BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
Extreme Powerhouse
      09-03-2019, 05:59 AM   #23
kern417
Cheapskate
4464
Drives: 2018 440i |2016 340i | 2010 X5
Originally Posted by IMS-340MP View Post
I guess engine load is different in each gear ? MHD recommend 4th gear with DSC off.
Originally Posted by GT500R View Post
Load is different and therefore so will boost or timing.
Again, why would load be different. Doesn't make any sense.
Stage 1 3rd Gear: http://www.bootmod3.net/log?id=5d5a1459ae729b5f706741e8
Stage 1 4th Gear: http://www.bootmod3.net/log?id=5d5a1463ae729b5f706741e9
Like I said, post logs to show what you're talking about so we can fill this thread up with data. At least with bootmod3 there's no difference between gears. Boost, timing, and load are all the same. Load is primarily based on RPM and throttle angle, not gear.
Also your timing advance is quite low I guess with a bit less boost or higher octane you will get better timing and more power.
That's what happened to me when I increased the boost timing retarded which resulted to lower top end power.
I learned that more boost not always equal more power, Ignition timing is the key, If we don't get a good combustion then the extra boost is useless.
Also how do you make your own tune ? I wish I could do that.
I was planning on tuning my own car but I'm going to wait until I can get dyno time for this very reason. It's typical to keep upping the boost and then add timing until it begins to knock, but you don't make the most power that way. You need to put it on a dyno to really tell if you're making more power with the changes you make.
I agree, our cars seem to like timing more that boost.
Originally Posted by umizoomi View Post
As long as 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
Youtube/Instagram/TikTok: @kern417
      09-03-2019, 09:24 AM   #24
Solid67
Drives: 2019 M240i xDrive MP Edition
Car: 2019 M240i xdrive M Performance Edition
Mods: BM3 Stg 2 E30 OTS, xHP Stg 3 TCU Flash, ER Catless Downpipe. MPPSK Exhaust, FTP Intake + Intake Pipe, FTP Chargepipe, NGK 94201 gapped to .022
Fuel used: E30 (Mobil 93 + Mobil E85)
Gear: 3rd - 2500rpm to 6650rpm shifting into 4th.
IAT: 101f
Boost: 16 PSI
AFR: 12.84
Timing: 14.5 degrees
http://www.bootmod3.net/log?id=5d5f4d0cc090c6120e71fd12
kern4174464.00
      09-03-2019, 09:29 AM   #25
kern417
Cheapskate
4464
IAT: 101f
Boost: 16 PSI
AFR: 12.84
Thanks, I'll update the baseline figures. I think it's strange that BM3 stage 2 logs tend to show big boost spikes and throttle closures. You peaked at over 22psi. I feel like they need to update their OTS maps for more progressive boost onset. How does it feel?
      09-03-2019, 09:32 AM   #26
Solid67
It's kind of annoying to be honest. I opened a ticket with PTF about the throttle closure issue and Halim said through adaptation, the throttle closure issue should take care of itself. However, that has not been the case. You can definitely feel it in 3rd and 4th gear when you floor it. It feels like the car isn't going or hesitating then it blasts off. I'd give up the blast off feeling for a more progressive/linear onset. I feel like its hurting my numbers too (1/4 and 60-130mph).
kern4174464.00
      09-03-2019, 10:01 AM   #27
IMS-340C
IMS-340C's Avatar
Egypt
396
Drives: Self Tuned 340i 8AT RWD
https://datazap.me/u/ims/log-1565091454?log=0&data=3-16
      09-03-2019, 11:55 AM   #28
msk340i
Drives: 340i M sport
Can someone look at this? It's on bm3 stage 2 93 octane
http://www.bootmod3.net/log?id=5d6e5ba2ae729b405635f152
http://www.bootmod3.net/log?id=5d6e5b82ae729b405635f151
I'm worried about the knock, should I be?
Anything else to look at?
Thank you guys
      09-03-2019, 12:33 PM   #29
IMS-340C
IMS-340C's Avatar
Egypt
396
I don't get it why are you worried ? your detected knock is zero.
Unless you are hearing pinging sound from the engine then you should be worried.
Thank you guys
      09-03-2019, 01:00 PM   #30
msk340i
The second log shows two knock events, no?
      09-03-2019, 01:26 PM   #31
IMS-340C
IMS-340C's Avatar
Egypt
396
You mean the 2 spikes at 2000 and 2500 RPM ? That's minor knocks.
