Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > CalWaterboy's EXCELLENT New Year - E93 Suspension DIY
      07-27-2012, 06:38 PM   #45
Crunch
Drives: 335D
Cal,
As noted by others, incredible write up! I've seen many, but this is one of the best.
Can I ask what was the key to reducing your brake grab? I've found this to be entirely annoying on my E9.
Thx,
Andy
      09-01-2012, 11:53 AM   #46
CALWATERBOY
CALWATERBOY's Avatar
146
Drives: 2009 E93 N54
Sorry for the late reply!
Tire pressure to BMW recommendation, alignment & ride height did it, but judicious foot pressure is needed.
      11-07-2012, 12:33 PM   #47
left123
left123's Avatar
56
Drives: TiAg 330i 6MT ZSP
Perhaps I missed it, but if not, we need to get this in the DIY section for suspension. Not sure how to make that happen but mods, if you see this, copy it over there.
      05-04-2013, 04:44 AM   #48
chiefsotos
chiefsotos's Avatar
42
Drives: BMW 335 E93
what about the bushing parts for the m3 e93 sway. I mean they are the same with the m3 e92 rear sway, so how do they fit? (because m3 e93 rear sway is 3,5mm thicker than the m3 e92)
      05-04-2013, 04:56 AM   #49
#Tee
#Tee's Avatar
560
Drives: yes
bump for a GREAT contribution!
You can follow my builds on IG: Tee212
      05-04-2013, 07:49 AM   #50
Zero_09
38
Drives: 07 E90, 2011 E90
good write up on how to jack up the car. Never knew about those race ramps. I'm thinking of getting them myself but $121 for the 21" seems a bit much.
      05-05-2013, 12:25 AM   #51
CALWATERBOY
146
      05-05-2013, 12:26 AM   #52
CALWATERBOY
146
Dunno! Mike came with mounts from HP Autowerks - nice 'n' snug.
Hey give 'em a ring....post back....
      05-05-2013, 12:28 AM   #53
CALWATERBOY
146
2x12 lumber oughtta do the trick. Bevel one end....cut to length.
      05-05-2013, 12:28 AM   #54
#Tee
#Tee's Avatar
560
Drives: yes
lol im serious! lots of photos are avail for those who actually search for certain suspension components are basically all here. the amount of time it takes for each pix and well detailed of how to's....cant let this go unoticed buddy! its actually refreshing at times to learn something in a thread stead of reading about ppl bashing on each others opinions.
      05-05-2013, 02:25 AM   #55
chiefsotos
chiefsotos's Avatar
42
Drives: BMW 335 E93
I heard Hp is very helpful, but i should buy most iems from dealer in Greece, to avoid large shipping cost and custom taxes.
If anyone can confirm that the parts numbers of rear sway bars m3 e93 and e92 are the same please chime in.
      05-05-2013, 08:25 AM   #56
demontwinz
Drives: 335i e92
i've read this thread about 4 times now. Good work CAL
      05-05-2013, 09:18 AM   #57
romanonj
romanonj's Avatar
148
Drives: F80 DCT
This is excellent write up.. I studied this post extensively before attempting this at home.. A few comments though based on my experience..
1. No need to compress struts in the wheel well. Loosening lower control arms allows for more travel. Just make sure to support front assembly when the strut is out, otherwise it is supported by your break line. If your caliper and rotor is not off, thats a lot of weight.. I did not remove mine, and used scissor jack to raise and hold the strut in place.
2. 1/4 drive adapter works great!! Who needs that overprices spreader tool!!
3. For strut top nut, use 13/16 spark plug socket with 6mm allen through it. Pic attached.
4. I found that placing car on concrete blocks is much more stable platform that jack stands. Allows for easy loading of suspension witout much worry for tipping the ride.. I robbed local marina before this DIY
5. Hydraulic spring compressor makes front strut work a breeze.. If you can rent one, my friend lend me one from his shop.. Makes me want to change career and work on struts for living!!
