DIY - NBT Retrofit - E92
12-01-2016, 04:53 AM | #23 |
Rep 11,903
12-06-2016, 02:32 PM | #24 |
42
Rep 163
Thank you for this DIY socket. I was planning to do a CIC retrofit on my e92 next summer but may just go straight for the NBT as I've seen some good prices on eBay for the unit, screen and controller.
Do you mind sharing the parts numbers mate from your list? Also I assume the Bluetooth antenna and the emulator is Non BMW so if you can share a link for that I'd be grateful. |
12-07-2016, 02:02 AM | #25 | |
Rep 11,903
http://www.e90post.com/forums/showth...&highlight=NBT |
12-08-2016, 01:30 AM | #26 |
Rep 18
Drives: E90 320d maybe
So, there is a lot of models of crashed cars on the market here in Croatia that could serve as donors for NBT unit, but since majority of the sellers are not familiar with product numbers of the parts in their wrecks, I am having trouble steering myself in the right direction.
So, could someone please shed some light here... E90 adds for example, usually advertise their systems as "Big navigation", Professional or Business unit, etc. Can you tell me what type of car am i looking at to dissect for NBT? can it be something like iDrive Proffessional from, lets say F30? i only know that i need 8,8" screen and can recognize the control knob that goes on the trim. I have seen NBT head units that are more 1-Din than 2-Din size (like THIS one), so i wonder, from which car, and with what "mainstream" name, will the unit actually be suitable for this E90 retrofit? |
12-25-2016, 05:58 PM | #29 |
Rep 11,903
12-26-2016, 10:02 AM | #30 |
46
Rep 370
12-26-2016, 10:48 AM | #31 | |
Rep 11,903
http://www.ebay.com.au/itm/Bluetooth...QAAOSwpdpVdUMw and reverse camera http://www.ebay.com.au/itm/CCD-Car-R...item3ab91a4b5e Both work fine No coding required as the NBT head unit should come coded for you vehicles VIN number Hope this helps |
12-28-2016, 09:30 AM | #32 | |
42
Rep 163
Cheers |
01-02-2017, 05:36 AM | #34 |
Rep 11,903
01-02-2017, 05:37 AM | #35 |
Rep 11,903
06-18-2017, 08:12 PM | #36 |
Rep 11,903
09-24-2017, 07:58 AM | #38 |
Rep 11,903
bump
02-25-2019, 06:21 AM | #39 |
10
Rep 93
Hello guys. I am currently waiting for my NBT to arrive and I am doing the retrofit. My car is currently without any navigation (2012 E92 328xi). I have one question for now - can I use the bluetooth antenna that is located on the plastic under the steering wheel, next to the speaker, or I have to buy a new antenna ?
02-25-2019, 10:41 AM | #40 | |
118
Rep 342
I keep getting robbed because I leave the front door open..
I could close it but I feel doing so would be a victory for the thieves.... |
niksss10.00 |
02-25-2019, 11:17 AM | #41 | |
Rep 1,912
03-05-2019, 04:34 PM | #42 |
10
Rep 93
Any idea what is the part number of the cable ? Link from ebay or aliexpress also works. Also the same about the cable that runs from the head unit to the USB/AUX in the armrest ? I think that ordering two new cables will be a lot easier than rewrouting the existing wires.
03-26-2019, 10:13 AM | #44 | |
118
Rep 342
The mounting holes are also in different locations, you need to cut some so the controller rests flat and use something to hold the controller in place. I used strapping from Home Depot.
