      05-01-2014, 09:23 AM   #1
mecheng03
mecheng03's Avatar
Drives: 135i
2008 BMW 135i  [0.00]
Looking for a mechanic in El Paso, TX
I'm moving to El Paso, TX with my out of warranty 135i and would like to know if there are any recommendations for a good BMW mechanic/shop in the area. I would like to stay away from the dealership if possible and I'll be on the East side of town. Also, I do plan on adding on an LSD and FMIC in the near future as well. Thanks for the help.
2008 135i MT
A22, LWAL, ZPP, ZSP, 322, 494, 507, 609, 653, 677, 6FL
MHD, ATM FMIC, ER Chargepipe, Forge DV, VRSF Downpipes, BMW Performance Suspension, RB PCV, CDV delete
      04-10-2015, 05:51 PM   #2
icabod7
icabod7's Avatar
Drives: 2008 135i Coupe
Reviving an old thread...
Interested in hearing recommendations for a mechanic in West Texas or around Las Cruces, New Mexico. I just moved from Dallas and was spoiled by the great service at Ultimate Bimmer Service.
Where do West Texas / El Paso folks take their bimmers to be serviced when they want quality work done?
cdv delete | clutch stop | bmw performance ssk | meisterschaft gt | berk mids | dinan cai | helix fmic | m3 subframe bushings, swaybar, front and back suspension bits | dinan stage 1 suspension | dinan cf strut brace |gc camber plates | dinan oil cooler | apex ec-7s w/PSSs | cobb stage 1 + fmic
      08-10-2016, 03:46 PM   #3
mecheng03
mecheng03's Avatar
Drives: 135i
I'll revive this post again. So I've used 3 locations since living in El Paso:
1. BMW El Paso: Expensive (which is to be expected) but the parts department is easy to work with. They replaced my battery and LPFP at a premium price...
2. GPS International Automotive: The owner Gerd is the man, does a great job and has been in business since the 1980's. My first year here they charged my AC for less than $40 with UV dye which would have been more $$$ anywhere else. I'm using them now to fix a job from the final group (see below)... He is very passionate about doing the job correctly which I'm all about. If I have anymore issues this will be my first stop from here on out. Negatives are that its basically a dirt plot with a small garage (main reason I switched initially to Moroni) and the time till completion is a little slower.
3. Moroni: A relatively new shop which opened in 2011 and I've used them about 4x now. First three were uneventful (wheel alignment, 60K service, diff/trans fluids) but my last (boost leak from vacc lines with not all replaced, OFH gasket/valve cover gasket, charged for broken bolts which in retrospect was from them) was pretty bad. I even took the car back 2 weeks later for valve cover bolts missing found when changing my spark plugs, my strut bars were finger tight/loose and other odds/ends were missing. When it was "fixed" the mechanic even left his tools in my engine bay after driving to the front for my inspection. After a persistent oil leak for 6 weeks Gerd later found that 2-3 more bolts were missing on the backside. Based on my 3 other encounters I think it was more of a jr mechanic w/o QA/QC oversight but I'm not going back. I guess a plus is their price was a lot cheaper though vs GPS: $650 +$300 broken bolts scam vs $1200.
Hope that helps.
2008 135i MT
