Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Not finding ABG module in NCS Dummy
      12-01-2019, 04:24 PM   #1
bimmerfan1972
bimmerfan1972's Avatar
95
Drives: 2011 BMW 335xi
Hi guys,
I'm trying to disable the seat belt warning chime in my 2011 E92. I have read out my ABG module, and in the FSW_PSW.TRC I see the two options that I need to change, SBR_FAHRER_1 and CC_GURTWARNUNG_1. Problem is, I don't see an option in NCS Dummy to load the ABG module. I am using Dummy 0.6.0.9. Do I need a different profile?
If I can't get this to work, can anyone tell me how to code this by just editing the FSW_PSW.man file? Do I just change the options to nicht_aktiv and copy the contents of the .trc file into the .man? Or is there something else I need to do?
Thanks
2011 BMW 335i xDrive E92 N55 Alpine White\M-Sport /BMS CAF/HPS CAI/VRSF 5" FMIC/VRSF CP/VRSF Inlet and Outlet/VRSF Catless DP/NGK 1-Step Colder Plugs/xHP Stage 1//MHD Stage 2+
      12-01-2019, 04:30 PM   #2
sdbmwcoding
Drives: BMW M3
Originally Posted by bimmerfan1972 View Post
Hi guys,
Thanks
You're most likely not choosing the correct module in NCS Dummy. But yes, in FSW trace just set the 2 lines to nicht aktiv. File > save as and save as Fsw_psw.man and then Sg_codieren back in ncs expert
      12-01-2019, 05:29 PM   #3
bimmerfan1972
95
That worked, thanks. Happen to know the setting for the passenger side? I saw it as this (SBR_BEIFAHRER_1) in a forum but my ABG did not have that setting. Or maybe I didn't need to code it out separately, but I don't have a passenger to test with right now.
      12-01-2019, 05:33 PM   #4
bimmerfan1972
95
Actually, I just read a description for CC_GURTWARNUNG_1. Looks like that might code the warning out altogether, for both driver and passenger. I'll have to check that next time I have a passenger.
