09-29-2017, 01:25 AM | #67 |
2003
Rep 2,499
Why would downshifting cause a leaking rear main seal? Can you please explain your reasoning here? I've never heard of this. Downshifting isn't "fun and awesome", it's a necessary part of driving a manual transmission.
05-01-2018, 07:28 AM | #69 |
Rep 525
I'm frankly shocked that this thread is not more active and that more people have not tried this and reported back. What's the deal?
Any issues? Any fears? |
05-09-2018, 12:50 PM | #70 |
Rep 6,870
Now that all of the tuners have figured out how to enable rev match in all modes or remove it in all modes that is where most people are turning.
05-09-2018, 01:02 PM | #71 |
2712
Rep 2,371
I don't think BM3 is there yet, as that is one big thing I am waiting for, and have not heard anything from them about it yet.
2015 Black Sapphire Metallic 6MT M4
03-28-2020, 04:31 AM | #72 |
Rep 1,977
Are people still using this trick to code out auto rev match? I’m getting rid if my BM3 License and I would like the option to get rid of auto rev match.
03-28-2020, 01:38 PM | #73 | |
Rep 433
Press start button once (do not depress clutch) Select Sport + Depress clutch and press start button to start the car Drive off and enjoy! Note: rev match will be now "off" in all modes. However, if you select sport or efficient too soon I find it occasionally begins to rev match again. If you stay in sport + for approx 20 mins from the start, it seems to hold the rev match "off" mode for the length of your drive even if you switch modes during the drive. Hope it works for you! |
03-28-2020, 03:39 PM | #74 | |
Rep 1,977
09-03-2020, 03:58 PM | #75 |
Rep 925
sauceonside31.00 |
09-27-2020, 11:31 PM | #77 |
Rep 433
FWIW that trick continues to work consistently for me. Yep it's not as convenient as being able to do it on the fly, but it's nice to have the rev match off in all modes (not otherwise possible without BM3 or similar)
10-12-2020, 12:27 AM | #78 | |
27
Rep 42
Press start button once (do not depress clutch) Select Sport + Depress clutch and press start button to start the car Drive off and enjoy! I.e. coding this out in bimmercode as described by OP and others does not work? |
10-12-2020, 08:48 AM | #79 | ||
Rep 433
03-11-2021, 11:32 AM | #82 |
Rep 19
Turn off it by bimmercode
Here you are a new setting by bimmercode for my 118D:
FEM / EXPERT MODE / 3020 Tc MASTER: TCM_STARTLOCK_BRAKE =>aktiv TCM_STARTLOCK_CLUTCH => nicht_aktiv TCM_STARTLOCK_DRIVINGREADINESS => nicht_aktiv You start engine with only one push of button and getting down bouth pedal (Brake + clutch) I confirm in this setting too a little increase in about 200 RPM when i stop the car and engaged every gear. You can code it all in NICHT AKTIV too but you have to push the strart button two times to start engine. |
02-27-2022, 07:55 PM | #83 |
18
Rep 363
Okay, here we are in 2022: SURELY someone has used BimmerCode to enable rev-matching in SportPlus...
02-27-2022, 08:12 PM | #84 |
2712
Rep 2,371
Just get a BM3 tune, it will do the job, along with a lot of other things that are also great.