Great write up man!!!
2016 F80 M3 BSM with Black interior DCT/Driver Assistance/Executive/LEDs/Adaptive/Black Wheels
2014 F32 435i xDrive AW/CR
2014 F25 X3 M-Sport Carbon Black
2011 e92 335is 2007 X3 122k miles 2006 e90 330i 132k miles
      05-05-2013, 02:37 PM   #58
CALWATERBOY
146
Too true! I compressed mine as that's SOP and needed if you do it my way.
But Eibach linears are shorter - discovered spring compression not at all needed, though my pics show compressors. Simply: Didn't know better when I put the first strut in. Live 'n' learn.
      07-17-2013, 12:38 AM   #59
wheen
23
Drives: f30
which bolts did you loosen for the lower control arms? the ones at the subframe or the ones on the hub/assembly?
in addition to loosening the bolts, did you have to force the assembly down to either swing the struts out of the fender or disconnect it from the knuckle?
      07-17-2013, 10:51 AM   #60
romanonj
romanonj's Avatar
148
Drives: F80 DCT
Subrame bolts need to be loosen. Once loose, no need to force it down, it will drop enough for you to get out the strut. U may need to rotate the assembly to have top mounting bolts clear the fender.. Search for ECSTuning video..
      01-22-2014, 04:07 PM   #61
raceyBMW
king of the hills
raceyBMW's Avatar
92
Drives: 2011 M3 w/ESS55, 2001 540i/6
2001 BMW 540i/6  [8.17]
1994 530i  [9.00]
2007 335i Coupe  [8.37]
This is a terrific DIY! If the OP is still around, are your GC Camber plates quiet as stock?
      01-22-2014, 06:10 PM   #62
CALWATERBOY
146
Yup, still wheezin' along, but my camber plates are quiet!
I've re-torqued a few times just to be conscientious.
      01-22-2014, 10:23 PM   #63
raceyBMW
king of the hills
raceyBMW's Avatar
92
1994 530i  [9.00]
I am going through Jay at GC to figure out my issues with mine, they like rattling over joints in the road. Hopefully the couple things we are trying will work out.
      03-30-2014, 10:51 PM   #64
Greg FEightytwo
Greg FEightytwo's Avatar
Drives: BMW GT4 M4 and X5M
Preface: I've embedded this lengthy post with many links hoping to assist those as inexperienced as I was with the E9x when I bought my car. There's much here but it won't turn you into a mechanic! That said, this project can be done by anyone with a level of determination, a nearby Sears, and good credit.
You'll learn much though your ride may be laid up awhile - not being my daily driver, I was able to take whatever time was needed - it was a pleasure doing work at my leisure, well over a month on jack stands from start to finish. Accomplished BMW pilots have done it over a weekend. Do these mods if you can - you won't regret it - my best to ya'll!
Contents:
Beginnings
DO'S and DON'TS
Raise the vehicle on jack stands
Remove E93 undercarriage braces
R&R front wishbones and tension struts
R&R front shocks/springs [struts]
R&R front sway bar
R&R strut brace - engine compartment
Drop the rear subframe but not the exhaust
R&R rear subframe bushings
R&R rear sway bar
R&R rear wishbones and guide rods
R&R rear springs, shocks, camber arms; toe arms
Finishing touches
Appendix A - Wheel normal ride height
Appendix B - Torque Values
BEGINNINGS
It all started when I drew inspiration from replacing my vile Bridgestone Potenza RFT's w/Michelin PS2's -- like taking off a tight shoe, my life improved.
Boldened, I purchased a Wavetrac LSD and had Sonic Motorsports do the install. I immediately felt the difference - I can feel it while moving slowly down my driveway - found major performance boost in curves, especially accelerating.
I searched, found, and read the Classics....Speediance....1fastBMW....jprandkpr....a host of others; my future became clear....total suspension replacement and M strut brace mod.
