PFC 08 and 11 track pads just released for the F2x 2 series |
07-16-2018, 09:35 PM | #24 |
Supreme Allied Commander
3886
Rep 54,519
Drives: F80 M3
08-09-2018, 06:08 PM | #26 |
3886
Rep 54,519
Drives: F80 M3
Proper Bedding Procedure for CarbonMetallic® Brake Pads
All PFC Brake Pads are pre-treated to be race and street ready. This treatment is done in the final step of the manufacturing process when the surface of the friction material is brought up to temperature in order to simulate a bedding cycle. However, proper bedding is still required using your rotors with the new CarbonMetallic® pads. The following process below is suggested in order to achieve the best performance, consistency and durability of the pad. STEP 1 Gradually get the PFC pads up to temperature. Do not spend a longer time on the brakes than usual because this can create a thermal shock condition within the compound. STEP 2 Perform several stops with progressively higher pedal pressure and braking force and from higher speeds. You will feel the effectiveness of the brakes increase with each successive brake apply. STEP 3 Continuing this procedure a few more times is the best way to accomplish the new transfer layer and, due to the higher surface temperatures, will assure a complete removal of the old friction materials from the disc. STEP 4 The disc should be allowed to cool as much as is practical, with ambient temperature being ideal. Allowing the disc to cool to ambient temperature will increase disc life and performance. STEP 5 The pads are now properly bedded to provide consistent performance. The pads should be brought back up to the operating temperature range to guarantee optimum braking power. This depends upon the specific compound. |
11-21-2018, 10:55 PM | #33 |
3886
Rep 54,519
Drives: F80 M3
Looking for PFC08 or PFC11 brake pads and live in Santa Barbara, Ventura or San Luis Obispo Counties? HP Autosport, Inc. is your local source.
We install everything we sell. www.hpashop.com |
02-16-2019, 11:33 PM | #38 |
3886
Rep 54,519
Drives: F80 M3
Looking Performance Friction Company brake pads and live in Santa Barbara, Ventura or San Luis Obispo Counties? HP Autosport, Inc. is your local source.
