      09-20-2019, 07:27 AM   #1
Edrift
Australia
75
Drives: BMW 135i E88
RHD front door lock actuator
So I broke part of my driver side door lock actuator when replacing my door.
The lock knob stick thing that pops up and down snapped off the plastic actuator housing so the knob can't go up and down anymore.
Does anyone know the part numbers for a RHD front door actuator?
All the ones I found online are for LHD passenger side actuators that are missing the interface to get lock barrel.
Oh and I somehow managed to break that lock barrel too but found a repair kit for it. They are fragile things.
EDIT-
Found the part number from realoem:
51217202144
Only problem is that I can't find any cheap places for a replacement. AliExpress is dominated by LHD variants which have a slightly different number because the drivers door had the lock on the other side
      09-20-2019, 07:29 PM   #2
JBT2
JBT2's Avatar
Australia
36
Drives: 2015 435i
Try Rod. Just give him the part # from Real OEM. http://www.everythingbm.com/
      09-21-2019, 03:15 AM   #3
Edrift
Australia
75
Ok after much searching the cheapest I found was about $90 for a used part or $150 for a new one
If it were a LHD variant then it could be had for $50 new.
Not prepared to pay that, I disassembled the whole actuator, removed the broken part and plastic welded it back together with my soldering iron.
I added some 5 second fix for good measure too.
Seems to be working fine now (the door lock knob moves up and down again).
In case anyone is wondering, super glue doesn't work on ABS plastic which most car parts are made out of.