One thing stood out: There are just about NO examples of E93 suspension mods.
I purchased a Bentley manual....thus began my adventure. After some study, late last year, I went ALL-IN.
Ordered: Street/School kit from Ground Control, a few miles East of Sacramento. Added end links for front sway to that order.
Ordered: M control arms, M sways, M rear subframe bushings, M strut brace, rear toe arms, and rented a bushing install tool from HP Autowerks in Santa Barbara.
Ground Control took awhile as rear E93 shocks are not the same as other models....the top mechanism adds 400 lb. Not having any in stock, I waited for Koni to make 'em in Holland and ship to Ground Control....this was unexpected, but to do it right....
Toe arms were hard to come by. But, HP Autowerks was able to supply their new toe arms fresh from the anodizing shop exactly when I happened to need 'em - good to go!
WARNING: MY SETUP IS PREDICATED ON THE PRESENCE OF A LIMITED SLIP DIFFERENTIAL - UNPREDICTABLE RESULTS MAY OCCUR IF NOT INSTALLED - GROUND CONTROL NEEDS M SWAYS WHICH NEED A LSD FOR BEST OPERATION
DO'S and DON'TS
DO acquire a comfortable creeper. I used this Craftsman 40" padded unit:
Attachment 676810
DO use at least 2 floor jacks for this project. You'll thank yourself for that. I used this Aluminum Craftsman, pricey and works no better, just liked it; Milwaukee by far the best if used often over time:
Attachment 676795
DO use an air driven 1/2" impact wrench. I used this Craftsman, an indispensable tool:
Attachment 676790
DO use a quality 1/2" torque wrench. 3/8" will work but the longer handled 1/2" gives you more leverage; power. I used this electronic Gearwrench -- beeps when target torque is reached; accurately measures and beeps on user set angle past torque as BMW requires on some bolts. Replaced my analog breakaway wrench with this - glad I did:
Attachment 677434
DO dress all bolts & studs with anti-seize - I used Permatex 81343, Ace Hardware:
Attachment 676792
DON'T depend on floor jacks to keep your ride up! Not even close to reliable for that duty. Use a 3+ ton jack stand at each pad. They're inexpensive -- 6-7 jack stands might be used at some points in the job. Remember to use wood between the jack stand and the point of contact to prevent damage.
Attachment 676943
DON'T completely remove a bolt with an impact wrench - turn those last threads out by hand. If a bolt is removed under power it may rocket out of the impact socket with enough energy to damage the thread where it next makes contact. Not a happy occurrence....PITA to fix!
DON'T install a bolt using an impact wrench until well started in the threaded area. Always start threading in a bolt by hand - otherwise, you stand a chance of screwing up the threads. You don't want that!
____________________________
I bought this 3 ton Craftsman set on sale - floor jack & jack stands worked well; 36" creeper was crap, being 2-piece and too short for this tall boy with no dip in frame rails for shoulder room [see the creeper I used, above]:
Attachment 676799
I now see the above set as a poor value -- I've yet to use the uncomfortable creeper and the floor jack quickly became on/off....little fine control. On the up side, the jack stands work.
Recommend: Purchase a quality floor jack. Used way too much for low cost performance! $300+ might be a good ball park.
Recommend: 4 post lift [Example] with jack so wheels can be R&R'd. Don't yet have; purchasing when I decide where can set up. Not a 'light weight' but immensely useful.
RAISE THE VEHICLE ON JACK STANDS
The whole project took place in a warehouse space. I followed forum advice to raise my ride on 4 jack stands. They served me well, providing a very stable, safe platform for work:
Attachment 657774
I used Race Ramps Jack Assist Ramps to raise my rear wheels 3" - enough to slip a floor jack under the rear jack pads. Can use scrap wood to do the same thing if $ an issue. CHOCK YOUR RIDE!
