DS vs D driving M57
12-10-2017, 01:31 PM | #1 |
Rep 11
DS vs D driving M57
The temperatures here winter time varie around 0C (32F) to -20C (-4F).
So the temperatures in the engine also are lower for longer time and in tough - degrees we should cover the radiator to keep the engine in good operating temperature. Also the speeds here are basically 90-103 km/h (55-63 mph). It brings a thought to my head, that driving in SPORT-mode could be better to the engine? The M57 keeps 5th gear 2000RPM 97km/h (60mph) vs. DRIVE-mode 6th gear 1600RPM or less. Town-driving on Drive-mode the RPM-s are low and so the CBU problem might be faster to come? While the SPORT-mode revs the engine more, which helps the soot/carbon to leave the engine better? Could I be correct? |
12-10-2017, 01:49 PM | #2 |
Rep 1,502
Drives: F36 435xd
Hi there
Do you know what normal operation temperature is? I have an Awron display in mine and have changed the oil drain plug to one with a temp sensor. And I can see that my oil temp is around 60 degrees Celsius at ambient temp at 0-5 degrees Celsius and highway driving. I know the actual temp is a bit higher since the sensor is at the oil pan and will be cooled by the wind while driving. I just think it’s a bit low.....
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
12-10-2017, 02:38 PM | #3 | |
Rep 11
In the cartrige, where you have the temp. sensor, the oil temp. is probably lower, it is not in use there. |
12-12-2017, 08:12 AM | #5 |
Rep 3,555
I've measured oil and coolant temp before and they were within 1 or 2 deg C. I used iCarly though so not sure where in oil circuit that temp is measured. I run about 85-86C due to no EGR cooler.
12-12-2017, 11:23 AM | #6 |
Rep 1,502
Drives: F36 435xd
Coolant is at the normal 84-90 but the oil was at the max at 58-60 deg c on the way home today where I drove approx 110km in 2 deg c ambient temp.
Could be that the sensor is faulty then.....
Brgds
