PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
Rubbing in front.
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
04-26-2022, 12:32 PM | #1 |
Rep 20
Rubbing in front.
This question might be asked way to often. But can't find anything regarding my setup.
Since a few weeks owner of a 320i automatic. Had some terrible wheels on it so decided to swap em out for Style 594's (OEM x6) It has 255/35/19 Ps4 all around. But it rubs badly on the fenders. not so much or almost none on the inner wheel wells. Pokes in the front quite a bit, but rear's are flush with room to spare. Wheel specs: 9J Et 15 on all 4. So is there a tyre that will fit without rolling the fenders on these offsets? |
04-26-2022, 08:11 PM | #2 |
40
Rep 108
The front fenders are plastic and cant be rolled. Sorry to say I don’t think you will make these will work on the front.
Edit - are you sure theyre et15 all around? OEM X6 wheels are most likely stggered, so you might be able to swap your front and rears |
04-27-2022, 12:48 AM | #3 |
32
Rep 58
Hello fellow wagon owner! I have a LCI wagon but I am not qualified to offer any recommendation because I've never tried any 19-inch wheels. Maybe look into 245/30/19 tires and also I've heard that Continentals typically have a narrower sidewall shoulder, but again take my suggestion with a grain of salt.
I am running a 18x9 ET31 wheels and 255/35/18 tires, and the front is exactly flush with the fender. So I'm afraid that making your wheel spec work without rolling fenders or crazy camber is... slim. |
04-27-2022, 01:59 AM | #4 | |
Rep 20
Pretty sure they're et15 all around according to the bmw number on the inside. There is a et45 option, but i think that would push the wheels out even further if i understand the ET sizes correctly. Edit: it's et48, and i completely mis understood et values. Last edited by JRwagon; 04-27-2022 at 02:11 AM.. |
04-27-2022, 02:04 AM | #5 | |
Rep 20
I got 1 more size to play with but those are et46(or45), but that would push them even more out if i'm not mistaken. Little poke is ok with me, as long i dont use the tires to automaticly roll the fenders Crazy camber is a bit of a no go, it doesnt look good for me on a e90/91 etc Edit: it's et48, and i completely mis understood et values. Last edited by JRwagon; 04-27-2022 at 02:11 AM.. |
04-27-2022, 04:10 AM | #6 | |
32
Rep 58
04-27-2022, 04:14 AM | #7 | ||
32
Rep 58
04-27-2022, 04:29 AM | #8 |
Rep 1,489
According to a bmw wheel site they are staggered rears are et 18 and fronts are et 48
Neither is conducive to 3 Series E9X |
tcphoto3547.50 AWD Addict304.00 |
04-27-2022, 04:35 AM | #9 | |
Rep 20
No i dont have access to a set of et48 wheels, however i got tons of bmw sets laying at work so there might be actually one. Was more talking about tires |
04-27-2022, 04:36 AM | #10 |
Rep 20
04-28-2022, 03:19 AM | #12 |
Rep 20
04-28-2022, 11:48 AM | #13 |
Rep 20
Have done the pin delete on top of the strut tower, did not make a difference rubbing wise. it's steering way better tho!
Might try a lower & less wide tyre upfront. Now in the search of someone who's willing to roll my fenders. Already rubbed trough the fender liner after 400km's |
04-28-2022, 12:22 PM | #14 | |
2039
Rep 2,680
get m3 arms and adjust camber to max -1.3. this is not much and it will look fine while providing more grip in turns. no impact on tire wear. the second step is to decrease front tire to 235. After both mods are done you may still get some rubbing but it should tuck the top of the tire in the fender. the very last option is camber plates and -2.5-3 camber. |
04-28-2022, 12:40 PM | #15 | |
32
Rep 58
That's not considering cost, amount of work involved, alignment, etc. |
04-28-2022, 12:56 PM | #16 | ||
2039
Rep 2,680
fender roll is not a solution. you can either replace wheels or try those two mods. gl |
04-28-2022, 03:23 PM | #17 | |
Rep 20
I'm going to try some different tyres, only to find the correct size. I know for a fact there are tons of 225/40 or 35 tyres laying abouts, but that will stretch badly on a 9J rim. Keep you posted , or find a ET48 rim, and use some spacers. (wich i have no disbelieve in since i run 60mm on front axle on my project for already 2 years and not single wheel bearing let go) |
04-29-2022, 11:53 AM | #18 |
Rep 20
Big update!
9J et18 works with 225/35/19, no rubbing at all. It's quite stretched tho so i'm going to experiment with 235/35/19 tyres. Must clarify this on stock suspesion, so have no clue if it will fit when you lowered the car. |
05-14-2022, 10:32 AM | #20 | |
Rep 20
Been running it as daily now, 35 high on a 255 in the rear is a bit much, keeps me from.speeding over speedbumps tho |
07-05-2022, 02:31 PM | #22 | |
Rep 3,655
