BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
European Auto Source (EAS)
      09-13-2022, 12:59 AM   #23
StripclubDJ
StripclubDJ's Avatar
4100
Drives: e92 m3
Originally Posted by MajorBob View Post
HI guys, I don't mean to hijack the thread but you seem skilled at diagnosing and working on the DCTs and I may be dropping mine for the 3rd time . This time to replace the combination temp/ clutch speed sensors. Getting codes 5A58, 5A76 and 5A73 and this seems like the most likely cause. Curious if you agree or if there is something else I should check first? Also… Does anyone have the Clutch removal tool they would rent out? Happy to pay a reasonable amount and return when the job is done.
Thanks!
Pm me
      09-26-2022, 10:37 PM   #24
hfm
Drives: Evolved
Any bay area shops w/ good DCT experience?
      09-27-2022, 02:49 AM   #25
StripclubDJ
4100
Drives: e92 m3
Not that I know of
      09-28-2022, 10:58 AM   #26
Helmsman
Helmsman's Avatar
Sweden
4485
Drives: 2011 AW E90 M3 ZCP
After several month without the friggin code...it turned up again. No code on the replaced aux water pump, cooling system seem to be running fine. This is a tricky one...
      09-28-2022, 08:13 PM   #27
spammysammich
spammysammich's Avatar
1605
Drives: 2009 E92 M3 Dakar Yellow II
2009 BMW M3  [10.00]
Do you recall the conditions and any notable behaviors when the warning popped up? I went on a pretty hard 8 hour total drive in 90f weather a while back and didn't have any issues besides the persistent o-ring weep that I've been tracking since February. I do have that recurring aux water pump code but it doesn't trigger any lights.
      09-29-2022, 04:27 AM   #28
Helmsman
Helmsman's Avatar
Sweden
4485
Hey man,
similar to others really i.e. typically at low speed (where I assumed water pump/coolant should help compensate for lack of air cooling). Did a 200 mile round trip/high way during the weekend without issues.
Missed your mentioned o-ring leakage, what sealing is this?
      09-29-2022, 08:06 AM   #29
spammysammich
1605
2009 BMW M3  [10.00]
The o-ring sandwiched between the thermostat and the transmission body. Probably gone flat over time. I doubt it was swapped out at the last full transmission service at 88k miles.
      09-29-2022, 09:37 AM   #30
Helmsman
Helmsman's Avatar
Sweden
4485
Ah, got it. Had my Tstat replaced together with fluid and filters some year ago, and yes believe I had some weep there as well. Wouldn't worry if tiny.
      04-19-2024, 05:14 AM   #31
Helmsman
Helmsman's Avatar
Sweden
4485
Pls see April 19th update on first page.
      04-19-2024, 11:33 AM   #32
omgzirra_exe
omgzirra_exe's Avatar
Drives: 4.4L M3, IS300
have you considered it might be the oil pump in the dct?
there's a plastic unit in there that could be causing issues. i think deansbimmer refereed to it as a anti-return check valve and a venturi pump or sucking jet pump?
what a name.. lol anyways it could be a factor. maybe you might just need a full service on the DCT with all the soft seals and inspection..
p/n: 28107842849
Build: ZillaSpec M3 N1 Build
M3Post Track General Discussion: Discord
#fakeGTS
      04-19-2024, 12:59 PM   #33
Helmsman
Helmsman's Avatar
Sweden
4485
p/n: 28107842849
Saw that interesting thread. However the box is only 40k calm miles old so have difficulties to believe anything is worn out really. Also, the code comes up very seldom since I replaced the aux coolant pump so tend to believe its some other krux.
      04-22-2024, 09:26 PM   #34
GORDON.M3
GORDON.M3's Avatar
1429
Drives: E92 M3 • F25 X3 M-Sport
Have you replaced the PN: 28107842838?
I was having some downshifting issues and the transmission was not smooth at all even after a full DCT service + upgraded pan. Then I replaced this part @ 60k miles and the transmission was shifting normally again just like it was when I got it at 30k miles.
I took a look at the ball inside of the jet suck pump and it was very much pitted and looked like it was getting old as the plastic had completely discolored.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor
DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI
      04-23-2024, 02:46 AM   #35
Helmsman
Helmsman's Avatar
Sweden
4485
Thanks mate, no haven't replaced that one. Thing is that the DCT code started to show already at 25-30k miles useage of the box (replaced when car done 20k miles). And code comes up really intermittent, can be months inbetween. Had fluid, both filters and pan replaced 10k miles ago.
Checking clutch pressure, control valves etc (Protool) it seems to align nicely with the spec's (also provided by the box/read by Protool).
m3post
