03-12-2019, 03:28 PM | #45 |
18
Rep 46
Just installed eibach euro v1 to zcp m3 today. front looks great but rear looks like little be higher than I thought. I have about 1" gap right now.. is that normal ? or do I needs time to settles down to get right high..?
03-12-2019, 04:28 PM | #46 |
102
Rep 352
Did you change both front and rear to V1 springs? Please send pic. They will def go lower a bit after settling.
03-24-2019, 05:35 PM | #47 |
Rep 1,030
Car looks great with the Eibach V1s! That's exactly what I'm looking for, but why is it some people complain the rear goes up and for some its perfect? Also, how do the Eibach V1 handle larger bumps? Does the car ever getting jarring? I'm lowered on Swift now and the ride is perfect 90% of the time, but for larger bumps and things like that I am not as happy with the ride or stiffness. Thanks for any help!
JD |
06-07-2019, 10:39 PM | #48 |
196
Rep 277
What's even more confusing is that this guy put V2 springs on the front only and the wheel gap on the front looks the same as the V1 drop listed in this thread by OP. Maybe OP you got a bad set of V2 springs with different specs?
https://f80.bimmerpost.com/forums/sh...postcount=1081 |
06-08-2019, 09:46 AM | #49 | |
Rep 468
2015 F80 M3 - Yas Blue, Silverstone Full., Bilstein B6 shocks, Eibach Springs, Full M Performance Carbon Add-ons, Titan 7 Wheels.
(past) 2012 E92 M3 - Melbourne Red - Eibach Springs/AG M359/ performance spoiler/ performance splitters/10mm spacers, Macht Schnell Test Pipes, Alpine Stage 2 Tune. |
06-21-2019, 10:01 AM | #50 |
Rep 3,661
Did you need the spring compression tool or is it just unbolting and bolting stuff back? I remember on the E46 M3 it was a PITA.
2016 F80 M3 AW/SO (Manual) - Picked up at the Welt 08/28/15 My Amazing European Delivery Story |
07-01-2019, 08:38 PM | #51 |
3237
Rep 2,160
07-03-2019, 09:16 AM | #52 | |
Rep 613
Drives: F87 M2 CS
I've had lowering springs/coilovers installed on a few previous cars and this is the most outrageous install pricing I've ever experienced. It's enough to prevent me from bothering with it.
Current: F87 M2CS - 6MT | Öhlins R&T | Garagistic Endlinks | Autosolutions SSK | AA EL Midpipe & Axleback | 255/275 PS4S
Gone: F87 M2C - 6MT | Öhlins R&T | G.C. Camber Plates | Autosolutions SSK | UCP | AA EL Midpipe & Axleback | Apex EC-7 | 265/295 PS4S |
07-03-2019, 10:47 AM | #53 |
I'm Batman!
3948
Rep 1,477
Those ^^^ prices are simply absurd. It took me about 3 hours with no lift and I had to reposition the car for every corner because of limited space. This was also the first time doing anything on an F80 so I wasn't familiar with it. A shop with a lift could do it in an hour or so. There are 3 nuts/ bolts to remove at the front and only 2 in the rear. $1700
If you were closer I'd help you out |
07-05-2019, 08:40 AM | #54 | |
Rep 3,806
07-06-2019, 03:11 PM | #55 | ||
Rep 613
Drives: F87 M2 CS
I've been getting recommendations for other good shops around my area. Hoping to get a few more quotes this week then order the springs. Quote:
1) Do you have a link to where you ordered the V1 Euospec springs from? 2) Do you have a particular install guide that you followed? I'm not hesitant to do a spring install, as I've done it myself on a few cars. And hearing that I don't even need to bother with a spring compressor is amazing, since that's always the worst part. The reason I have been planning on paying a shop to do it is because in the DIY tutorials I've seen, they all seem to make it sound much more labor intensive than you've indicated. Like this one...
Gone: F87 M2C - 6MT | Öhlins R&T | G.C. Camber Plates | Autosolutions SSK | UCP | AA EL Midpipe & Axleback | Apex EC-7 | 265/295 PS4S Last edited by DadVibes; 07-08-2019 at 02:08 PM.. |
07-09-2019, 03:25 PM | #56 |
Rep 613
Drives: F87 M2 CS
Thanks to your recommendation, I ended up ordering some Eibach v1's (E10-20-031-09-22). They should be here early next week with install set for next Thursday.
08-05-2019, 06:17 PM | #57 |
Rep 851
My V1's arrived from Europe as well! I am considering just installing the fronts on my M3 CS. Pics to follow hopefully by next week
2018 M3CS - Alpine White
2016 BMW M4 - Vorsteiner | Michelin MPSS | Dinan | Swift | M Performance Carbon Everything (Garage Queen) 2016 VW GTI - Unitronic Stage 1 Tune | AWE Track Edition Exhaust (Daily Driver) |
08-07-2019, 04:40 PM | #58 | |
Rep 613
Drives: F87 M2 CS
Before: After: (post alignment and over 400 miles driven) [/url] Before: After:
01-09-2020, 08:36 PM | #59 |
Rep 897
Is there anything that can go wrong of affect long term wear/tear if o choose to lower just the front? I also feel like rear is good enough.
More scraping or so because of the increased rake? Not really I guess? |
01-10-2020, 07:58 AM | #60 |
Rep 464
It's not an aggressive drop anyway but the handling characteristics can change because of the increased rake, more weight is moved to the front this way.
Instagram:catpupu_f80 |
01-10-2020, 09:11 AM | #61 | |
Rep 897
01-11-2020, 02:35 PM | #62 |
9
Rep 22
I drove around with the zcp rear and eibach v1 front for about a month. I like how it drove in all modes (C, S, S+). Still feels like how a sports car should. But, the rake looked weird to me.
Just installed the eibach v1 rear last week (looks much better since it leveled out)... the drive def feels softer in a good way. I feel like the sport mode feels like a notch between comfort and sport... the ZCP springs is def stiffer ride than eibach V1. Im not sure if I like the softer ride with the V1 though... I love the look, but I find in comfort is just to soft and prefer to drive around in sports mode. I guess comfort is now "wife mode" whereas, comfort was to jarring for her with ZCP. Will see how this plays out it the coming months. |
01-12-2020, 02:55 PM | #63 | |
Rep 1,665
Nobody is spinning out of control driving their improperly lowered cars and, frankly, none of us are that good of a driver to even be able to notice the slight difference in handling balance. |
04-06-2020, 06:18 PM | #66 |
166
Rep 276
The drop looks perfect... Very very balanced from front to back.
It's appears you will not have any issues around town or daily driving what so ever. Keep us posted on the long term drivability and if you face any issues. |