Initially installed tall Race Ramps under each rear wheel [see next 2 pics] then raised front end from the center jack pad. Installed front jack stands w/2" thick wood at front side jack pads. Raised rear at the differential w/4x4 wood to provide enough loft to place jack stands w/2" thick wood at rear jack pads, then removed tall Race Ramps. Ready for work!
I didn't like the idea of my 4000 lb ride pivoting on the first two jack stands as the vehicle was raised to install the second pair. Tall Race Ramps provided the stable platform I wanted as a temporary measure.
Here are jack points. Again, use the differential as a rear center jack point, but be careful not to include the cover in the contact patch. After up on all 4 jack stands, took all wheels off.
REMOVE E93 UNDERCARRIAGE BRACES
The E93, unlike any other 3, has undercarriage bracing that must be removed. Starting in the rear, it was as simple as unbolting:
Attachment 657775
Attachment 657776
I removed the plastic aero tray under the front of the car - about 20 bolts - and unbolted the front E93 brace:
Attachment 657680
Remove the front brace arms. Now the suspension can be accessed.
R&R FRONT WISHBONES AND TENSION STRUTS
Not much to this. Each arm is bolted at one end; needs nut removal at the other. Pull off. Replace w/M part.
Doing one side at a time, use impact wrench to remove bolts/nuts. R&R one arm before doing another - a wishbone and a tension strut for each side - view stock arms #14 & #9 here and M parts #14 & #19 here.
It's best to jack the knuckle up to normal ride height to remove/install, otherwise you'll find undue stress.
IMPORTANT: Suspension bolts should be started but not torqued until all bolts are in - give your suspension room to move so that all bolts can be fitted w/o stress - if necessary, loosen a few other bolts to achieve this. Otherwise you could cross thread a bolt!
IMPORTANT: Torque all suspension parts while at normal ride height with steering wheel centered. See Appendixes A & B.
Attachment 657684
Pic borrowed from 1fastBMW - thanks!
R&R FRONT SHOCKS/SPRINGS [STRUTS]
First, free wires and brake hose from the strut. Compress the springs - I used these Craftsman spring compressors:
Attachment 657695
Jacked the knuckle up & hand tightened, the easy way to do it. When fully compressed, removed the nuts from the strut studs in the engine compartment and lowered the wheel....tilted strut out for removal....CAREFUL not to scratch fender wheel well paint! Some tape the wheel well - look back 2 pics to see.
Attachment 657696
Now the pinch clamp must be widened. I used a 3/8 female x 1/4" male adaptor - 1/4" fits right in; turn 45 degrees. Strut lifts right out! Only good for a couple of tries - corners of the 1/4" end round easily - I went through 2 - they're inexpensive and I didn't want to wait to receive a strut spreader tool.
Thanks, mike-y, for the tip and this pic! [Post #2]
Attachment 657699
Attachment 657697
Reverse order to install new strut - there's a button on the strut that slots through the opening in the pinch clamp - you cannot put it in wrong. Careful to be sure wiring is returned to correct route.
Remember, engine compartment nuts will be torqued when car's back on the ground with the steering wheel centered. In my case, I tightened engine compartment strut mount nuts finger tight - still have strut brace to install using those studs.
I left the gold Ground Control height adjustment collar threaded all the way up until time for ride height adjustment.
Attachment 657700
R&R FRONT SWAY BAR
The front sway's easily unbolted, end links & mounts; removed. Then, a problem: How to mount w/2 part M3 sway bushings. Stock here. My solution was to rubber mallet them into place - snap! Apply silicone grease to the bushing prior to install so they can easily rotate on the sway bar. Install new M sway in reverse order.
Move both hubs to normal ride height with steering wheel centered & torque all bolts & nuts. See Appendixes A & B.
Attachment 657705
Attachment 657706
Attachment 657707
R&R STRUT BRACE - ENGINE COMPARTMENT
Here's my procedure for the M strut brace, a major pain!
