BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Low coolant temperature
      12-07-2016, 08:52 AM   #67
nicklockard
43
Drives: 2009 w/Nav; paddleshifters
Originally Posted by JTC1 View Post
Where is everyone ordering their Tstat from? I know someone in another thread said they ordered from Rock Auto. Is that a safe bet?
I think mine was from FCP Euro. Behr part.
      12-07-2016, 10:10 AM   #68
dmanb2b
Drives: G07, F97, F30, E90, E46, E30
OEM t-stat from ECS. Was about $60 shipped also ordered the 4 bolts, but to my surprise the old ones looked just fine. I replaced them anyway for piece of mind.
      12-07-2016, 10:17 AM   #69
_TB_
Drives: E91 325d Touring
Koed.dk
      12-07-2016, 12:01 PM   #70
TDIwyse
614
Drives: 2011 335d
My first online delivered thermostat had a hairline crack in the housing that extended under the gasket. I sent it back...
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods
      12-08-2016, 01:54 AM   #71
digitaldav
25
Drives: 2009 335d
Thats where I get all my parts from. Just got my Tstat from them last weekend.
      12-08-2016, 08:22 AM   #72
JTC1
36
Drives: 2011 335d
Which one did you order? I was looking at the Mahle.
      12-08-2016, 10:21 AM   #73
Hoooper
213
Drives: 335D
I used the Beck/Arnley one from rockauto. Still working correctly 2-ish years later which means its sadly at least as good as the OEM one
      12-09-2016, 01:39 AM   #74
digitaldav
25
Drives: 2009 335d
I too used the Beck/Arnley one from rockauto.
      01-20-2017, 09:51 AM   #75
vladmury
vladmury's Avatar
Denmark
101
Drives: 325d E90 LCI M-sport
Hi guys,On M57 325d I changed both thermostats Egr and main after car was warming up very fast ( in 5 km water was up to 80, after 9 km up to 90 and stable)
Now last days I was checking again and surprise after 15 km water rose from 11 to 60C , after 35 km water was at 82-84. This is not normal to warm up that slow.
I changed the egr stat but no change. I will replace main stat again( note the old one is also original bmw), doubt it will fail after 3 months. Besides that is there something else that will create a slow warmup?
      01-20-2017, 09:56 AM   #76
BB_cuda
BB_cuda's Avatar
767
Drives: 2011 335D Msport, 2013 X5D
Is your coolant system properly bled to get air out of system?
Out North American 335d don't have EGR thermostats by the way. Another consideration is your local weather temp but 35 km=21 miles sounds like a long way to warm up, I agree. My warm up is more like 4 miles=6.4 km but Houston much more warm than Denmark right now.
      01-20-2017, 11:56 AM   #77
mob17
mob17's Avatar
400
Drives: E92 335D
Originally Posted by TorqueAddict View Post
Originally Posted by TDIwyse View Post
As another data point... changed my thermostat this week. Previously the car would warm up to ~172-176F, unless in town stop and go driving, where it might get to mid 180's. New stat car warms up to ~186-190F. ......
I'm curious if those posting significant fuel economy benefits from changing their thermostat could describe their before/after coolant temps, and plot hand calculated mpg results over an extended period of time before/after their thermostat change? That would give some interesting comparison to see if the trend line significantly changes.
If your car was reaching 172-176 (77-80 C), your thermostat was most likely fine. All i could get my car to was 60-63, doesn't matter how'd i drive. No hand calculated MPG's but my tank with similar driving styles and routes used to last me ~570-650kms max. After the replacement, on winter fuel, i hit 780Kms on the tank, which is quite noticeable.
Now within 10-15 minutes of my drive to work the temperature rises to 80+ C easily, and car drives and behaves differently. Tranny is more smoother. I have been driving this car for over 4 years now - everyday. I can feel the difference in behavior. May be it never got out of warm up cycle ever (never in closed loop)
Another thing that i can relate to this is glow plug controller/glow plugs. Mine failed last winter, which caused me to monitor temperature. According to BMW training document, the glow plugs also work intermittently if your engine isn't warm enough - as a result low temps = overworked controller and plugs hence leading to failure.
My glow plug controller has failed i think. I get some rough starts when its cold. I haven't replaced it as i thought i have deleted my dpf that the glow plugs are then used just to start.
If i dont replace what could happen? Should i, as i dont have a dpf?
