03-24-2019, 10:33 PM | #1 |
Rep 42
Misfiring N55
Hey everybody, I just changed all the coils and plugs on my n55 due to misfiring. 2 done by a shop under extended warranty because of codes coming up and the other 4 done by me because car kept misfiring and they quoted $1,200 since warranty wouldn't cover them without codes. Now I'm still having misfiring problems (especially when giving applying throttle while shifted into higher gears) and occasional stumbles while idling (especially during cold starts).
My warranty is about to run out in 200 miles (I'm at 73.3k) and I want to make sure it isn't some major problem. Any ideas on what I could test out? Maybe checking the pressure coming out of the HPFP? Any help is greatly appreciated, thanks! |
03-25-2019, 03:49 AM | #2 | |
1086
Rep 2,361
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
blakeelkin12.00 |
03-25-2019, 04:05 AM | #3 | |
36
Rep 129
03-25-2019, 04:29 AM | #4 |
Rep 42
Changed the coils with the plugs, and definitely wouldn't pay that hahaha. I let them change the two plugs and coils that came up on the codes because it was covered under my extended warranty. I'll make sure to get all of that checked out, thanks! Any other tests I should have them run before my warranty ends in 200 miles?
03-25-2019, 04:34 AM | #5 |
Rep 42
Haha was just looking up if people got their turbo switched out because of that garage wastegate rattle. Any other symptoms that accompanied the turbo issue? Did you have a similar misfire around medium throttle while shifted into a higher gear? My car completely stumbles two or three times when giving it gas at highway speeds
03-25-2019, 09:51 AM | #6 |
76
Rep 323
Drives: 2013 BMW F30 N55 335ix 6mt
mine stumbles too. got new spark plugs gapped at .018 was better for a bit but it's back now at highway speeds. need help
blakeelkin12.00 |
03-25-2019, 01:31 PM | #7 |
Rep 42
13blk335ix75.50 |
03-25-2019, 02:33 PM | #8 |
Rep 5,385
Are these all OEM plugs and coils?
Any engine modifications?
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
03-25-2019, 05:29 PM | #10 |
Rep 10,286
blakeelkin, by any chance were you or the first shop able to identify any stored codes? When the engine misfires, its a fairly serious matter and codes are stored immediately.
Four systems may not perform correctly when the engine misfires: - Delivery of air - Delivery of fuel - Ignition - Wiring / how electrical signals are carried Spark and coils are the first item to check. There might be an air leak somewhere. At 73K miles, it's worthwhile to check the OEM charge pipe if it's still present. The next step would be to check fuel injectors. Bad injector can literally flood the cylinder. |
blakeelkin12.00 |
03-25-2019, 11:34 PM | #11 |
76
Rep 323
03-26-2019, 10:32 PM | #12 | |
Rep 42
03-26-2019, 10:39 PM | #13 |
Rep 42
I had found a good N54 sticky thread talking about all the main reasons the engine might be misfiring and all applies very well to the N55 aside from the intake valve carbon buildup.
Check it out here: https://www.e90post.com/forums/showthread.php?t=631829 Going to change injectors and let you know if that alleviates the issue. edit: also have you already changed coils? If you haven't that's most likely issue after plugs. Easy change too. Here's the same product as the BMW plugs made by Delphi just half the price and missing the BMW branding: https://www.fcpeuro.com/products/bmw...-12138616153-1 Last edited by blakeelkin; 03-26-2019 at 10:43 PM.. Reason: asking a question |
13blk335ix75.50 |
03-27-2019, 10:52 AM | #14 |
76
Rep 323
thanks will change coils next
03-27-2019, 11:23 AM | #15 |
36
Rep 59
So were any codes thrown and if so which ones? I had a misfire in cylinder 1 and it threw a code immediately. The misfire was due to a slightly over tightened spark plug.
03-27-2019, 01:31 PM | #16 |
76
Rep 323
no codes thrown. I have bm3 stage 1 and it's been happening ever since I installed it
03-27-2019, 01:33 PM | #17 |
76
Rep 323
I have a 2013 f30 n55 335ix 6mt. ER chargepipe, afe drop in air filter, wagner catless downpipe, bm3 stage 1 93 tune. NGK plugs gapped at .018.
03-27-2019, 02:01 PM | #18 |
Rep 529
Why did u gap them to 0.018 and are only running stage 1 tune? That tight of gap is reccomended only for high boost applications.
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
03-27-2019, 06:38 PM | #19 |
153
Rep 258
So... you'd want to disconnect the BM3 to see if the misfires stop, right? I don't think you need to remove it altogether, just unplug its connections to see if the problem goes away.
03-27-2019, 07:58 PM | #20 |
Rep 42
When I was changing coils I figured i had to take off the strut brace because the back two were clearly blocked but it was literally impossible to find the e-whatever socket to take it off (plus needing to buy new fasteners).
I figured out that you can simply unscrew the plastic cover over the back two coils (3 10mm on each end) and then wiggle it around to the right side of the engine under the strut brace. This gave me more than enough room to remove plugs and coils. |
03-27-2019, 08:01 PM | #21 | |
Rep 42
03-27-2019, 08:11 PM | #22 | |
Rep 42
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
bmw, f30, misfire, n55 |