I followed this procedure, but was stumped when the center cast piece wouldn't go over the tab at all. No matter what. No way, no how.
Solved by slipping it in from the side, a tight fit! Perseverance carried the day.
Attachment 657712
Attachment 657713
Attachment 657714
Bolted it together loosely - until back on the ground w/steering wheel centered, front suspension properly torqued, maybe the last part of this job.
DROP THE REAR SUBFRAME BUT NOT THE EXHAUST
I dropped the rear subframe 3-4" to enable rear subframe bushing & sway R&R. Support the subframe with a floor jack under the differential, again being careful not to include the diff cover in the contact patch. I placed a jack stand with 4x4 wood piece under the subframe cross member just rear of the diff; just forward of the brace mount as shown, 3-4" below the cross member [the amount of drop I want].
Attachment 657724
Unclip all wires at the wheels to allow slack, then disconnect brakes lines here:
Attachment 657725
Use flexible line crimps or quickly plug the flex lines to prevent draining brake fluid to your floor. DO NOT allow brake fluid to contact your paint - it will permanently damage the finish! If it does go there, don't attempt to rub it off - dab up w/paper towel.
Next, rather than dropping the exhaust, I disconnected at the flanges forward of the cats, a 4 nut removal, easy:
Attachment 678357
Image borrowed from jprandkpr
Also removed the reinforcement plate w/8 torx bolts:
Attachment 678358
Then removed the mid pipe brace, one bolt:
Attachment 678359
That allowed my exhaust piping to move with the subframe drop; I supported the cats/silencers with a jack stand and section of 2x6 wood. Disconnected rubber hose operating the rear exhaust flap. When I later needed to drop one side or the other, I removed rearward hanger mounting bolts rather than muscling off the rubber hangers.
Had I dropped the exhaust, somewhat heavy, I'd of had one big matzoh there with nowhere to go! Totally in the way of my creeper, needs removal from the work area. Big pain. T'heck with that, I said.
I removed all 6 subframe bolts and g-e-n-t-l-y lowered the subframe onto my jack stand's 4x4 wood block [look 5 pics back; above].
R&R REAR SUBFRAME BUSHINGS
Next, I used HP Autowerks' subframe bushing tool to replace all four stock bushings w/M subframe bushings. It's easy enough with an impact wrench, but DON'T forget to lube your threaded rod [used 20/50 motorcycle oil....no lube = seized nut!], and please, butter your bushings with silicone grease for a sa-mooth install.
Attachment 657727
I bought the pictured Dow Corning 111 silicone grease at WW Grainger.
All stock bushings come out from the bottom, but front M bushings go in from the top; rear M bushings go in from the bottom. HP Autowerks' tool highly recommended - <$60 rental - makes the job very easy.
R&R REAR SWAY BAR
M Sway was reputed to be a difficult R&R but critical, as it is dramatically beefier than the stock sway. I didn't find it hard at all, once I devised a way to snap the rear sway 2 part bushings together on the bar.
Simply drilled a couple of holes in bar stock - slowly tightened bolts by hand - snap! snap! The clips went right in on the bar. Use plenty of silicone grease on bushings so that they turn easily on the bar.
Do not use a rubber mallet! Rear sway bushing assy's are of very diff composition than front, and will explode like an evil jack-in-the-box if you try to mallet them together.
Scads of room to maneuver with subframe dropped 4" - a smooth install.
Attachment 657732
Attachment 657733
Torqued mount bolts but left end links disconnected as the much fatter M sway must be moved out of the way to R&R guide rod mount bolts at the bearing carrier.
Raise subframe and torque the 6 subframe mount bolts.
IMPORTANT: Start all subframe mount bolts by hand, then tighten all barely snug, then tighten to torque value. If you tighten each bolt to torque before starting the next, you stand a good chance of having the last bolt or two not thread in, being offset a small ammt by new bushings. Save yourself some time and frustration - follow this procedure.
Remember to re-clip wires and reconnect brake lines.
