01-16-2021, 11:52 AM | #67 | |
Rep 4,445
Need to run the mic after lunch.
01-16-2021, 03:27 PM | #68 |
Rep 21
Hey making a 2nd request for any instruction manuals for the dip switch settings... My box came with no manual on this so I'm not sure which dip switches I need to activate for my car.
Its a 2009 pre-lci e92 with individual audio if anyone is able to help! |
01-16-2021, 03:55 PM | #69 |
///M
95
Rep 252
Has anyone tried or know if it's possible to do the coding with Bimmercode after installation? Unfortunately I installed the Bimmertech unit about a month ago and didn't see this coding piece.
01-16-2021, 05:31 PM | #70 |
Rep 619
Look in the above post. Someone told me try 3 and 4 on. That worked for me.
01-16-2021, 07:12 PM | #72 |
Rep 3,331
For Carsara 3/4 should be on. All others off. There should be no other settings that work on the E9x M3.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
01-16-2021, 07:14 PM | #73 |
Rep 3,331
There is an in and an out for each size connector. I believe the bigger connector is the unused set for our car. So one of these connectors will connect to the microphone itself. The other one will connect to your existing microphone cable. Two connectors will remain unused - I wrapped them with electrical tape so they wouldn't rattle.
01-16-2021, 08:31 PM | #74 | |
Rep 21
Now I'm stuck on the wiring for the back of the CIC. Somehow my carplay box input is a female connection to female connection on the CIC... Not sure what I did wrong there so back to reading posts as I swear in my readings someone else has mentioned this. |
01-16-2021, 08:47 PM | #76 |
Rep 3,331
Try 3/4/7 on. I think someone else posted that configuration. I have the pdf on my laptop but don't have it handy.
01-16-2021, 08:51 PM | #77 | ||
Rep 3,331
Did you try all possible configurations? One end needs to connect to your existing LVDS cable I don't recall which ends were male vs female.
01-16-2021, 09:05 PM | #78 |
Rep 21
I think that’s what I have going on.
01-16-2021, 09:37 PM | #79 |
Rep 619
01-16-2021, 09:52 PM | #81 | |
Rep 3,331
Contact the seller see if they will refund or send you the right set.
01-17-2021, 11:46 AM | #82 |
Rep 973
Drives: 2012 E92 M3 DCT ZCP
Here are the instructions.
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE/ARP | MPE V2 | AA green filter |BMW CF Rear Spoiler, RW Carbon Diffuser, CF Front Splitters | DTEC 160W Angel Eyes
01-17-2021, 12:38 PM | #83 |
Rep 10
Ladies and Gents
I've just posted on the original (big!) thread but as this is Carsara specific I hope someone can help/advise me please. I've followed this thread with interest - thanks to Cyberdemon and you all for making this such a helpful resource I run a 2012 F10 Alpina (sorry ) with CIC and decided to take the plunge with a Carsara box and installed it today. It's almost there but I have the exact same problem as PACarGuy - after 1 min I get the same error message, see image. Like your E9* installations, my car did not need the iDrive loom - the controller works the screen perfectly. A# is connected to B#. I've tried connecting L# to B# but then the display does not come on at all. I've also tried connecting the IDrive loom in case this works, but nothing with that either. The most successful option is A# direct to B# with L# not attached to anything, but I get this error message every 1 min. Any suggestions guys? I wonder if something is needed into the feed L# and this is tripping the message?? One other quirk is if I turn on the radio with the ignition off, before the install I'd get the iDrive screen switch on and radio would play. Now radio plays but I get no iDrive screen, only an orange screen. But if I turn the ignition on, normal BMW splash screen and iDrive screen loads as normal. Other than this it seems to work ok. I've emailed carsara and hope they can help, or I hope someone can advise me on how to solve? On audio, like you guys I've tried to code out AUX from the console to HU only but I only get the first code option CDMM_AUX_HU - I've changed to "aktiv" But I can't find the USB_SINGLE or DOUBLE Currently I am only getting audio if I connect the aux wire into the console (so it's still live despite the one code change I made) Any advice would be gratefully received |
01-17-2021, 01:10 PM | #84 | |
Rep 973
Metrics4.50 |
01-17-2021, 02:17 PM | #85 |
Rep 10
Hi PACarGuy. Yes I saw your post and tried that. My loom didn't have the CIC-KT connected, so I tried connecting again in case it made any difference but it didn't. The loop is also removed.
I'm pretty sure all the connections are good but that's something I will check again as I go through it all again. Really puzzled on what's occurring |
PACarGuy683.50 |
01-17-2021, 02:59 PM | #86 | |
26
Rep 183
Current: E93 M3 DCT/Jerez Black/Fox Red-Black
Gone: E93 M3 DCT/Alpine White/Fox Red/Premium/Enhanced sound/Convenience Pkg. ED: 10/04/2010 |
01-17-2021, 03:05 PM | #87 | |||
Rep 6,635
01-17-2021, 03:08 PM | #88 |
Rep 6,635
I copied this from someone.
Nazty Naze One!57.50 |
