BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY - Led Fog (F32 to F30) Install Only!!
proTUNING Freaks
      05-23-2016, 03:19 PM   #67
etinifni
etinifni's Avatar
Drives: 2012 328i Modern Line
Originally Posted by TrickyT
Originally Posted by etinifni View Post
Anyone know the difference between just adding the LED fog light conversion and the retrofit kit?
BMW 63132358310
Depending on the retrofit kit, it's probably just an LED replacement, without changing the housing and having proper cutoff.
That's what I was asking. What is the difference between this kit and just buying the actual retrofit led fog lights?
:wave:
      05-23-2016, 03:21 PM   #68
TrickyT
TrickyT's Avatar
Drives: 2015 Alpine White 328i xDrive
This "Kit" is the OEM LED foglight. Which includes proper housing and cutoff. A retrofit will just replace the bulb.
      05-23-2016, 03:26 PM   #69
etinifni
etinifni's Avatar
By saying "retrofit" I was referring to the LED fog lights listed at the beginning of this thread. The kit looks like it has these housings but there are extra stuff like a control bow and some capacitors. Seeing that this kit requires these makes me question if they are needed when just installing the newer led fog lights listed in this thread.
:wave:
      05-23-2016, 03:36 PM   #70
TrickyT
TrickyT's Avatar
What was posted by the original post will need coding to clear errors. Any conversion kit that adds just LED or HID normally has the capacitors etc to avoid the errors but those could also just be coded.
      05-23-2016, 03:39 PM   #71
etinifni
etinifni's Avatar
That's kind of what I thought, was just curious.
:wave:
      05-23-2016, 04:27 PM   #72
Gabreigns
Gabreigns's Avatar
494
Drives: F3x
Is there any way to make the LED fogs brighter. I feel like they are not bright enough. Some coding like for DRLs?
      05-26-2016, 09:05 AM   #73
TrickyT
TrickyT's Avatar
Did you already code this?
3062 MAPPING_ABBIEGEL_R_PWM_LEVEL_1 -> 100% : LED Foglights front right
3063 MAPPING_NEBELSCHW_R_PWM_LEVEL_1 -> 100% : LED Foglights front right
3063 MAPPING_NEBELSCHW_L_PWM_LEVEL_1 -> 100% : LED Foglights front left
3062 MAPPING_ABBIEGEL_L_PWM_LEVEL_1 -> 100% : LED Foglights front left
      05-27-2016, 03:59 AM   #74
Gabreigns
Gabreigns's Avatar
494
Drives: F3x
Thanks for this! I believe I have one of them coded but perhaps not the other line for both left and right. Will check it out.
      01-14-2017, 07:48 PM   #75
Sanelko
Sanelko's Avatar
70
Drives: 2012 Jet Black 328i
So anyone figure out what the additional hardware included with the 61132358310 kit vs buying the 63177315559/63177315560 separately is for?
Here is a post where a guy shows everything included with the kit:
http://f30.bimmerpost.com/forums/sho...1058807&page=2
Do all f30s already have the cornering foglight module?
      02-16-2017, 03:06 PM   #76
ss1523
X6M
Drives: 2016 F86, Past 2014 F32 indiv.
Difference I can see is coding vs. no-coding. The kit is plug and play, but the other "retrofits" require coding. Going to get the retrofit done for LED foglights but can't seem to find a reasonably priced pair.
      04-01-2017, 05:46 PM   #77
etinifni
etinifni's Avatar
Has anyone who has done this retrofit had any issues? I just ordered a set.
:wave:
      04-02-2017, 06:25 AM   #78
Gabreigns
Gabreigns's Avatar
494
Drives: F3x
No issues so far. A very easy mod to do. Just need to aim them better. I feel like mine are aimed too damn high.
      04-19-2017, 08:25 AM   #79
Mikael335i
France
19
Drives: BMW 335i F30
Hello CrapSOOT,
Based on your thread, I decided to install the LCI fog lights on my 335i F30.
I had no problem for replacing the left one...but for the right side, I'm facing some problem.
in fact, as you can see on the picture, the current fog light is a little bite hidden by a big vertical part and as the LCI fog light is more bigger, I think it will be impossible to install the LCI fog light.
Did you had the same problem?
Thank you very much for your help on this topic
      04-23-2017, 07:19 PM   #80
etinifni
etinifni's Avatar
Did the retrofit yesterday, couple of things to note.