IMPORTANT:
Bleed your brakes!! [Post #30] If you get air way up in there, activate the ABS pump.
R&R REAR WISHBONES AND GUIDE RODS
On to M Suspension Arms [Parts #17 & #18]. Stock arms here.
Again, not much to this. I replaced the wishbone & guide rods.
IMPORTANT: At the rear especially, suspension bolts should be started but not torqued until all bolts are in - give your suspension room to move so that all bolts can be fitted w/o stress - if necessary, loosen a few other bolts to achieve this. Otherwise you could cross thread a bolt!
IMPORTANT: Doing one side at a time, move the wheel hub to normal ride height when removing/reinstalling bolts to avoid undue stress. See Appendixes A & B.
Move sway bar up to access guide rod bearing carrier mount bolt. R&R one arm at a time. When finished both sides, install M sway bar end links, both rear hubs at normal ride height; torque all bolts & nuts.
R&R REAR SPRINGS, SHOCKS, CAMBER ARMS; TOE ARMS
Again one side at a time, I then R&R'd shocks, springs, camber arms and toe arms.
IMPORTANT: The headlight leveling sensor is connected to the driver side rear camber arm with a rod. Disconnect before removing camber arm mount bolts or you WILL damage the sensor - think $60 and PITA trip to the parts counter. You may wish to replace the sensor with the M3 sensor to obtain the repositioned sensor arm, ready-made. Read about need for 180° change in sensor arm position on M3 camber arm install, 14 para's below.
IMPORTANT: The shocks prevent the wheels from articulating to the point of CV joint damage. When disconnecting this assy, support the bearing carrier with a jack stand. Handy point to do so just inboard of the disk, forward.
Unbolted shock & two mounting bolts; removed camber arm. Must drop exhaust some to get inboard bolt out. Dropped each side individually so did not have to drop the whole exhaust - remove hanger mount bolts/nuts on one side to accomplish this. Jack stand can be used to support freed side but I let it rest on my bod [on creeper] as I attached the camber arm; immediately reinstalled the exhaust. Then, did other side.
Springs fall right out. Spring hat pops off by tapping a bladed screwdriver in between hat & subframe. Only the top shock mounts left to unbolt and brother, that's when my troubles began!
The trunk of an E93 is, put mildly, crowded. There're hundreds of lb of hydraulic gear and roof strut to deal with - following this procedure, I attempted to remove side panels.
I swore. I screamed. I sat deep in thought....they wouldn't budge! Understand, they must be removed to R&R the shocks....all would be for naught without that.
I'l skip everything I tried; approaches were many. In the end I cut holes with my Dremel in the felted plastic panels above my struts to access the mounts.
That is not a trivial job in the trunk of an E93. Much is in the way....space cramped....Dremel a touch large....then it hit me: The E93 is uniquely suited to the job!
I raised the top part way, and all was revealed.
Attachment 657739
I cut a hole....
Attachment 657740
I discovered: WIRES!
Attachment 657786
Big danger there....do you see the abraded covering? Luckily, though I didn't know about them until after removing the cutout section, none were damaged. But forewarned is forearmed: be aware of this!
Attachment 657741
That done, assembly w/M camber arm wasn't a problem. Attach camber arm with inboard bolt; swing up to attach shock with bolt. Tap the Ground Control sping hat into position - O-ring will hold it there reasonably well. Use a floor jack w/bit of wood between camber arm & jack to move camber arm w/attached shock & installed spring up to position.
Careful to guide the spring so that the bottom part of the hat slides into the spring. Attach to bearing carrier with bolt. Leave Ground Control gold height adjustment collars (top of spring) threaded all the way up until ride height adj time, otherwise the rear suspension may not be able to reach normal ride height, preventing the upper control arm & guide arm bolts from threading in properly at the bearing carrier.
Now you'll find the connecting rod for the Headlight Vertical Aim Control Sensor does not reach from the M3 camber arm mount!
