06-18-2017, 02:37 PM | #24 | |
Rep 1,481
BTW your 2006 Imola 6MT.. might be the perfect example of what I'd want today. Love it.. |
06-19-2017, 07:48 AM | #25 |
Emperor
1614
Rep 2,753
The vert doesn't drive nearly as nicely, and isn't as practical as the coupe.
That said, if you're just looking for a weekend top down experience, it can be a good time. The convertible is no less likely to suffer subframe mount failure than the coupe in terms of construction (was a myth early on, now 100% disproved), but they do experience it less often than coupes, on average, because they're not driven as hard. The e46 has two main weak spots. Happily both are cheap and easy to address so long as you do it BEFORE failure: 1) subframe mount points tear out. You can address this BEFORE IT HAPPENS by injecting BMW's structural foam into the cavity. The foam costs $86, install should taken ~30 min. If you wait till it cracks to do this, it will be MUCH more expensive-- thousands. To avoid, do a PPI including having the subframe lowered so the mount points can be inspected. You can't see them without lowering the subframe, but you can do it without removing the subframe. This should add ~30 min to the PPI. Ask for pictures, to prove they did it. Foam 2) VANOS pump tabs and cam bolts. Beisan Systems sells a pump disk the addresses the tab failure (permanently) which costs $150 post core return. While you're in there, have the cam bolts installed with loctite. The total job should be 4-5 hours of labor, if you don't have them refresh anything else while they're in there (e.g. vanos seals). The above fixes lock down all s54 catastrophic failure modes. Again, failure to do these cheap fixes can result in the chain blowing a hole in the side of the engine. Do them, and the issues are addressed forever. I would suggest having them replace the vanos seals ($60) and upper chain tensioner guide $14) while they're in there, as parts are cheap and it should only add another or two of labor, but it's not necessary to do so from a reliability perspective.Pump disk. Beyond that, an SMG car can be a way to find a good car for a lower price. The SMG and 6mt are the same trans, and these days it's relatively easy to convert a SMG car to 6mt. My best friend bought one and we converted it ourselves (took about 8 hours), my brother bought one and paid a shop to do it (they charged him $1100, far less than the price premium for a 6mt car). Both sold their (still functional) SMG pumps for $800+, further offsetting the costs. Plus resale is increased. Opening up the field to SMG cars makes the search a LOT easier. And then rod bearings, which you should do as oil analysis dictates (elevated lead and copper). Rod bearings wear by time spent above 7500rpm. Mine needed to be replaced at 125,000 miles, but that included ~10,000 track miles (taking every gear to redline) and bouncing it off the limiter daily from new (once the 1200 mile break in was over). I would suspect most verts will never need the rod bearings done, except for unusual owners. Beyond that, the e46 M3 is like every other BMW made-- cooling system and bushings/ball joints (all of them) should be replaced at 100,000 mile intervals, to keep it driving like new. Fluids (diff/trans/coolant/PS), filters should be replaced at inspection 2 intervals (50-60,000 miles, depending on driving style). I've been DDing/tracking an e46 M3 for 15 years now, other than one year off in an e39 M5 (decided it was too large for me, now its my wife's DD). Currently I have two e46 M3s-- my coupe (weekend/track) and an M3 wagon DD (100 miles/day).
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport Last edited by Obioban; 06-19-2017 at 07:56 AM.. |
06-19-2017, 10:18 AM | #26 | |
831
Rep 2,352
Drives: 16' BMW i8
Garage List 2001 BMW M3 E46 CON ... [9.50]
2016 BMW i8 [10.00] 2003 JEEP GRAND CHE ... [0.00] 2000 540i SPORT E39 [10.00] 2007 TOYOTA TACOMA ... [0.00] |
Pics of the M3 Wagon |
06-19-2017, 10:22 AM | #27 |
Emperor
1614
Rep 2,753
The waon is fully mechanically and electronically M3 converted (engine/trans/diff/subframes/bushings/control arms/cluster/seats/steering wheel/shifter/exhaust/ecu/etc), but has the stock, non M body work.
Build thread: http://www.m3forum.net/m3forum/showthread.php?t=555592 Recent pic. Please ignore the tint-- it's getting redone soon (came with the car). Also, it hasn't been washed since early April.
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport |
06-19-2017, 01:41 PM | #28 | |
Blocked from G80/G82 for having an opinion
3498
Rep 3,729
The car I am looking at is SMG which isn't a problem with me and I agree, converting it over once the pump fails was something I discussed with my BMW Tech friend. Hopefully everything checks out and I will be able to post up some pics next week! BTW, nice wagon! I love wagons! |
06-19-2017, 06:00 PM | #29 |
Rep 610
I've been thinking of getting my first manual car and I would like it to be an e46. (Non-M3) I really like the look of these cars.
Hard to find manual coupes here in Texas. |
06-19-2017, 09:17 PM | #31 |
3498
Rep 3,729
Its these side profile shots that really display the balanced body lines of the E46 convertible. I really love it and why I realize I keep coming back to this every so often. Having the F80 is so practical that it doubles as my family car, in a way it makes me want something unpractical hahaha
06-20-2017, 10:15 AM | #32 |
salty cowboys fan
6159
Rep 3,408
Biased Z4M owner here, but if you don't need a backseat, check out the M roadsters. Same engine as E46 m3, a bit lighter, and much easier to work on if you DIY. Very rigid, and only comes in 6MT prices are very good on these atm, around $20k depending.
she’s home! '22 M4 Comp xDrive
NickyC17484.50 |
06-20-2017, 10:38 AM | #33 | |
Emperor
1614
Rep 2,753
I do think the e46M coupe is a significantly better car than the Z4M coupe, though. My experience with working on both is that they're pretty identical to work on....? And aftermarket part options are severely limited on the Z4s vs the e46s. No SMGs to wade through with the Z4M, either!
MarkMcL1.50 |
06-20-2017, 11:16 AM | #36 | |
salty cowboys fan
6159
Rep 3,408
Z M3 |
06-20-2017, 11:27 AM | #37 | |
Emperor
1614
Rep 2,753
Or, my car during my most recent valve adjustment (at ~144,000 miles):
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport Last edited by Obioban; 06-20-2017 at 11:32 AM.. |
06-20-2017, 03:15 PM | #38 |
salty cowboys fan
6159
Rep 3,408
Nice air box Getting into the weeds here, but IIRC to get to the starter on M3 the intake manifold has to come out, but there's room enough on the Z to pull it out from top without removing anything. I suspect thats not the only time the room is helpful
06-20-2017, 04:28 PM | #39 |
3498
Rep 3,729
Wow, that's some clean internals. Did you follow the service interval or change out the oil every 5-6k instead?
06-20-2017, 07:57 PM | #40 | ||
Emperor
1614
Rep 2,753
.... if a starter ever actually needs replacing :P Quote:
Since I retired it from daily use to weekend/track use, it gets changed yearly-- every ~3000 miles. It's never seen short drive cycles. I live in the country, so every drive it gets fully up to temp. And... every drive has always included an Italian tuneup.
06-20-2017, 08:44 PM | #41 |
Rep 6,084
06-22-2017, 12:27 AM | #44 |
3498
Rep 3,729
I feel like in 10-15 years I will be in your shoes saying that on a forum to some kids looking for an F80 hahahah
