03-02-2008, 12:53 AM | #1 |
Rep 7,719
Why do higher end BMW's lower windows when doors are opened?
I've always wondered about this feature. It's not limited to BMWs, but other more expensive cars as well. When you open the door, the window lowers a little, then it raises up when the door is closed.
What's the purpose of this feature? |
03-02-2008, 01:03 AM | #3 |
Rep 518
The cars which donot have the window housing like the sedans usually do.
e.g. mid 90's lexus es, acura tl, etc when the door is closed the window takes the pressure so the window is lowered so that the window is saved from pressure |
03-02-2008, 01:04 AM | #4 |
Rep 7,719
03-02-2008, 01:07 AM | #5 |
Rep 7,719
This actually makes some sense, so this feature is to reduce the stress put on the windows. Thanks.
03-02-2008, 01:44 AM | #6 |
General
384
Rep 21,747
Drives: E92 335i TiAg/E46 323i TiAg
I found out the hard way. For some ODD reason, when closing my door, the window wasn't lowered... I think it raised itself... I probably hit my keyfob or something... Anyways, it wasn't lowered, and when I closed the door, it make a noise almost like something riccochet'd off my window.
07 E92 335i | TiAg | Step | Padl | Cmft | Alum Trm | PDC | Nav | Assist | Sat | Lthr | Prem | Sprt | Rear Splr | RDSport Quads | iPod | V1 | LT Refl | VS Clear Bra | OEM Lip | KWV2 | Mtec Sides | BBS LM-R
00 E46 323i | TiAg | 5sp | Sport | Roof | RDSport Cams | RDSport tune | RDSport Shift | Volk LE37 | M3 spoiler | PSS9 | SuperSprint | Brembo |
03-02-2008, 01:51 AM | #7 |
35
Rep 216
like rrg007 said its mostly done on coupes or 2drs mainly because the windows are large and isnt shrouded at the top by metal. Its bare glass. So in order for it to close it must lower a little to pass through the arch.
03-02-2008, 03:52 AM | #8 |
Rep 2,927
Drives: E60 530D M SPORT
mostely coupes and soft tops as they are frame less windows just glass the glass does look mre stronger than the normal window
03-02-2008, 10:14 AM | #11 |
Rep 3,132
Im not sure its really related to more expensive cars.... the mustang GT does the same thing.
2018 R35 GT-R Cicio800 | 2007 E92 335i - RB Turbos, TC Kline DA Coils, HPA M3 Suspension, Quaife LSD, Stoptech BBK, JB4, FuelIT, AR Downpipes, RDSport Quads, Stett OC, Helix IC, Volk TE-37, Vorsteiner V-35, OSS Headlights | Retired - 2015 F82 M4
03-03-2008, 08:06 AM | #12 |
Rep 502
Does the 3er coupe do this also? I should have paid more attention when I test drove it.
see ya
06 325i. IT'S HERE!- 08 E92 328xi, Premium, Auto, Cold- Montego Blue |
03-03-2008, 10:48 AM | #13 |
Rep 1,118
Drives: 2009 E89 Z4
Yep, just on coupes and convertibles. First time I experienced this was on a 350Z back in '03
Z4 sdrive30i | Deep Sea Blue | Ivory White Nappa Extended Leather | ZSP |
03-03-2008, 11:18 AM | #14 |
Rep 4,320
Drives: '07 Z4 M Coupe
yes it does
03-03-2008, 08:49 PM | #15 |
Rep 17,304
as others have said, its because the weather stripping is not connected to the tops of the windows as opposed to on sedans. the closing action simply ensures a snug fit under the stripping. and as far as having that feature on higher end makes and models, my 97 328is does it every time
edit: plus coupe windows are generally a lot bigger than those on sedans, idk what thats has to do with anything. just throwing it out lol |
03-03-2008, 11:03 PM | #16 |
Blue Force Tracker
124
Rep 1,372
My G37 does it too. My old G35 did it but my 04 Mustang GT didn't so that must be something that domestics switched over to later on
Stay safe 855th MP Company! Hosmer/Espinoza you're my boys!! |
03-04-2008, 12:13 AM | #17 |
Rep 1,714
And it helps prevent from compressing the air in the cabin......reducing the stress on your eardrums.
I'm serious. Get in an older car, slam the door and note the effect on your ears. |
03-04-2008, 09:09 AM | #18 |
142
Rep 2,900
This really does go back a ways. My friends '91 or '92 Integra did this.
03-04-2008, 06:53 PM | #19 |
Moderator
497
Rep 27,441
it's done on coupes. i know for bmw, this at least dates back to the e36.
03-12-2008, 10:31 PM | #21 |
chris
278
Rep 12,144
think a lot of cabrios and coupes have this feature... its not very uncommon... it's a great idea to solve an old problem.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
03-14-2008, 06:34 PM | #22 |
Rep 530
I have a two-door which doesn't have this feature, and when someone slams the door or the trunk while I'm in the car, I can feel the air pressure on my ear drums. I think that's one reason for the feature. Another is that it takes a bit more to close the trunk (mine's connected to the cabin, like a hatchback), because of the air getting compressed. I have to push it all the way down until it latches.