The problem is: Sensor arm needs to be rotated 180° to connect. 335i headlight level sensor parts, rear -- M3 headlight level sensor parts, rear Unless connected your headlights will freeze in a fixed position, most often pointing up, irritating oncoming drivers. Yow! The M3 mount is significantly outboard of the 335i mount:
Attachment 698653
New part? Check electrical operation? Rather than fool around, I went KISS: Fab'd a 1.5+" offset bracket from a small piece of Ace Hardware aluminum sheet stock:
Attachment 698654
I rolled the tabs around the M3 mount for a secure fit and bolted together - viola! New mounting hole approx. where the 335i camber arm provided it. Leveling system now works, maybe a quick headlight alignment needed, easily done. No new M3 sensor; no sensor arm rotation. Just good ol' shadetree ingenuity. Did I do good?
Back to installing suspension components:
IMPORTANT: Leave bolts started but not torqued to allow suspension movement until ALL bolts are in. Only then should suspension bolts be torqued down.
Attachment 657742
Then, toe arms -- maybe the easiest part -- zip, zip.
Attachment 657762
Attachment 657763
FINISHING TOUCHES
End game: Meticulous double check to be sure all nuts & bolts have been correctly torqued with hubs in the normal drive position and steering wheel centered. You'll have found by this point that using a torque wrench is best done on a lift as exerting up to 122 ft lb torque w/ride on jack stands is not the easiest of tasks. Can be done, but you may struggle!
Reinstall E93 bracing, reinstall plastic front undercarriage aero sheet, torque engine compartment strut mount & strut brace bolts with all paws on the ground; do ride height adjustment.
IMPORTANT: After lowering your ride to pavement, start your engine and run your 3 couple of times back & forward a few feet to move wheels to normal drive position. Be sure your steering wheel's centered as you roll. THEN torque strut bolts. Otherwise, you may stress strut mount bolts:
Attachment 698666
Attachment 698667
I ground off the tack weld on the broken bolt; threaded in new and installed it correctly. Expecting no further trouble.
Ground Control provides for ride height adjustment -- see the gold rings on struts & spring hats [click here]? They're threaded on the red cyl to provide that adjustment. Sweet! Again, I had screwed all stops to the top of the adj cylinders before final height adjustment to allow knuckle (front) & bearing carrier (rear) movement to normal ride height while R&R'g parts.
GOLF TEE MOD
One last little thing. re: N54 -- If you crimp the rubber vacuum line to disable the driver's side exhaust flap at the rear of the car, you'll change low rpm behavior in a very pleasing way - much better modulation & torque. I did it with a plastic wire tie. Exhaust also louder, not a big plus for me as the sound isn't quite what I like, but good feedback. Known as the "Golf Tee Mod." Easily Googled - you'll find many DIY docs & YouTubes.
__________________________________________________ _
UPDATE: Uncrimped my rubber vacuum line. Found reduced back pressure resulted in lower low rpm torque which, though it seemed to enhance low rpm throttle control, yielded lower low rpm thrust and ran a touch rougher. Restoring to stock was a return to smoothness and torque, so much so that I'm skipping this mod unless/until new engine settings are figured out, maybe adj'd with JB4.
Done! Off to the alignment shop....an OUTSTANDING experience I recommend to everyone.
Attachment 657764
TOE ARM UPDATE
10 months later, clicking at my rear suspension; suspect worn toe arm Heim joints.
When cool weather's here, no click....yet. Looking into Megan toe arms - more later!
Ride height is measured from the top of the wheel well fender flange to the bottom of the wheel rim.
Front Stock Values:
16" wheel -- 22.99 in -- 584 mm
17" wheel -- 23.58 in -- 599 mm
18" wheel -- 24.09 in -- 612 mm
19" wheel -- 24.60 in -- 625 mm
Rear Stock Values:
16" wheel -- 22.24 in -- 565 mm
17" wheel -- 22.83 in -- 580 mm
18" wheel -- 23.35 in -- 593 mm
19" wheel -- 23.82 in -- 605 mm
But if you wish to work with wheels off the car, which I did, measure from the top of the wheel well fender flange to the bottom of the hub. That was 18.7" front; 18" rear on my car.