You worry if knock are higher and last far more than that.
It could also be a misfire not a knock.
      09-03-2019, 01:35 PM   #32
msk340i
Got it! That's why I asked you guys 😂 thanks a lot.
Everything else looks ok?
      09-03-2019, 02:02 PM   #33
IMS-340C
IMS-340C's Avatar
Egypt
396
Yes at 6500 RPM and 16 PSI boost your timing is around 12 is very good.
      09-03-2019, 02:44 PM   #34
msk340i
I don't know what that means but I totally trust you internet stranger 😜
Thank you
      09-03-2019, 02:49 PM   #35
IMS-340C
IMS-340C's Avatar
Egypt
396
If the engine is knocking your timing will be much lower than 12, In technical terms it will "Retard"
The Internet Stranger
Thank you
      09-03-2019, 07:46 PM   #36
GT500R
Drives: BMW X3M
How was this determined? Generally higher compression ratio cars do extraordinary with gains when adding boost... i.e. the 5.0 with a supercharger is a beast due to high compression motor.
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance
10.84@127.43 / +1912 DA NH Dragway |
10.6@130 Dragy / +820 DA The Streets |
NOW: Tesla Model Y Performance
      09-03-2019, 07:50 PM   #37
kern417
Cheapskate
4464
Thank you guys
As a rule of thumb, do not floor it at that low of an rpm. Either downshift or only push partial throttle. Flooring it at low rpm can cause knock.
When you log, start above 2000rpm. That's the main difference I see between your too logs and likely what caused the knock in the second log.
I've experienced the opposite. Typically you lower the compression ratio to add more boost. Otherwise you need to rely on timing to make good power. It just seems like on our cars, adding a lot more boost doesn't make a lot more power. I'm not sure if the turbo is limited or if the engine just doesn't respond as well to it. But regardless there will be a point where efficiency is at its peak, and then adding more boost pressure just creates more heat.
Until I get on a dyno and adjust my tune I can't say for certain. Just what I'm seeing to be typical since our tunes rarely push over 20 psi.
      09-03-2019, 09:21 PM   #38
GT500R
Drives: BMW X3M
Is "load act. %" the actual load?
      09-04-2019, 03:44 AM   #39
IMS-340C
IMS-340C's Avatar
Egypt
396
Guys you are missing the key factor here, OCTANE.
Yes high compression and high boost should have great power assuming using very high octane fuel.
High compression + high boost = knock > Retarded timing > Less power.
Add the appropriate octane fuel to the equation and you are fine, also putting into consideration ambient temperature.
I witnessed this personally when I ran stage 1 with more boost than MPPSK I actually had less power at top end as the only fuel available here is like 88 octane.
Even with MPPSK and only 14 PSI of boost at 6500 RPM my timing is around 8-10 degrees which is very bad.
kern4174464.00
      09-04-2019, 03:58 AM   #40
IMS-340C
IMS-340C's Avatar
Egypt
396
I guess so, why I feel suspicious in your question
      09-04-2019, 05:42 AM   #41
kern417
Cheapskate
4464
Stage 1 E30 logs. I always have one cylinder lagging behind, but it tends to catch up by redline. It looks like everything is the same except they increased the timing to 15°. It definitely feels faster than 93.
http://www.bootmod3.net/log?id=5d6f91bdc090c652e3aa365c
http://www.bootmod3.net/log?id=5d6f91bec090c652e3aa365d
      09-04-2019, 05:48 AM   #42
kern417
Cheapskate
4464
So one of the reasons I made this thread is being shown. I'm having trouble seeing the difference between Stage 1 and Stage 2. Are there any other stage 2 logs out there? I thought it had a higher boost target. And I don't really see how it's taking advantage of a downpipe or why it's needed.
      09-04-2019, 07:59 AM   #43
IMS-340C
IMS-340C's Avatar
Egypt
396
I was also wondering the same thing, what's the difference in tuning between stage 1 and stage 2 same octane.
We know Decat release exhaust gases out of the cylinders faster but how can we benefit from that in terms of tuning ?
kern4174464.00
      09-04-2019, 08:45 AM   #44
enemigo13
Drives: F32 LCI 440xi citrineblack
logs should be done after some WOT pulls. as this ecu will target less right after writing or e.g. after 1-2 WOT pulls. It needs more to make adaptations. Usually stage 1 gives ~1.1 bar (16psi) at ~6200rpm, stage2 gives 1.3 bar (19psi) at the same rpms.
