02-15-2010, 11:11 AM | #67 |
Rep 4,470
I think it would be most helpful for anyone advising on 245/265 tires to be very specific about brands. To just state that a 265 can be made to fit the rear (stock set up) with no rubbing is simply wrong as different brands have different shapes and you're basically pushing the size limit.
135i, SGM, Coral, Sport Package, Auto, Premium Hifi, USB/ipod, Apex EC-7s, PPK Stage II
02-15-2010, 11:51 AM | #68 | |
Rep 581
02-15-2010, 02:05 PM | #69 | |
Rep 10,176
02-15-2010, 03:20 PM | #70 | |
445
Rep 1,658
02-16-2010, 08:45 AM | #71 |
104
Rep 2,474
ordered my tires yesterday!! 255-275! should arrive thursday.
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks! |
02-16-2010, 09:57 AM | #73 |
104
Rep 2,474
actually just arrived! awesome!! No one I have called is jumping at the opportunity to mount and balance these suckers though. Sad.
02-16-2010, 10:18 AM | #74 |
Rep 10,176
I had to pay $200 to get mine mounted. I asked that they do not put a tire monkey on them. I paid a bit extra to have areal tech mount them. (I've had a handful of bad mounting experiences though).
02-16-2010, 11:38 AM | #75 |
104
Rep 2,474
Dang. I gotta shop around a little more.
02-16-2010, 01:17 PM | #76 |
104
Rep 2,474
Well, BMW dealership is the only place that has been confident that they can do this no problem. and its 175$ might just have to suck it up.
02-16-2010, 02:44 PM | #77 | |
Rep 446
If so, that's not too bad, as long as the dealer does quality work. |
02-16-2010, 02:52 PM | #78 |
104
Rep 2,474
Alignment not included. Ill get an alignment after I install the camber plates at my usual place.
02-19-2010, 08:55 AM | #79 |
104
Rep 2,474
being mounted today!!!
02-19-2010, 10:06 AM | #81 |
104
Rep 2,474
I will start a new thread when I get home and show a teaser pic of the wheels.
02-19-2010, 12:22 PM | #83 |
104
Rep 2,474
in the trunk!
02-19-2010, 12:44 PM | #84 |
Rep 3
im very interested in this setup but would like to remain with the stock M sport pack 135i suspension on the car
will theses wheels fit with direzza sport z1 235/40/18 front and 265/35/18 with stock suspension without any moification to camber? |
02-19-2010, 12:57 PM | #85 |
Rep 446
Height of the front sidewalls is the biggest potential problem with a that setup. 235*.4=94 mm. Compare that to the stock 215*.4=86 mm. That's around 2/3" taller tire all around, all else being equal.
Also, by comparison, even the OP's 255/35 setup is still only 89.25mm from rim to tread. |
02-19-2010, 01:12 PM | #86 |
104
Rep 2,474
I know you can run 235/40 direzza on a stock 7.5" wheel. I dont think height is an issue.
02-19-2010, 02:53 PM | #87 | |
Rep 3
so what would be ideal size in front to run these wheels on stock camber and suspension , i know the rear is not an issue with the 265/35/18.. ideal front would be 225/40/18? |
02-19-2010, 03:37 PM | #88 |
Rep 446
Check a page back in this thread about tires sizes. Looks like someone was able to get a 235/40 on, but there were potential issues with fender rub without camber plates. 225/40 might be the best you can do in the front with a bone stock suspension, at least if you don't want rubbing. But like they said, these should really only be put on if you're willing to modify the suspension slightly to get the proper camber in place.
