06-11-2014, 12:48 PM | #67 |
Rep 938
I used the home made kit and it leaked. It also seemed to build up additional pressure since there wasn't anywhere for the fluid to go. Back to a rag. Works like a charm.
06-12-2014, 04:48 AM | #68 | |
40
Rep 292
Thank you for the part numbers and sharing. I needed this after coming from the track and saw all the fluid splashed for the first time. |
06-17-2014, 02:06 PM | #71 |
22
Rep 124
Drives: 2013 E92 M3 ZCP
Yes it does. The reservoir and cap are still the same design and allow for the power steering fluid to spill. I'm having the issue on my 2013 and will go with kaiv's solution as soon as I receive all the parts.
06-27-2014, 10:27 AM | #72 | |
_______
169
Rep 1,088
Just want to make sure I get the right adapter so I don't get stuck at the house with a car that can't go anywhere. Can you list the specific adapter or sizes. Thanks. |
06-27-2014, 12:18 PM | #73 | |
Smiling Politely
1381
Rep 29,118
I did this as well.
My last run at Fontana I found PS fluid in the little reservoir....it worked!
08-06-2014, 10:29 AM | #74 |
10
Rep 112
I tried the PS reservoir from the 1M in my E92 M3 track car and it doesn't work much better than the M3 reservoir. Still looking for a better solution.
Assimilator1594.00 |
08-06-2014, 12:41 PM | #75 |
Rep 923
If your willing to spend some money for an easy fix-
http://ind-distribution.com/ind/bran...ring-reservoir |
08-06-2014, 04:30 PM | #76 | |
Rep 1,388
Are they got damn joking?
E90 M3 Space/Fox/6MT
E92 335i BSM/Saddle/6MT - Sold |
08-06-2014, 06:57 PM | #77 | |
Havin' a blast!
125
Rep 4,847
I have the following on my car and it works great. Cost me only a few Hamilton's. Quote:
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
08-07-2014, 08:43 AM | #78 | |
Rep 1,388
I'd love that reservoir extension piece - but jesus tapdancing christ, six hundred sixty freaking dollars? Like.....WHY?
08-07-2014, 12:48 PM | #79 | ||
Havin' a blast!
125
Rep 4,847
As for 660, cuz 660 is like 6.60 for ballers? Similar to spending over a grand for those thin side view GTS mirrors...
08-11-2014, 09:32 AM | #80 |
Rep 1,388
One thing I never get used to is the M-tax, which takes the BMW tax and cranks it up to 11. It's the cross we must all bear.
08-13-2014, 10:40 AM | #82 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
I find that mine is saturated after one track event... I replace it each time. My thinking is that a fluid saturated sweat band is not the best thing to have hanging around my hot engine compartment.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
04-20-2015, 12:47 AM | #83 |
Rep 12,730
where could one of these be purchased? i'm not finding it online.
Instagram; @roastbeefmike
04-20-2015, 07:04 AM | #84 |
Rep 1,470
Atlanta BMW parts Dept.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
04-20-2015, 10:35 AM | #86 |
Rep 1
04-20-2015, 10:51 AM | #87 |
43
Rep 262
was thinking about getting that but someone said it doesn't have a filter inside like the OEM one. Have you encountered any issue with this setup?
2010 E92 SSII DCT, Akra Evo, ESS Tune, Performance Spolier &Splitter, Edition Side Markers, AD08R
04-23-2015, 08:23 PM | #88 |
Rep 1,470
I had an M6 bolt laying around to do this but it was the wrong pitch. What is the correct thread pitch?
Got it. M6x1.0 which is what I had. I just had to chase the threads with a tap first to clean out funk.
