Some wiring diagrams for the members
03-27-2013, 12:19 PM | #67 | |
Rep 4
hifi harness
03-27-2013, 09:56 PM | #68 |
Rep 1,585
Drives: 2011 VO 1M
Garage List 2010 Porsche 911 GT3 [10.00]
2021 BMW X5 SD40i [0.00] 2023 Toyota TRD Pro [0.00] 2011 BMW 1M [9.83] 2014 Ford Raptor [0.00] 2005 Ariel Atom 2 [0.00] 2008 135i SOLD [10.00] |
I have a new harness that I didn't use during my install. PM me if you are interested.
I am actually move to the Mobridge DA2 because I can't get rid of the damn floor noise.... Upgrading L7 is more of a challenge than I thought |
03-28-2013, 11:08 AM | #69 |
9
Rep 75
Drives: 335i
Which harness do you have and how much do you want for it? I tried sending PM but it wouldn't let me
03-29-2013, 11:23 AM | #70 |
Rep 1,585
Drives: 2011 VO 1M
I'll take a pic of it. I believe it's a hifi harness that can be used for L7 applications. I will verify that, I paid $45ish for it so can sell if for a few bucks less.
08-15-2013, 09:47 AM | #71 |
Car Tuning Geek
581
Rep 1,475
Anyone have pictures of the base, HIFI and logic system? I'm not sure which one this car has?
04 GPW/Onyx NSX
08 Rio Yellow s2000 CR 16 F80 Dakar M3 15 Ferrari 458 Spider |
Livinlife335i1.50 |
08-15-2013, 10:48 AM | #72 |
Rep 3,201
There are stickies addressing this question. Or you could go here:
http://www.musicarnw.com/start-here-your-car/ |
08-15-2013, 10:49 AM | #73 |
Rep 3,201
And if you're talking about the 09 M3, it has EITHER HiFi or Individual/Enhanced Premium. It won't have base (in the US) nor Logic 7 (in the US).
08-19-2013, 08:02 AM | #74 |
Rep 1,585
Drives: 2011 VO 1M
^ Musicar to the rescue! Btw, I have purchased from them, and would highly recommend MC. Ken really knows his stuff; and the products + custom enclosures are top notch!
///1M #643 of #740
04-04-2014, 02:27 PM | #76 |
Rep 2
Would you happen to know what runs underneath the little compartment in front of the shifter if you remove the rubber lining?
This is what I mean: Last edited by ckorban; 04-04-2014 at 03:40 PM.. |
04-10-2014, 01:37 AM | #77 |
Rep 1
Hi, I have a 2010 BMW e93 with I Drive Business Nav but a BASE audio non amplified. The floor sub-woofers have 4 wires into them.
As these are in parallel with the single unit door speakers is it not possible to connect into 2 of these 4 wires to take high level inputs (2 front channels) to the 4 channel amp??? Then connect to the remaining 2 wires to feed new door speakers (I intend to use the Focal 100RS units) with 2 channels from the amp. This will save running new wires into the doors from the sub connector point. Running new wires to the sub point from the rear amp for the 4 channels. Can anyone help please?? Last edited by Aitchmarsh; 04-18-2014 at 03:55 AM.. Reason: Clarity |
07-16-2014, 11:29 AM | #78 |
Rep 1
Thanx
Worked great for me, just tapped in to the wires, soldered a couple female rca plugs with 4 inches of wire and plugged in to my amp" Rockford Fosgate 1000" with a male to male rca cable, stole remote to, hooked up the amp to my speaker box equipped with 2 12" Alpine typeR bas speakers and boom.... got great sound
08-04-2014, 06:08 PM | #79 |
10
Rep 130
Drives: 2008 328i Sedan Sports
This diagram is incredible and I wanted to reshare it. Now I feel safe changing to big power and bypassing the HIFI plus knowing what the stocks can take etc that I may keep some.
So much great help on this forum. I don't use the others much because e90 is so badass! http://www.e90post.com/forums/attach...1&d=1209780865
2008 E90 328i Sport Sedan
335 189 wheels/Eibach Pro-Kit/H&R 10&12mm/K&N/Charcoal delete/LED Past:2012 R56 MINI S/1992 E34 525i/1989 E30 325ic |
10-29-2014, 04:12 PM | #80 |
Rep 2
Help please if someone can give me an idea i will really appreciated.
I need to replace this cable 61129130178 According to the dealer they want over 500 for the labor and parts the part only cost me 21. The cable is in the batter where it goes no idea I was thinking the under the driver seat is a long wire unless in travel all over the car or maybe under the center console if someone have any idea will be well appreciated. This is because i have the airbag light on in order to be reset wire needs to be replaces. thank you. |
01-05-2016, 05:09 PM | #81 | |
14
Rep 37
Drives: 320d, M Sport Coupe
08-16-2016, 04:24 AM | #82 |
9
Rep 75
Drives: 335i
If I want to add a crossover just for upgraded tweeters is that still possible since they are wired along with the Mids on the doors?
Currently have JL ZR-100 (tweeters) JL C5-400cm (Mids at door) OEM subs and JL 6/600 Any suggestions are appreciated |
08-20-2016, 02:09 PM | #83 |
Rep 13,115
Can't you get a passive crossover from JL?
Probably any passive crossover would work but one designed by the speaker manufacturer would probably be better. |
08-22-2016, 01:28 AM | #84 |
9
Rep 75
Drives: 335i
I have the ones that it came with but does that even work since the speakers are wired parallel? I'm going to re wire everything so that everything has its own channel. Any reason that's not recommended for any reason?
08-24-2016, 01:33 PM | #85 |
Rep 13,115
Everybody splits the connection
Everybody splits the connection(parallel)
that's what you have to do to get good sound quality. Then most people put the crossover in the door to void having to run another set of wires to the door. If you look at the Technic Harness kits for base system I think there is only one of 4 that does not split the connection. See technicpnp.com |
10-23-2016, 01:42 AM | #86 |
Rep 52
Got a quick question everybody i just bought a logic7/hk wiring harness from technic pnp and was wondering is their such thing as putting the connector back on the oem amp upside down or it doesnt matter? Im asking because both ways fits.
10-05-2017, 12:26 AM | #87 | |
Rep 2
Color coding
11-11-2017, 02:57 AM | #88 |
58
Rep 213
hi,
I don't know if I'm in the right place to post this. been around this site for wiring diagram information for my 2007 e90 n54. I have a crank no start problem and wanted to look at the wiring. I took out my spark plug coil pack to check for spark. pulled out coil pack, left electrical plug in and used a screw driver with wire to run close to ground to see the spark jump when cranking=NO SPARK COMMING FROM COIL PACK. So I switch to another coil pack and it was the same result. so I figure I would start looking into the wiring diagram of how the coil packs are wired and how can I test them. please help or point me in the right direction. thank you. vehicle symptoms: was driving, I down shift and pressed the gas paddle, all of a sudden my car starts to miss/sputter.. yellow check engine lights come on. I had to drive 20miles more to my destination. Got there, went out and came back to start car 3hours later. Car started and then died out. since then, my car hasn't been able to start. friend accidently erased the codes with his reader. so tried to restart and pull codes. only code came out was a p0341 code which refers to the camshaft sensor. so I order cam and crankshaft sensor and replaced both. also cleaned out the venos solenoids and swapped and replaced them, checkout out all spark plugs. tried to restart car and still same problem long cranking, no start, half yellow engine light on which mean limp mode? help help help. |
