R44 Performance
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      03-28-2024, 03:07 PM   #1
NORAGRETS
NORAGRETS's Avatar
444
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
Bump stop DIY
Anyone have a bump stop diy to share or is it legit the same as replacing the springs and struts?
2017 F80 ZCP BSM - Klein Innovation. ActiveAutowerkes. AR Design. BootMod3 Paul Johnson. EvRw. Project Gamma. RW Carbon. UCP. UUC. Hawk. Dinan. NGK. Macht Schnell. TMS. VR. aFe.
RIP - E82 135i - 7/7/2021
      03-28-2024, 05:13 PM   #2
FaRKle!
Front or rear?
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      03-28-2024, 05:17 PM   #3
M3SQRD
M3SQRD's Avatar
2164
It’s a simple process. The ID of the bump stop should match the OD of the strut/shock piston rod. Once the strut has been removed from its upper (strut tower) and lower mounts (knuckle), the springs are compressed and removed from the struts. Now you slide the old bump stops up and off of the piston rod and then install the new bump stop by pushing it down the piston rod. Similarly, for the rear, once the shock has been removed from its upper and lower rear mounts, you slide off the old bump stop and then push the new bump stop down the piston rod. If this is for the oem suspension then I believe you’ll have to remove the old bump stops from the dust shields and install the new bump stops into the dust shields before sliding the new bump stop-dust shield onto the struts/shocks. New bump stops installed. You’re done!
NORAGRETS444.00
      03-28-2024, 05:18 PM   #4
NORAGRETS
NORAGRETS's Avatar
444
Originally Posted by FaRKle! View Post
Front or rear?
Rear
      03-28-2024, 05:47 PM   #5
FaRKle!
Originally Posted by NORAGRETS View Post
Rear
Jump to rear damper removal/disassembly/overview section. Also take note of the tools overview at the beginning.
Originally Posted by Index
0:00 Intro
0:21 Tools overview
2:23 Engine bay parts removal/loosening
4:22 Removing the wheels
4:47 Front wheel well components removal
7:22 Removing the front spring and strut
7:57 Front spring components overview
8:25 Front strut/spring unit assembly
10:13 Front strut/spring assembly installation
11:42 Front wheel well components installation
13:31 Securing things in the engine bay
15:03 Rear headlight levelling sensor notes
15:36 Rear damper removal
16:31 Rear spring removal
17:47 Rear spring overview
19:14 Rear damper unit disassembly
20:53 Rear damper components overview
22:02 Rear damper unit assembly
23:09 Rear spring installation
24:03 Rear damper installation
24:52 Camber arm and components securing
26:52 Wheels installation
NORAGRETS444.00
      03-28-2024, 06:20 PM   #6
NORAGRETS
NORAGRETS's Avatar
444
      03-28-2024, 06:25 PM   #7
NORAGRETS
NORAGRETS's Avatar
444
Thank you, thank you.
OEM bump stops come with the plastic dust shields in case anyone is considering doing this too. Only need to purchase part number 31337847662.
f80post
