European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      01-05-2016, 12:16 AM   #45
Status Gruppe MNF
Status Gruppe MNF's Avatar
220
Drives: 03.5 M3 / 2015 M3 Individual
Our Coilovers are now instock.
More info here
http://www.statusgruppe.com/collecti...s-coilover-kit
      01-05-2016, 12:42 AM   #46
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
More info here
Thanks. Updated!
      01-05-2016, 05:45 AM   #47
M3SQRD
M3SQRD's Avatar
2161
MCS offers their one-way non-remote reservoir (1WNR), two-way non-remote reservoir (2WNR), and two- (2WR), and, three-way (3WR) remote reservoir dampers for the F8x M3/M4.
I'm installing their 2WNR damper with GC 5-bolt camber plates and F/R 450/750 lbf/in springs.
      01-05-2016, 03:41 PM   #48
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
Any links with more information?
      01-06-2016, 07:11 AM   #49
M3SQRD
M3SQRD's Avatar
2161
http://www.motioncontrolsuspension.com
      01-06-2016, 11:47 AM   #50
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
Yeah. Thanks for the link. I already went through the obvious routes for more info.
I want to see specific info on the F8X kits from MCS. Since you've purchased a set, care to share where you got it from and where others can get more information about that specific kit? What dealer did you go through? Are there any retailers selling them from their catalog yet? Etc.
      01-06-2016, 02:18 PM   #51
M3SQRD
M3SQRD's Avatar
2161
The MCS damper line, similar to Ohlins TTX damper line, is more of a custom build and spec'd based on your particular needs; e.g., street, track, dual-purpose or race setup. I worked with BimmerWorld to spec and assemble my set of MCS 2WNR dampers + GC camber plates for my dual-purpose needs. BW is available to answer all of your questions on suspension options (before and even after purchase) and to help make sure you've selected the right damper and spring rates for your needs.
      01-06-2016, 04:59 PM   #52
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
Thank you. Master list updated with information on MCS 2-way and 3-dampers.
      01-15-2016, 04:08 PM   #53
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
Spring Rate Conversion added.
      01-16-2016, 07:45 AM   #54
M3SQRD
M3SQRD's Avatar
2161
FYI, spring rates are also listed in N/mm (e.g., Ohlins R&D kits):
lbf/in = 0.2284*25.4 N/mm
kg/mm = 1/9.81 N/mm
      01-17-2016, 09:00 AM   #55
Amgeater2
Drives: X6M, M8, Mc 600LT, 296GTB
Adjustable kit just like the KW HAS and the Dinan, but they come with camber plate, adjustable sway bar end links, and you can choose the spring rate at check out. IMO far superior than KW HAS and Dinan.
http://www.ground-control-store.com/.../II=981/CA=295
      01-17-2016, 10:47 AM   #56
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
I used this kit on my E92 M3 for a few years and had great expeririences with it. Going to use this on my YMB beauty as well.
      01-18-2016, 01:12 PM   #57
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
Thanks for the info. I added this to the list.
      01-18-2016, 01:58 PM   #58
Amgeater2
Thank you for creating such of Great List !! party0030:
      01-19-2016, 05:05 PM   #59
mshab356
Go ///M or go home
mshab356's Avatar
Drives: 2015 F80 M3 6MT
Originally Posted by DiscoWagon View Post
Very nice and complete list, this should be a sticky!
What made you skip the E9x series M3?
2015 AB/SO F80 M3 6MT | 19" Black M437 | KW H.A.S. | AutoTechnik Black Front Grills | BMW Performance Side Grills | Painted Front Bumper Reflectors | Gloss Black Exhaust Tips
GONE 2011 SG/Blk E92 M3 CS 6MT
      01-19-2016, 11:54 PM   #60
O3DigitalBath
Drives: M3
I think it should be noted that a number of other companies offer custom setups (Moton, BC Racing...etc). Also that while they both may offer custom spec'd stuff the MCS and Ohlins products couldn't be more opposite from each other (monotube vs twintube).
      01-20-2016, 04:08 PM   #61
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
Thanks for your input. I hope you find this thread useful.
When starting this thread, I was careful to choose what information I was going to display. Sure, there are people who are absolute suspension geeks (like me). But there are also people just looking for a list of what's out there. If I don't choose which info to display, the list could turn into an exhaustive post of information.
In regards to putting up information that is specific to each kit, I've tried to just address what I thought would be common inquires (also information that is easy for me to find). I figure that if a person needs/wants more information from that point on, they can do their own research from there.
More often than not, the people who would like to know about monotube vs twintube would also like to know individual spring rates, piston travel, piston thickness, viscosity performance, inverted shocks, 2-way adjustable, 3-way adjustable, true coilover over rears, camber plates, what kind of joints, bearings, thrust sheets, perch on body or preloaded... the list goes on and on. These are most likely the people that would do the research on their own anyways. As much as I'd love to know every detail of each kit, I can't do all the research myself to post.
Some members have been kind enough to post replies with more specific information. I've also tried to link each kit to a thread that discusses that very kit in more detail.
So for the sake of simplicity, I'm just going to keep the OP as a "list" with a little bit of information.
      01-21-2016, 01:15 PM   #62
O3DigitalBath
Drives: M3
Completely understand, I was simply pointing out that comparing those 2 products isn't ideal as they are fundamentally different in most ways.
Great thread with tons of information!
      01-21-2016, 02:46 PM   #63
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
Apologies. I got a flag notification and for some reason I thought your post was directed to me. Thanks for your clarification.
      01-21-2016, 03:08 PM   #64
Amgeater2
I want to Personally give a BIG Thank you to our member EXO for creating such a great Thread that its now a Sticky !!!
      01-22-2016, 08:48 PM   #65
M3SQRD
M3SQRD's Avatar
2161
My point wasn't to compare damper internals - ''TTX' was used to differentiate between Ohlins TTX and R&T lines. Also, I wouldn't compare BC with Moton, JRZ, Ohlins, MCS, etc.
      01-26-2016, 01:23 PM   #66
O3DigitalBath
Drives: M3
The whole point is whatever I guess, my point was just that it wasn't the most ideal comparison so so much is different between them besides some ordering options.
...and you're right, I would break the brands you just mentioned into 3 groups but i'm sure our opinions of each and their lines vary pretty drastically. Regardless that isn't really a conversation for this thread.
coilovers, sleeve kit, springs, suspension
f80post
