European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      06-24-2018, 05:18 PM   #155
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Originally Posted by paliknight View Post
Sorry for the amateurish question, but with the F8X factory CCBs, all parts are carbon ceramic, right? Including the calipers?
Also, if you could get the entire set of CCBs for 10k, why would anyone pay 4500 for a rotor?
Only the rotors are ceramic. The calipers are some sort of alloy(probably with ceramic pistons) and ceramic brake pads.
Sure... IF you have need new rotors the "kit" might be the way to go for a measly $1K more.
Dack
      06-24-2018, 11:45 PM   #156
paliknight
fuck this field
paliknight's Avatar
Drives: 18 F80 CS/18 F80 ZCP/19 M2C
Dack
Oh I see. But the 10k is for all 4 brakes lol in the set/kit. The rotor is 4500 each then pads are 600 each so you're looking at either 18-20k to replace all 4 rotors and pads or 10k for the entire thing and "free" calipers. Or am I missing something? Seems strange.
BMW family... for now.
Dackelone10588.50
      06-25-2018, 07:22 AM   #157
CanAutM3
General
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
Not sure where your $10k for the CCB retrofit comes from, but in Canada, it retails for C$19,300.00. The kit is still cheaper than replacing the rotors and pads at the 4 corners and you do get new calipers for free .
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
Dackelone10588.50
      06-26-2018, 12:31 PM   #158
paliknight
fuck this field
paliknight's Avatar
The Full Kit (front and rear) is 10k here:
https://www.bmwpartspros.com/partloc...90&startrow=31
      06-26-2018, 01:33 PM   #159
CanAutM3
General
CanAutM3's Avatar
21117
That's amazingly cheap. The best way to replace CCB rotors for existing CCB owners IMO.
      06-26-2018, 02:25 PM   #160
paliknight
fuck this field
paliknight's Avatar
https://www.bmwpartspros.com/partloc...38;startrow=31
That's what threw me off a bit. Owners were saying how it cost them 17k or so to replace just pads and rotors when you can get everything and free calipers for almost half that lol
CanAutM321116.50
      06-27-2018, 12:45 PM   #161
spr
Drives: F80 M3; e92 ESS650+ M3
FYI, that isn't a full retrofit kit. It doesn't include the booster and all the stuff. See here:
https://www.ecstuning.com/b-genuine-...t/34112358378/
F80 M3 HRE FF04 275/305.
Dackelone10588.50
      10-20-2021, 04:31 PM   #162
Uzr133
Drives: BMW M2 Comp
... With track use, the CCB seem to wear out pretty fast, almost at the same rate as iron rotors (some reported even faster). ...
The issue is heat. Heat, beyond a certain point (which no-one seems to quantify) causes the carbon fibers to oxidize (causing them to weigh less) and lose strength.
So, with CCB rotors, there should be a massive payback for brake-cooling ducts that can keep the rotors "properly" cooled. The problem is that I've not seen what would constitute "properly" ... but it's a given that cooler means longer life, all other things being equal.
      10-20-2021, 04:43 PM   #163
Uzr133
Drives: BMW M2 Comp
Originally Posted by evanevery View Post
... I should also say, that a very well informed BMW Engineer in Munich also told me that if the rotors were even the slightest bit above "done", then you can put them through a whole new set of pads. IOW: They only checked the rotors when changing pads, and if the rotors weren't done, then they weren't done! (So you might get THREE sets of pads if you played it by the numbers...) ...
So that sort of says that there's a significant safety margin designed into the CCB rotors and/or their wear specs.
... He also confirmed that the CCB rotors do not fail dramatically if taken below mins, they just gradually lose stopping power...
Wow, that's a (positive) biggie. Still, it only makes me feel a little better because everything else I've read implies that CCB rotors can (and likely will) fail catastrophically if pushed past their specified wear limits.
      10-20-2021, 04:58 PM   #164
Uzr133
Drives: BMW M2 Comp
Originally Posted by lemetier View Post
... That's the number one problem. Hell, I can wear out an MCCB rotor in ZERO miles/KM. Stick it in a 500C oven for 30 mins and nothing but a ceramic shell with a ton of little holes will remain. Let it cool then flick it with a finger. It will shatter into pieces. In one of the other threads, I quoted the engineer responsible for MCCB figure of 600C as the initial oxidation point. I now have a document from SGL/BMW that states it's in fact only 500C as there are two different types of fiber used in the chop material. The fibers are recycled from BMW and Boeing manufacturing waste and it is the BMW trimmings that are lower temp. ...