      01-20-2017, 03:02 PM   #78
vladmury
vladmury's Avatar
Denmark
101
Out North American 335d don't have EGT thermostats by the way. Another consideration is your local weather temp but 35 km=21 miles sounds like a long way to warm up, I agree. My warm up is more like 4 miles=6.4 km but Houston much more warm than Denmark right now.
After my last change of thermostats in October, I bleed the system and everything was ok. I did not monitored the temperature since December , now outside was -5 that morning could it be the reason for the slow warmup?
what is not normal is after temp reaches 88, if I slow down or drive moderately the temp strarts decreasing close to 82, before once it was up to 90 it will not move from there
      01-22-2017, 09:56 AM   #79
vladmury
vladmury's Avatar
Denmark
101
UPDATE; After main stat change, the coolant temp goes up to 96 and around 93-94 degrees C on highway. I have seen also 97 C at idle after a highway run.
Do you think 97 is too much? I had the impression it should stay at 90-91, now I am concerned that new thermostat might be bad as well aghhhhhw
      01-22-2017, 12:27 PM   #80
_TB_
97 is just fine.
      01-22-2017, 04:51 PM   #81
BB_cuda
BB_cuda's Avatar
767
Originally Posted by _TB_ View Post
97 is just fine.
Is your radiator fan cycling off and on? I was told fan should come on at 92C from trust worthy source. Once again, let the system self bleed by idling with reservoir cap off and heater running. This is about only time I recall getting fan to run. My system rarely breaks above 90C.
Please let us know if that 97 continues.
      01-23-2017, 02:26 AM   #82
_TB_
You can use the aux. pump to bleed the system - then you do not have to have the engine running
      01-23-2017, 04:02 AM   #83
Laursdahl
Denmark
22
Drives: E92 335D 2006
Hej.. Min gør nøjagtig det samme.. Læste et sted at grunden til bmw ikke har vand temp. i min bil er at den kan flytte sig en del og unødigt forvirre brugeren..
      01-23-2017, 10:39 AM   #84
BB_cuda
BB_cuda's Avatar
767
Lucky you for having that auxiliary pump. I'm not positive for all 3 production years that North America got the 335D but my 2011 didn't get this. I have seen my coolant hit 93C after driving on freeway and then come home and park in garage but car still running. It then slowly settled down to 85-86C range. To be clear, car was in 80s until I parked and radiator lost air flow and then went to 93C. I wonder if that T/S just needs to settle in. I do agree the 97C doesn't pose an issue but your fan will run more.
Hey look at it this way, you may get a longer T/S use interval than the rest of us as they all seem to slip down the slope of slowly but surely decreasing control point.
      01-24-2017, 07:29 AM   #85
vladmury
vladmury's Avatar
Denmark
101
Actually after first night I noticed the coolant level was on minimum, even if was filled and bleed the past day. I topped up to max and bleed the system once again. Now it stays at 91-92 stable. Actually the fan came on at 97 but I need to mention in the past there was never need for the fan as the temperatures did not reach 97 C. So I think the reason the engine ran hotter it was because of the lower coolant level.
If you think the temperatures of 82-86 degrees C is normal, this is bulshit. It should stay with original thermostats at 89-92 , in any case it should be over 89. And in max 10 km it should warm up to 80-85 no matter of the outside temperature.
      01-24-2017, 09:10 AM   #86
TorqueAddict
TorqueAddict's Avatar
171
Drives: 340i - 335D
These temps are possible on a 'stock' car. Deleted vehicles report lower temperatures due to the obvious reasons.
JR Auto tune and Bohl Diesel Downpipe - KWv2 coils - Apex Racing 18" EC7 wheels wrapped in Michelin PSS 245/275 F/R - Zimmerman cross drilled rotors F/R with Hawk HPS pads - SS brake lines - Motul RBF 600 - ADD W1 oil catch can - BMW performance CF spoiler
      01-24-2017, 11:22 AM   #87
BB_cuda
BB_cuda's Avatar
767
Sorry, I quoted my own experience. I don't have an EGR cooler so no heat from it comes into coolant system. From several conversations with stock guys, there is about a 3C difference when running down freeway at steady cruise.
      01-26-2017, 12:58 AM   #88
Yozh
Yozh's Avatar
870
Drives: 2011 335d M-Sport
There may be different thermostats. My OEM one that failed was stamped with 88C. And that seems to be the correct temperature most of our 335d run at. 325d may have a 89C or 92C thermostat, it may be a bit different.