Front wheel hubs I raised to normal ride height with floor jack and a piece of 2" x 6" wood under the hub as shown in pic #5 from the beginning of this post.
Rear hubs I raised with floor jack & short length of 4" x 4" wood under the camber arm just inboard of the bearing carrier.
IMPORTANT: Ground Control suspension intended to reduce ride height maybe an inch. I did 3/4".
____________________________________ Ft Lb ________ N/M
WHEELS
Wheel Lug Nuts..........................89..........120
EXHAUST
Exhaust - forward flanges...............15...........21 - turbo
........................................33...........45 - non turbo
Exhaust - reinforcement plate...........43.5.........59 - Torque +90° [-+30°] -- 8 Torx Bolts
Exhaust - mid-pipe brace................15...........20
Exhaust - hangers - differential........26...........35 - turbo
........................................22...........30 - non turbo
Exhaust - hangers - wheel carrier.......15...........21
Exhaust - hangers - rear chassis........15...........20
M3 STRUT BRACE
Bulkhead mounting bolt...............73.75..........100
All other bolts......................25.07...........34
FRONT SUSPENSION
Sway bar end link.......................44...........60
Sway bar mount to subframe..............16...........21....M8 bolts
Tension Strut @ knuckle................122..........165
Tension Strut @ subframe................74..........100
Control Arm @ knuckle..................122..........165
Control Arm @ subframe..................74..........100
Strut Pinch Clamp.......................60...........81
REAR SUSPENSION
Brake line to hose.......................9...........12
Sway bar end link.......................42.7.........58
Sway bar mount to subframe..............16...........21 - M8 bolts
Rear subframe bushings..................73.7........100
Upper Control Arm @ bearing carrier.....73.7........100 - Torque +90°
Upper Control Arm @ subframe............73.7........100
Guide Arm @ bearing carrier.............73.7........100 - Torque +90°
Guide Arm @ subframe....................73.7........100
Camber Arm @ bearing carrier...........121.6........165
Camber Arm @ subframe..................121.6........165
Camber Arm Shock Mount..................75..........102
Upper Shock Mount.......................27...........19.9 - M10
Upper Shock Mount.......................37...........27.3 - M14
Toe link @ bearing carrier..............73.7........100
Toe link @ subframe.....................73.7........100
Disclaimer: I make no representation regarding the accuracy or advisability of any value or procedure in this post - this is what I did for my ride. Yours may be different! Other models may require other procedures and data - verify everything as for your vehicle before you do any of what I've done - you proceed at your own risk.
Hey CalWaterboy,
Thanks for the information. I just wanted to ask if you by chance have the measurements to the rear headlight lever that you created?
Mine did not come with the fabricated one and I plan on doing what you have to make my current one work.
Thanks in advance for your help.
G
      04-28-2014, 09:14 PM   #65
mlifxs
Diamond Geezer
mlifxs's Avatar
212
Drives: Jet Black 2007 328i Saloon
Hi CAL,
Now that you've had it for awhile, how do you like your Ground Control setup? I sent you a PM if you'd rather respond there. I noticed earlier in this thread that this is strictly a street car. Are you still happy with the ride? Anything you would change?
Thanks!
      06-06-2014, 03:05 AM   #66
BudVlad
Old Geezer
BudVlad's Avatar
Czech_Republic
364
Drives: 08 E92 N53B30
2008 E92 N53B30  [10.00]
Thanks CALWATERBOY for great idea for the rear headlight leaver adapter. Dimensions can be easily scaled from the picture he posted.
BTW: I had to use Megan toe arms because the M3 aluminum doesn’t fit.