So, if that's true, this person's CCB rotors should disintegrate any time, now ...
This car has TiKT brake-cooling ducts and the front rotor temps are overlaid onto this video. Lap after lap, the car drops 200+ kph (125 mph) under heavy braking. The brakes hit over 800 deg C and are over 500 deg C for a significant portion of the time. Apparently, the pads are a special RSC formulation that they have worked with Pagid to develop.
      10-20-2021, 05:31 PM   #165
CanAutM3
General
CanAutM3's Avatar
21117
You realize you are replying to a 5+ year old post?
      10-20-2021, 05:51 PM   #166
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
No.
The disc type on the AMG GT R Pro is different than the Gen 1 MCCB. I couldn't have been more clear. Neglecting to utilize all the info provided…thats on you.
The discs on the car in the video you used have a higher percentage of carbon and have a longer oxidation life. The temp boundaries are the same however, and rather obvious by simply observing the color change at the respective temperature points. TBH, it appears to have too much airflow to the discs.
CanAutM321116.50
      10-20-2021, 05:52 PM   #167
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Its like running into an ex who insists on giving you a handy in the bathroom for old time sake.
CanAutM321116.50
      10-29-2021, 12:43 PM   #168
TomsM4
Drives: BMW M4, 2018
If you take your car to the track your CCB pads will evaporate at the rate of 1-2 mm/track day. I also somehow got a chip in one of my rotors and was told it was damage not due to wear and was not covered under warranty. The price for new front rotors alone: $11,000. I switched to girodisks all around for about 3K. Anyone need a set of rear CCB rotors and pads?
      12-03-2021, 03:47 PM   #169
elsixto
Drives: M4 CS edition, X3 F25 35D
I am delighted with my carboceramic brakes
      01-11-2023, 04:48 AM   #170
Maya_88
Drives: BMW M3
I drive also tracks with my CCB and were on 50 %, I have made them refurbished. Same as new.
      02-06-2023, 04:11 AM   #171
Hide-F80M3
Drives: BMW F80 M3
Anybody who replace rotors?
Hello, considering the cost of new CCBs
Someone replace steel roters instead of Carbons
The other type of BMW performance big rotor kit is consist of steel rotors
It seems that calipers are the same as CCBs, maybe not the pads as CCBs
If there is someone do this with steel ones. please let me know
how much would be the cost difference.
Regards,
      05-25-2023, 02:04 PM   #172
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Drives: OG M2 • Exige
Regards,
The CCB rotors are currently about $3800 USD each, so most either buy what they need used off of eBay, or a full kit from getbmwparts.com for $12,600 USD, and sell the gold calipers to mitigate the cost.
The CCB package uses the same caliper as the ///M Performance package/M2C/M2CS.
      06-02-2023, 10:42 AM   #173
rhyary
rhyary's Avatar
Drives: 2013 M3
For those who prefer to keep their CCB (carbon ceramic brakes) and want to avoid converting to steel or buying new, there is a happy medium: refurbishing the ones you already have.
If you're considering the CCB option when purchasing a new car, keep in mind that the option below can reduce your cost of CCB ownership.
The option is refurbishment. There is a wealth of scientific knowledge behind carbon ceramic brakes, and there are many compelling reasons to own this technology. The main concerns are cost and wheel size. If anyone is interested, please send me a direct message. Additionally, feel free to subscribe to my dedicated Carbon Ceramic Brakes Facebook group, where I provide a wealth of information.
I hope to hear from you soon.
      06-02-2023, 10:47 AM   #174
rhyary
rhyary's Avatar
Drives: 2013 M3
Link to Facebook ccb group
https://m.facebook.com/groups/296265...ibextid=zoDNOU
      08-04-2023, 12:53 PM   #175
rhyary
rhyary's Avatar
Drives: 2013 M3
The usa site is now up.
Visit rebrakeusa for information
f80post
