Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > HID fog lights easy as pie and a cost of only $60.95
      01-17-2010, 12:51 PM   #89
kurizma
Drives: alpine white 335i coupe 6MT
2022 Telsa Y  [0.00]
2018 Audi Q5  [0.00]
2007 e92 335i  [8.50]
Installed the fogs yesterday with the 10000uf/25v caps. drove around for a couple hours and no flickering or codes.
I bought the caps from a local elecronics store here in santa clara for 1.40 each. hope i can return my radioshack ones.
now i need to switch out my headlights to 6000k. my 3000k fogs are overpowering them. they're really bright and look yellow/white but light up the ground very yellow.
2007 Alpine White 335i coupe 6MT premium/sports/navi
      01-17-2010, 01:58 PM   #90
ehssan_alkhiyami
I don't drive fast , i fly very low
ehssan_alkhiyami's Avatar
Germany
14
Drives: E60 M5 , F31 320D Xdrive
cool stuff .. at least we know now that the coupe require 10000uf caps ...thanks for the info ...
      01-17-2010, 10:01 PM   #91
ChiDiddy
50
ChiDiddy's Avatar
19
Drives: pop smoke
ok so clarify, how is everyone wiring in the caps? one in each wire?
      01-17-2010, 10:36 PM   #92
335iredline
14
Drives: BMW 335i E90
Good to know this is working out for you guys. Post pics of your set ups!!
      01-17-2010, 10:48 PM   #93
Kev
Critical Care Anesthesiologist
Kev's Avatar
Hong Kong
482
Drives: SMB F83
I hope you realize that by switching out to 6000K from stock color, you'll actually lose more light output and make your foglights even more over powering......
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist"
      01-18-2010, 09:41 AM   #94
335iredline
14
I think you might be a little confused because in no way fashion or form does a stock h11 (for E90) halogen bulb put out more than a 6000k HID bulb.
      01-18-2010, 10:41 AM   #95
200Duece
200Duece's Avatar
45
Drives: '73 2002,'18 X5 35d,'17 328d T
Maybe his low beams are 8000 or 10K???
1988 E28 535is Euro Conversion --- sold
2009 E90 335 6MT --- sold
2003 E39 540iT Msport --- sold
      01-18-2010, 12:38 PM   #96
Flea7
Flea7's Avatar
Drives: E92 M3 6MT/F48 X1/F430/F12
2016 X1  [0.00]
2008 E92 M3  [0.00]
2005 Ferrari F430  [0.00]
2014 Ferrari F12 Be ...  [10.00]
I think Kev is referring to the stock low beam HID bulb...I think which is @ 4300k.
but if you're running halogens .... then, yes you're right.
      01-18-2010, 01:21 PM   #97
kurizma
2022 Telsa Y  [0.00]
2018 Audi Q5  [0.00]
yeah, i know i'll lose light output. for some reason, the 3000k gives more of a white color when looking at the lights directly but outputs a very yellow color on the road. the white of the 3000k looks whiter than the stock headlight xenons. i dunno, maybe it's the cheap ebay HID kit i got. :\ i think a 5000k or 6000k will match it better. ideally, i want a 5000k bulb but can't find a reputable company that makes a d1s at 5000k.
      01-18-2010, 09:16 PM   #98
OwnAge
Gourik
OwnAge's Avatar
187
Drives: soon
2009 328i  [8.90]
i thought my kiit sucked when i installed it. Cause it was yellow on the ground but white inside the foglight.
I think HID 3000k are that way. However, the more i drive the less white i have now. May be the bulbs were new thats why it has that white light.
      01-20-2010, 08:45 AM   #99
blueaudi18
blueaudi18's Avatar
Drives: e92 08' 335i , mb sl500
will this work for hid angel eyes too? or is it just for fog lights
POSTED WITH APOLOGIES FOR POOR SPELLING, GRAMMAR AND SENTENCE STRUCTURE
      01-20-2010, 01:50 PM   #100
ksspacegray07
Drives: 335is coupe
interested in seeing this for angel eyes hid too!
      01-20-2010, 04:40 PM   #101
200Duece
200Duece's Avatar
45
Everyone should google search the Kelvin light scale. you'll under stand why you are seeing what your are seeing.
      01-21-2010, 08:35 AM   #102
335iredline
14
Not this exact scheme Ive already tried it
Stay tuned. Ive tried 2 setups and no bueno but trying one more this weekend. Ill keep you posted!
      01-22-2010, 11:22 AM   #103
200Duece
200Duece's Avatar
45
Funny side note,
I ordered a set of HID H8's ina kit from an ebay source. I was able to request a "special digital wire harness" to have them not throw a code with my higher end car. There was no extra charge. The Kit came yesterday afternoon and upon inspection of the "digital wire harness", it looks just like what 335redline has done with the capacitors. Looks to be a little smaller in size and it does have the clips all assembled so there is no soldering needed. I'll cut open the shrink wrap to see what rating the capacitor is and post a pic later.
And the whole kit was shipped in 3 days for $40 total
      01-22-2010, 07:23 PM   #104
200Duece
200Duece's Avatar
45
opened up the "digital harness" and found a 10000uf cap.
I tried the kit without the cap and it turned on and then would shut of and throw a foglamp code
I added the cap and it would flicker like 3 times and then stay off... no code
I double checked to make sure that I had the wires connected correctly and everything seemed to be correct all the neg was neg and the positive was positive.
I then swithched the pos and neg and "pop" the cap blew out. So it was right the first way. like I thought it was.
Does anyone think that the 10000uf cap is too much for my LCI E90 335? Should i swap in a cap with a smaller rating?
BTW the kit is a 35w12v kit with digital ballast.
      01-22-2010, 07:29 PM   #105
nyc3r
nyc3r's Avatar
Drives: E90
was the cap 25v or 35v? the op used 35v and another user used 25v, both work w/o error.
      01-22-2010, 07:43 PM   #106
200Duece
200Duece's Avatar
45
Here's a pic. I double checked and the arrow does point to the neg side. I'll have to try it all again later. I just wanted to make sure that using a larger than needed cap wasn't the problem
      01-23-2010, 10:42 PM   #107
200Duece
200Duece's Avatar
45
Everything works great. just gotta make sure that the kit is propperly hooked up to the negative(solid brown wire side on the BMW OE plug) all the way through with the black wire on the cap and then black to the neg on the ballast.
Only thing I modded about the kit was to fit the correct male plug ends to the cap "digital wire harness". This just eliminates like a foot of un-needed wire. Here is the kit I bought:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Ordered in H8 at 5000K with the special "digital wire harness" for free for my LCI E90
Color at 5000K is still a little more blue/purple than the OEM xenon.
      01-24-2010, 09:40 AM   #108
nyc3r
nyc3r's Avatar
Drives: E90
do you have picture of the changes you made to the plug? I just order these based on your recommandation. they better work
      01-25-2010, 12:53 PM   #109
200Duece
200Duece's Avatar
45
You are going to switch male plug ends I and II
I also removed the other wire from the rubber boot. I did not use this wire --- Blue arrow.
and just make sure that when you re assemble the plug head on the cap wire that the BLACK pin will connect to the BROWN on the BMW OE female plug
Last, after it is all ready, you must make sure that the black wire side of the cap harness connects to the NEGATIVE side ( or bottom in my pic) on the ballast.
      01-25-2010, 06:03 PM   #110
nyc3r
nyc3r's Avatar
Drives: E90
thanks for the picture, any reason you didn't plug the cap cable to the connect near bulb instead of directly to ballast? wouldn't that mean you don't have to swap plugs?
