05-10-2024, 02:13 PM | #1 |
DT///M
151
Rep 1,374
Drives: 2014 F31 Touring
Led fog with Halo
Got these foglight recently and went to install them but I am not sure where I can splice the power for the ring into. The bulb is plug and play. But where to splice?
Google only gets me foglight bulb replacement. And I don't want to just start splicing... Anyone work with these have an idea? Thanks!
"With great power comes great responsibility." -El-Superbeasto
05-10-2024, 02:24 PM | #2 |
Rep 487
Highly likely you'd want to connect to switching +12V so that they turn on when the car starts. You should be able to pick this in the fuse box.
I strongly advise you not to splice into any wiring that relates to Hi/Low beams or any other bulbs, esp when your car is pre-LCI and every bulb goes through the test cycle by FEM at every engine start. Would love to see these in operation. Do share some pics once you get them to work. Also, if these came with plastic lenses, PPF them asap or within 6 months the lenses will be "frosted" from sand on the roads.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
Erie Von Otto150.50 _ObiJon207.50 |
05-10-2024, 03:50 PM | #3 |
Rep 16,192
Is the ring separate from the fog? If so connect them to the fuse for the console outlet. They'll turn on when you unlock the car, turn off a few minutes after you lock it. If the fog bulb is LED don't count on it being plug and play, it will probably have to be coded.
Erie Von Otto150.50 |
05-10-2024, 05:04 PM | #4 |
DT///M
151
Rep 1,374
I've already coded the led as I've been running those bulbs for a long time. I just wanted to upgrade the look. Found these for a fair price and now just need to get the rings powered up.
