10-22-2015, 03:05 PM | #1 |
General
2944
Rep 21,753
▀▄ eas | Dinan Suspension Complete Line Up - Authorized Dealer
Now available from EAS is Dinan's complete line up for the M5. As an authorized dealer we are ready to handle all your Dinan needs whether it be install or shipping. PM today for expert advice and info Dinan - High Performance Adjustable Coilover System - BMW F10 M5 For the driver that demands the best out of their vehicle. The Dinan® Adjustable Coil-Over Suspension was bred in the race lab but refined on the street for maximum versatility. No matter the environment, the traction that is bestowed upon the vehicle from the improved suspension will inspire new found confidence when running at higher speeds. Combined with a substantial reduction in body roll as well as reducing dive under breaking and squat under acceleration. Dinan will guarantee you superior handling, performance, and comfort. Dinans design keeps the factory Electronic Damper Control shocks in place and implements threaded collars to allow the user to change the ride height. The end result is a sleek lowered stance that provides improved handling to go along with its stunning visual appearance. The springs combined with progressive bump stops and other components increase travel that allows the car to be lowered up to an 1” in the front and 1 1/2" in the rear. Suspension packers are included to fine tune handling and comfort by changing the clearance of the progressive bump-stops, something no respectable racecar is without. Components are machined from 6061-T6 aluminum and black anodized for appearance and corrosion protection. Features: - Threaded collars allow easy and precise front & rear vehicle height adjustments. - Included suspension packers allow adjustment of bump-stop clearance to fine-tune handling and comfort. - 100% compatible with EDC equipped models - Stock upper spring mounts are utilized for quiet operation - Substantial reduction in body roll. - Spring rates are nearly 50% stiffer in front and 10% stiffer in the rear. *Approximate Front/Rear Lowering: Front: Up to 1.25" lower Rear: Up to 1.25" lower * 3/4" drop is recommended in front and back to maintain a civilized ride. Models Supported: 2012+ BMW F10 M5 Dinan - Lightweight Adjustable Anti-Roll Bar Set - BMW F10 M5 Almost all street cars come from the manufacturer with an anti-roll bar as it is a common part of modern suspension systems. However they are designed to be overly soft for maximum comfort. An anti-roll bar does exactly what it says by reducing body roll in all situations. Every Dinan® tuned anti-roll bar is built and tuned specifically for each BMW chassis. Lowering the amount of body roll keeps your BMW more level than stock (while still allowing just enough body roll) to improve mechanical grip. This improvement gives the driver a much more planted and confident feeling in every corner. Front Anti-Roll Bar Add a 28mm Lightweight Tubular Adjustable Front Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time. The Lightweight Tubular Adjustable Front Anti-Roll Bar is 44% lighter than a solid anti-roll bar of comparable stiffness. This anti-roll bar is adjustable from 35% to 53% stiffer than the stock bar. This 2 hole bar can be mounted in 3 different positions with supplied end links that are left and right hand threaded for easy length adjustment. Rear Anti-Roll Bar Add a 22mm Lightweight Tubular Adjustable Rear Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time. The Lightweight Tubular Adjustable Rear Anti-Roll Bar is 29% lighter than a solid anti-roll bar of comparable stiffness. This anti-roll bar is adjustable from 39% to 72% stiffer than the stock bar. This 3 hole bar can be mounted in 3 different positions with stock BMW end links Features - Less Body Roll - More Mechanical Grip - More Stable At Limit - Front: Large 28mm size (stock bar is 24.5mm) // Rear: Large 22mm size (stock bar is 21.5mm) - Front: 2 hole bar with 3 possible positions on bar & adjustable length end links // Rear: 3 hole bar with 3 possible positions on bar - Lightweight – Front: 44% lighter than a solid anti-roll bar of comparable stiffness // Rear: 29% lighter than a solid anti-roll bar of comparable stiffness - Only tubular anti-roll bar with a large range of adjustment on the market - Tubular (Hollow) Construction Models Supported 2012+ BMW F10 M5 Dinan - Negative Camber Control Arms - BMW F10 M5 Negative Camber Control Arms provide a reduction of understeer and more immediate turn-in from the M5 by inducing more negative camber on the front wheels. The additional negative camber improves the grip of the front tires in the turns thus reducing the vehicle's tendency to "plow" or "push" the front end for those who drive a bit more aggressively. This increase in negative camber is accomplished in two ways. The shorter front upper control arm increases camber gain, which is the amount of negative camber that is created by the geometry of the suspension as the car rolls to one side. In addition the static negative camber or the amount you will see on your alignment read out is also increased. The combination of static and dynamic camber gain adds an increase in front grip when the tire is loaded. Features - Replaces front upper control arms with ones that increase negative camber by -0.3° - Improves grip of front tires - Evens out tire wear during aggressive cornering Models Supported 2012+ BMW F10 M5 Ordering: Phone: You can reach us directly by calling 866.669.0705 to place your order over the phone. Payment: Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone) Other Payments: Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods. Shipping: All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees. Hours of Operations: Monday - Friday from 9AM to 5PM PST Saturday - 9AM-2PM PST Sunday - Closed Retail Location/ Installation Center: Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell. Contact Info: Phone: 866.669.0705 x31 Email: kevin@europeanautosource.com Website: http://www.europeanautosource.com Feel free to contact me via PM, email, or phone if you have any questions.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
10-28-2015, 05:41 PM | #2 |
General
2944
Rep 21,753
Thanks for the inquires
PM today for all your Dinan needs
11-05-2015, 02:22 PM | #3 |
General
2944
Rep 21,753
Thanks for the inquiries
We are an Authorized Dinan retailer PM today for all your Dinan parts
11-10-2015, 02:45 PM | #4 |
General
2944
Rep 21,753
Dinan sway bar set available for you F10 M5
PM today for pricing and details
11-13-2015, 06:15 PM | #5 |
General
2944
Rep 21,753
Get you Dinan suspension from EAS
PM for pricing and details
11-17-2015, 11:34 AM | #6 |
General
2944
Rep 21,753
Dinan Sleeve over installed
11-20-2015, 11:21 AM | #7 |
General
2944
Rep 21,753
Dinan sway bars just installed
12-04-2015, 06:41 PM | #8 |
General
2944
Rep 21,753
Get your Dinan suspension from EAS today PM for pricing and details
12-30-2015, 11:42 AM | #9 |
General
2944
Rep 21,753
Get your Dinan suspension products from EAS today PM today for pricing and details
03-10-2016, 05:53 PM | #10 |
General
2944
Rep 21,753
Get your Dinan suspension from EAS PM today for pricing and details
03-18-2016, 05:54 PM | #11 |
General
2944
Rep 21,753
Get your Dinan suspension from EAS!! PM today for pricing and details
04-06-2016, 04:57 PM | #12 |
General
2944
Rep 21,753
Dinan adjustable toe arms
PM today for all your Dinan suspension needs
05-12-2016, 06:12 PM | #13 |
General
2944
Rep 21,753
Dinantronics in stock and ready to ship
Backed by the Dinan Warranty PM today to get yours
06-23-2016, 11:43 AM | #14 |
General
2944
Rep 21,753
NEW lower price on Dinan Adjustable coil over systems
In stock and ready to ship PM today for details and pricing
07-07-2016, 04:25 PM | #15 |
General
2944
Rep 21,753
New lower pricing on Dinan coil over systems
PM today for all your Dinan needs!!
07-23-2016, 11:53 AM | #16 |
General
2944
Rep 21,753
EAS your #1 source for Dinan performance parts PM today for details and pricing
11-07-2016, 05:59 PM | #17 |
General
2944
Rep 21,753
Dinantronics units in stock and ready to ship PM today for details and pricing
