06-30-2012, 01:41 PM | #1 |
29
Rep 95
Adding footwell or ambiant lighting
Evening all,
I just been looking at a F30 which has foot well lights and led lighting inside the doors, can you add these to an existing car which doesn’t have this installed, i.e. is the cabling already there. Looks very good when all lit up. Any help would be appreciated. |
07-02-2012, 10:31 AM | #2 |
Rep 4,939
Drives: 340i MPPSK
I suspect if you ask the dealer if you can retrofit the ambient lighting, they would probably say no. That said, chances are that the wiring loom does have the necessary cables but that it's just the light sources (LED bulbs) that are missing. You might also find that the OBC needs a coding tweak.
Life is a state of mind |
