02-01-2024, 11:58 PM | #1 |
Rep 1
2013 X1 E84 Using Excess Coolant?
My 2013 E84 had a low coolant alert in 2022. I topped it up with about 1L.
Regularly serviced since. Aircon + heating working fine. No other indications. Last 3 weeks, the low coolant alert has come on. I topped up with 2L. Alert re-appeared soon after. I'm aware tank capacity is approx. 7.5L, and have added 2.5L since the alert re-appeared. So in total, I have added 4.5L in the last 5 years of ownership, which overall seems reasonable. I have noticed that my E84 does not have the red marker float level in the coolant tank as other videos suggest? A few questions - 1. If I have added too much coolant, will this be detrimental? 2. If the alert appears again, I will definitely be taking the vehicle to the mechanic as this amount of coolant seems abnormal to be adding in a short period. What are the possible issues of X1's using more coolant than usual? 3. Are E84 X1's known to have these issues? Many thanks in advance. |
02-02-2024, 02:29 PM | #3 |
Rep 434
They are known for leaking radiators, all the x1's have the water pump issue, etc. The expansion tanks are prone to splitting at the seam and dribbling for a leak. They can all be hard to find. I think mine is leaking just a touch, but I can't see any trail.
02-05-2024, 08:03 AM | #4 | |
Rep 1,556
I was also worried that maybe I f'd up the OC/OFHG gasket when I changed it last year but I have no frothy badness in the oil...had been monitoring the fill cap but also juat changed the oil yeaterday. Never a drop of coolant on the garage floor either. So... the mystery is just something I live with and monitor.
- Jeff
bosstones' flickr |
02-05-2024, 12:38 PM | #5 |
Rep 67
patoss19, sorry to hear. Unfortunately coolant doesn't evaporate that fast, you're probably leaking from somewhere.
UV coolant dye is very useful to pinpoint the source of the issue. If possible, avoid driving the car until you can diagnose the problem. Also, do not try to repair the failed part, it must be replaced. To echo what the others said, unless you're pushing the car hard and/or overheating the engine, I'd suspect the following: -Cracked radiator/expansion tank -Leaking hoses/connections -Oil filter housing gasket failure You will likely have to take the under tray off the car to diagnose a leak (or take it to a shop). Best of luck |
02-05-2024, 12:57 PM | #6 | |
Rep 434
bosstones1191.50 |
02-06-2024, 08:51 PM | #7 |
Rep 1,556
Good point and same here. I remember the SA topping it off one time (while under warranty) and I asked him about it. He said that the techs probably had been doing it the whole time so I just never noticed.
- Jeff
bosstones' flickr |
04-24-2024, 02:37 PM | #8 |
Rep 13
I've experienced something similar. Driving home from a local business I got the Yellow then RED engine overheating warnings. Shut off car and inspected for leaks, steam, or other overheating signs. Waited 10 minutes, then proceeded. Repeat of above. Close enough to home to get to driveway. Had car towed to dealer where they diagnosed water pump failure and $3,500 to repair. Had it towed to independent where repair was done for $1,600. New water pump and t'stat installed. Driven a few local trips since. Coolant tank level is about 3/4" below filler neck when cold. Is this normal?
It appears I might be losing coolant but still no signs. Tank does not have probe stick to measure level, only a yellow disk. Any suggestions? |
05-09-2024, 12:25 PM | #9 | |
Rep 434
The only thing I can suggest is keep watching. I know a lot of guys don't fill fill the coolant as it tends to lead to the tank rupturing (common problem on these). How long ago did you have the stop do it? I would go back and tell them you've added coolant now and have them double check. The water bump uses these clip connectors and it's amazing to me they don't leak. |
