rear starter bolt stripped n52
05-02-2023, 11:08 PM | #1 |
33
Rep 217
I tried using a 11mm and it ended up stripping the rear bolt, i put the E14 back on by hand it still fits snug since I barely stripped the top threads. My ratchets dont fit im getting a swivle head tomorrow and Hopefully it works. Although is it the same process of stripping a oil filter housing bolt by the mickey mouse flange where you can cut the head Of the bolt and that allows you to pull of the housing?
05-03-2023, 12:54 AM | #3 |
DIYer
274
Rep 312
I ordered some etorx wrenches when doing mine. Please for anyone reading do not try to use other types with e-torx unless they are big like the center support engine brace.
Then again, the cost to cover a set of sockets and wrenches for most all e torx on the vehicle is at most $75 in tools. |
05-03-2023, 06:42 PM | #5 | |
e91Owner
425
Rep 1,129
You’d probably have better luck with a small bolt extractor. |
05-03-2023, 07:08 PM | #6 |
Rep 4,324
Yes, if you manage to snap the head off, the bolt slides out of the hole.
I had this happen once and I drilled a hole through the head of the bolt. I used a chisel and hammer and hit the bolt and the head snapped off. Maybe I was lucky that the whole head snapped off. |
