Official APEX Wheels Showroom Gallery Thread
07-05-2021, 06:54 AM | #1058 |
Rep 1,413
Throw me some opinions, please!
I just installed a squared set of EC-7Rs this past weekend — looks phenomenal! (And that weight difference from 18" 313s to these 17x9s? Omg!) anyways, I am at a block with what is shown below. I am going to double check the camber is set to -1 — but worst case scenario that it is: what size do y'all think? Ideally going to order between the 5mm and 12mm from apex. I'd also like to fill out the rear's fender. Any and all help is appreciated. Thank you!
See you, space cowboy.
Supercharged |
Biginboca3766.50 |
07-20-2021, 02:50 PM | #1059 |
154
Rep 215
Please advise on the fitment before I order. I want the most rear traction possible. Completely stock suspension e92.
SM-10 Front: 18x9 et 30 but which tire to go with? 235/40/18 --> too much stretch on a 18x9 rim. 255/35/18 --> might be the best choice? Or my preferred 245/40/18 due to bigger sidewall, but I have heard of these rubbing? Rear: 18x10 et33 with 275/35/18 PS4S I am open to doing a very slight fender roll and dial in -2 camber. Will this fit? Last edited by R3dLeader; 07-20-2021 at 02:57 PM.. |
07-20-2021, 03:24 PM | #1060 | |
3562
Rep 6,799
For a staggered setup with a 18x9" ET30 front and a 18x10" ET33 rear, I would recommend running 245/40-18 front and 275/35-18 rear tires. These sizes will be the closest in overall rolling diameters and you shouldn't have any rubbing with a 245/40-18 up front on stock suspension. In the rear, a 275/35-18 will typically require a rear fender roll to fit without rubbing under suspension compression. No fender pulling, etc will be required. If you have any additional questions, please do not hesitate to reach out. -Geirsen
07-30-2021, 08:27 AM | #1061 |
17
Rep 50
Haven't seen my exact setup to this point so figured I would share
EC-7 in race silver 18x8.5" sqaure 235/40 R18 Michelin Pilot Sport AS4 No suspension mods, no spacers, no nothing, just straight bolt-on replacements for my bent OEMs
@N52_e92 on Instagram
LCI 328i xDrive | 3-stage IM | AA catless headers | Turner Motorsport tune | 330i muffler retrofit | APEX EC-7 18x8.5 et35 square | Michelin PS A/S4 235/40-18 |
08-04-2021, 04:45 PM | #1063 | |
3562
Rep 6,799
APEX Flickr F30 Satin Black Image Search -Ian
08-08-2021, 10:41 AM | #1065 |
3767
Rep 2,738
Never posted these but they are ARC8 18x9 et30 up front with 5mm spacer and 18x10 et25 rear running 255/35r18 tires square. (Track alignment -3.5 front camber and -2.5 rear camber)
08-08-2021, 07:52 PM | #1066 |
Rep 48
I have a titanium silver 2008 e92 335i. I currently have a set of hyper silver apex arc-8's. I can't decide if I want to keep these or sell and purchase hyper black, anthracite, or black. What color looks best with silver exterior?
08-09-2021, 11:33 AM | #1067 |
Rep 809
08-09-2021, 03:54 PM | #1068 | |
3562
Rep 6,799
Anthracite or Black will give a bit more contrast and a more "aggressive" look. Hyper Black is always a good choice for when you can't decide between a light or dark finish! -Ian
The843N544.50 |
08-09-2021, 07:03 PM | #1069 |
Rep 1,772
Drives: Bmw 330i and Bmw 328i
Arc 8 18x9 rear 18x8.5 front.
08-13-2021, 06:56 AM | #1070 |
3767
Rep 2,738
One more shot of ARC8 Bronze fr 18x9et30 w/5mm spacer and rr 18x10 et25 and 255/35r18 square tires on track camber alignment fr -3.5 rr -2.5
09-18-2021, 08:28 PM | #1071 |
42
Rep 101
Small update, installed SPC rear camber arms and the KW V2's have settled.
Now running -3.0 camber in the rear and the previous rubbing has been minimized, funny only the passenger side rubs for the most part. Fenders are shaved. Would like to add a spacer upfront to even things out. Wheel specs: ARC-8 18x9 et 30 front // 18x10 et 25 rear - Matte Bronze Tire specs: Conti ExtremeContact Sport, 235/40/18 front // 275/35/18 rear Last edited by Technics_; 09-19-2021 at 09:17 PM.. |
09-18-2021, 08:52 PM | #1072 |
Rep 432
Sick stance, any accelerated inner tire wear with that camber?
09-28-2021, 09:29 PM | #1073 |
Rep 7
Apex Arc-8
First time posting, long time viewer of forum. Here is my current setup. After reading the recommended tire sizes I opted to try going a little meatier. Hoping to add more spacers in the rear to match the fronts.
Apex Arc-8 18x9 et30 square Stock suspension, 3mm spacers front, 8mm spacers rear BF Goodrich comp 2 A/S 255/40/18 |
Expert@ApexWheels3561.50 |
09-29-2021, 11:55 AM | #1074 | |
Rep 432
09-29-2021, 12:38 PM | #1075 |
Rep 7
A bit at full lock. I had to cut out a bit of the fender liner and remove the oil cooler vent. The tires rubbed the shock a little which is why I put the 3mm spacer up front. The rears still need a bit of work in order to add a larger spacer. I will be shaving the inner lip off and relocating the fender tab as a fender roll did not help very much.
09-29-2021, 12:59 PM | #1076 | |
Rep 432
09-29-2021, 01:33 PM | #1077 | |
3562
Rep 6,799
-Ian
09-30-2021, 11:20 AM | #1078 |
Rep 7
I had searched every page of the forums prior to going with 255/40 and decided to just pull the trigger and make it fit. I wanted to be square with a meatier look and I did not think the 35 would have the appearance I was hoping for. I have a bit more work to do but i believe Ill be able to shave the rears down and relocate the rear bumper tab to fit a 13mm spacer in the rear to match the fronts. Wish me luck! I will reply once I figure it all out.
