01-12-2019, 11:30 PM | #1 |
46
Rep 194
Decoupling steering weight from suspension stiffness
Does anyone know how to decouple the steering weight from the suspension stiffness and throttle response in Sport Mode? I want: stiff suspension, responsive throttle, and light steering. My car has adaptive suspension.
I am in the Los Angeles area. Any recommendation for a shop that can properly code for this would be greatly appreciated. |
01-12-2019, 11:35 PM | #2 |
Rep 1,827
AFAIK, it's not possible to accomplish what you're looking to do with basic coding. There is a coding option to allow for Configuration of Sport mode, wherein, you can select either the drivetrain (throttle response) or chassis (steering & suspension) to be in sport or normal mode when Sport is activated. However, I don't think there's a way to code the Chassis configuration to make steering and suspension separate.
I don't have adaptive suspension, so it doesn't really apply to me, but this is based on what I've read thus far in the forums.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
01-13-2019, 12:11 AM | #3 |
46
Rep 194
I know Dinan Shockware moves the stock sport suspension setting to Comfort mode, so you get stiff suspension and light steering, but not responsive throttle. I called Dinan to ask if they had a solution for this but no luck. I'm sure someone on this forum knows how to accomplish this.
01-13-2019, 12:54 AM | #4 |
2JZ-GTE
3069
Rep 4,015
Nope
01-13-2019, 02:19 AM | #5 |
95
Rep 116
If you're considering the Dinan shockware anyways, what you MIGHT be able to do is configure sport mode to have sport drivetrain but comfort chassis. That way you'll have the sport throttle response, the light steering, but "comfort" suspension, which is now essentially the sport suspension.
01-13-2019, 09:30 AM | #7 | |
46
Rep 194
01-13-2019, 11:04 AM | #8 | ||
95
Rep 116
adaptive, button, coding, mode, sport, steering, suspension |