My stock halogen fog lights were only attached with one screw, I thought that was kind of odd but the fog housings only have one screw hole. Second, the install is definitely really easy if you have a lift. Lastly I'm unimpressed with the light output even with coding to 100%. I'm not quite sure it's worth the high cost involved for the LCI lights.
[IMG]http://d.pr/i/wbAj+[/IMG]
[IMG]http://d.pr/i/l5Ik+[/IMG]
:wave:
      04-23-2017, 08:45 PM   #81
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Any change to LED requires coding out the cold and warm checks. My retrofit cost about $125, and the measured light output is three times that of the stock 35w halogens. My install thread:
http://f30.bimmerpost.com/forums/sho....php?t=1377259
Coding isn't difficult, well worth learning how to do. If it wasn't for the codes all being in German it wouldn't be intimidating at all.
      08-02-2017, 11:14 AM   #82
Vinboyblue
165
Drives: BMW 335
Has anyone ever tried retrofitting 6 series fogs?
      09-18-2017, 01:30 AM   #83
alexgarcia
Mexico
Drives: 2016 320i base sedan
hi guys,
I just bought fog led lights retrofit OEM parts:
63 17 7 315 559
63 17 7 315 560
These havent arrive yet and I thought I needed resistors but now I understand all I need to do once installing them is do a coding. I have no idea where to look for the codes or how to do it since I am new into upgrading my car etc...
Mine is an F30 (year 2016 320i) VIN K356623
Can someone point me in the direction of the codes I need to set up and also how do I do a coding I have no idea what I need? I have a schwaben mini/bmw scanner, is that good or do I need a software and ENET cable?
Thanks....
      09-18-2017, 03:45 AM   #84
atzebmw
Germany
588
Drives: Tesla Model 3
Originally Posted by alexgarcia View Post
hi guys,
Thanks....
You need the e-Sys software and an ENET cable.
Or you can find someone who codes for you.
      09-19-2017, 12:02 AM   #85
alexgarcia
Mexico
Thanks for your guidance Atzebmw
Dante467.50
      09-19-2017, 11:53 AM   #86
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
alexgarcia ,
You only got a partial answer above.
To do any coding on an F series, you need the following:
  • Cable (OBD II connector on one end and LAN connector on other)
  • E-Sys progrgarm
  • E-Sys Launcher
  • PSdZdata -- probably Lite will be good enough unless you intend to Flash an ECU, then you'll need Full version
Suggest you post on this thread: http://f30.bimmerpost.com/forums/sho...916911&page=21
When doing so, address your post to either ShawnSheridan or Almaretto
With all of the above, it's really very straight forward to code out the warm & cold check that the system routinely does for regular bulbs, but not necessary for LEDs
Hope that helps
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
      09-20-2017, 05:14 PM   #87
SalpacinoBMW
SalpacinoBMW's Avatar
14
Drives: 2012 335i Sedan
Originally Posted by Dante View Post
Thanks for the DIY!
I did that mod in February.
This also works with the wheel mounted. Just go full lock to the left when doing the driver side (other side vice versa).
With the wheel in place, you can tug the fender liner behind the wheel, just like you did with the brake disc.
When putting the new LED fog in place, I found it useful to pull up on the mount. It might not slip into place easily (it didn't with my M-Sport bumper, there was a gap), but when you pull up from the inside, the fog will find its way.
This looks so much better than the yellow fogs. Plus, the cornering lights still work with the LED, which is a bonus.
Just code everything to 100%, otherwise they will start to flicker after a few seconds!
Do you have the link or info on the lights you used?
      09-21-2017, 04:58 PM   #88
alexgarcia
Mexico
My fog led lights arrived today
I much better understand now all that it is required to do the coding. Today my fog led lights arrived (they look so nice) and I cant wait to install them even I dont have all necessary software and hardware to do the coding.
I have read some retrofits have no error or require no coding (i dont know if that is my case) anyways I will look into getting all the required to do the coding and will post in the thread below for guidance. I am about nervous about all this coding but since I am also upgrading my 6.5" screen to a 8.8" screen with navigation I really need to learn all this.
I will post some images as I start my installation...(I was about to consider buying the resistors but I will not now and better deal with this coding challenge)
Thanks,
Originally Posted by RSnic View Post
alexgarcia ,
  • E-Sys progrgarm
  • E-Sys Launcher
Hope that helps
