Thanks, I am running these with 245/35 & 265/35. I did consider 235/40 but I’d read reports of rubbing on the arch liner!
The black looks great - more pics please!! |
03-19-2018, 07:35 PM | #183 |
58
Rep 154
03-20-2018, 01:16 AM | #184 | |
Rep 2
03-21-2018, 11:02 PM | #185 | ||
Rep 4
Could I ask what tire you ended up choosing for your set up. I also have the Dinan Springs and want to go this route. Thanks in advance. |
d_a_m92.50 |
03-22-2018, 03:40 AM | #186 |
Rep 2,598
H&R's now fitted - no rubbing with the OEM 437m and 245/35 and 265/35 MPSS which if i'm honest I was secretly worried about! The lowering has also helped to tuck the front wheels into the arches nicely.
03-27-2018, 03:57 PM | #187 |
26
Rep 64
That is a sweeeet ride. Well done!
himynameskevin28.50 |
03-27-2018, 04:27 PM | #188 |
Rep 2,598
04-13-2018, 02:18 PM | #190 |
Rep 27
05-12-2018, 03:22 PM | #191 |
Rep 2
Hey guys, I just found a mint set of the 437m wheels from a 2017 m4. Comes with brand new rubber and I'm wondering if the stock tire 255 fronts and 275 rears would rub on a x drive 440i gran coupe. Any info would help.
05-13-2018, 09:19 AM | #192 | |
Rep 1,288
Drives: 2014 435iX, FBO
I got the M4 knock off rims from GTS and the offsets fit perfectly for a cost of roughly 1000 for the set. Why do the OEM route? My tire sizes are 245 and 275
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
05-13-2018, 09:50 AM | #193 |
Rep 2,598
No, 255/35 & 275/35 will not work with xDrive - rolling diameter needs to be within 1% front to rear. This combo exceeds that. 235/40 & 265/35 would work.
05-13-2018, 09:52 AM | #194 | |
Rep 2,598
OEM is also superior due to the fact that the OEM 437m are forged and the concave is deeper than the replica's. I am running a 245/35 and 265/35 combo without any issues whatsoever and my car is lowered. |
05-26-2018, 02:07 PM | #195 |
Rep 749
Drives: 2016 528i Executive Edition
Anyone have feedback on whether fitment on an f31 touring is the same as f30/f32?
Thinking 235/40/19 and 265/35/19 on the oem 437m. Thanks! |
05-27-2018, 11:49 PM | #197 | |
Rep 749
Thanks so much! It looks badass! It looks like I would have to stick with 335/40 and 265/35 as the car is xdrive. But good to know it looks sensational on the touring! |
05-31-2018, 05:07 AM | #198 |
Rep 1
Hi, first post! Can someone please explain the constraints between a xDrive vs non with regards to tire fitment?
I'm in the process of deciding between a 2015 428i M Sport or 2014 435i xDrive M Sport with the single goal of switching to the 437m oem wheels. And unlike many here I actually do like a wider aggressive width and higher profile (don't like the look of low profile tires on these, personally), esp on the rears and so don't care if there's a little bit of rubber extending beyond the fenders but I don't want rub on the inside (full lock's ok though). Would love to run 275/35/19 on the rears. Also, I'm seeing several 437M sets that do not include the tpms sensors. I'm assuming I'll be able to just use whatever is on the existing wheels of whichever car I purchase? Thanks in advance! Last edited by blowndiffuser; 05-31-2018 at 05:33 AM.. |
