2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY Leaky Turbo Lines 550i (n63)
      02-01-2017, 08:09 AM   #23
BadBoyBeltran
Drives: 2011 BMW 550i GT
Hey guys resurrecting this thread.
Getting a turbo coolant pump error and a turbo coolant pump return line error. I already have changed the hoses like what you guys have on your photos.
There is a recall/service bulletin to change the lines and the auxiliary coolant pump. Have you guys had this done?
Recall # is 11V-521 Service Bulletin 11 08 11. By the way, these pump failures does not illuminate your CEL.
      02-01-2017, 09:26 AM   #24
BadBoyBeltran
PS
Which is the fuse for the turbo aux cooler pump?
      02-08-2017, 04:02 PM   #25
dadysev
dadysev's Avatar
Montenegro
170
Drives: Man
Here is another leak that can develop! RRRR.
Thanks to the OP for this.
http://f10.5post.com/forums/showthread.php?t=1275796
      03-05-2017, 01:09 PM   #26
Milestune
22
Drives: BMW
Dadysev, what size hose did you use? It almost looks as if the OEM hose is tapered?
      03-06-2017, 12:37 PM   #27
dadysev
dadysev's Avatar
Montenegro
170
Drives: Man
Can't remember if it was 1/2 inch or 3/8. I bought both. sorry,.
      04-13-2017, 01:19 AM   #28
335socal
Drives: Alpine white 335 coupe
3/8 fits snuggly. 1/2 is too big on the turbo coolant return pipe and will leak.
      07-25-2017, 05:21 PM   #29
Jims M3
Drives: F95 X5M, F80 M3, C7 Z51
I just bought the silicone hose highlighted earlier. Did you just cut off the OEM clamps? Did much coolant come out?
      08-29-2017, 04:56 PM   #30
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Should I be concerned only one hoes
      08-31-2017, 12:29 PM   #31
dadysev
dadysev's Avatar
Montenegro
170
Drives: Man
Thats exactly where it starts!
      08-31-2017, 02:27 PM   #32
Bossman535
13
Is this for the n63 550i, and what year?
Any symptoms you received when they failed ?
      09-27-2017, 10:21 AM   #33
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
what happens if the pump fails?
      01-16-2018, 11:34 AM   #34
rogueshot
Drives: '10 550 GT
# 17127576363 is the "left" side "y" fitting and hoses. Does anyone have the part # for the right "y" fitting and hoses?
      01-16-2018, 07:46 PM   #35
BloomingtonFPV
Drives: 2011 550i xdrive
There is only one 'Y'. Check these:
http://www.realoem.com/bmw/enUS/show...diagId=17_0490
http://www.realoem.com/bmw/enUS/show...diagId=17_0920
http://www.realoem.com/bmw/enUS/show...diagId=17_0922
Which one do you mean?
      01-17-2018, 09:07 AM   #36
rogueshot
Drives: '10 550 GT
Bloomington,
aren't there 2?
      01-17-2018, 04:47 PM   #37
BloomingtonFPV
You are looking at the turbo coolant lines. The one that has plastic (17127576363 ) is deep down inside, right in front of the turbo actuators (the silver disk things). It sends coolant to the engine. It is a huge pain to replace.
The top ones are easy to get to and easy to replace, or just patch up where they start to decay.
      01-17-2018, 04:55 PM   #38
BloomingtonFPV
Here is what I ordered:
https://www.fcpeuro.com/products/bmw...se-11537577014
I didn't get a left one, but here are all the part numbers:
http://www.realoem.com/bmw/enUS/show...diagId=11_4190
      01-23-2018, 01:13 PM   #39
rogueshot
Drives: '10 550 GT
Now i get it! thanks for taking the time to clarify. My top ones are in good shape showing the tiniest bit of crust but no active leaking. I suspect the lower Y connector/hoses under driver turbo are the ones leaking. Figures. I guess I ll pop the turbo intake hose to get a better view and then decide if I go the brass "T" repair or replace the entire hose/fitting assembly. Not sure I am up for alternator/fan/cowl removal to gain access....
      01-23-2018, 01:19 PM   #40
BloomingtonFPV
See this thread for how I did it:
http://www.bimmerfest.com/forums/sho....php?t=1183633
Also see this:
https://www.newtis.info/tisv2/a/en/f...epair-manuals/
      02-15-2018, 03:32 PM   #41
dadysev
dadysev's Avatar
Montenegro
170
Drives: Man
Have you guys noticed burning smells? When the coolant burns by the turbo i noticed its not the typical smell. I'm guessing because of the increased heat. It almost smells like a toxic plastic burning.
      03-26-2018, 09:45 PM   #42
adammilad
Drives: 2006 550i
The Tee is 1/2" line and the metal line going to the turbos is 3/8". I could not get the 3/8" to work so just made due with 1/2".
      03-28-2018, 05:09 PM   #43
Bossman535
13
Yah I get the plastic burning smell as well.. so that's the coolant lines going bad ?
      03-29-2018, 05:02 PM   #44
dadysev
dadysev's Avatar
Montenegro
170
Drives: Man
Well for me thats the coolant bubbling in the valley of the motor. Mostly likely caused from leaky coolant from the turbo lines.
5post
