TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > OFHG / Mickey Mouse flange
      07-09-2023, 09:35 PM   #1
AllBlackBimmer
AllBlackBimmer's Avatar
815
Drives: 2019 X3 m40i
I need to do my OFHG, for the second time now.
Does it make sense to replace the Mickey Mouse flange when doing this? I’d get the aluminum one
I’ve had my radiator replaced about a year ago, and then replaced a few hoses but I don’t think they would’ve touched the hose with the Mickey Mouse flange in it, correct?
If doing the MM flange, and OFHG … what else should I have done while they are in there doing the work.
My sepertine belt and tensioner were done 50k ago… debating on doing that as well.
N52 328i, 151,000 miles
Thanks
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710
      07-09-2023, 11:01 PM   #2
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2006 BMW 330i  [8.21]
2009 BMW 328i Touri ...  [7.90]
2013 BMW X5 35i  [7.63]
2011 BMW 528i  [8.75]
2006 Mazda3  [5.50]
Thanks
I'd get the hose done at the same time just to be sure. Change as much of the coolant as you can as well, sort of a semi-flush. And yes, do the tensioner and belt @ 50k. Easy to change the VANOS seals while you're there, so I did mine at the same time. There's been recent discussion on crank seal guard, might as well do that while everything is pulled off.
https://www.e90post.com/forums/showthread.php?t=2029635
      07-10-2023, 02:33 AM   #3
Serf27
Serf27's Avatar
2851
Drives: 335i
Replace that flange, replace belt and tensioner.
Get an oem gasket.
Those aftermarket gaskets don’t last as long.
whyzee1251681.50
      07-10-2023, 06:25 AM   #4
AllBlackBimmer
815
Dumb question, what is this hose called? The one that attaches to the MM flange? I believe it goes to the thermostat?
VANOS seals... I will have to look that one up, but thanks for the suggestion
Crank guard seal - this is the metal cover that protects against the crank sucking in the belt if it snaps? would make sense to do if I am going to the belt/pulley/tensioner
      07-10-2023, 06:26 AM   #5
AllBlackBimmer
815
Get an oem gasket.
I agree, i only have ever used OEM gaskets.
My OFHG has lasted almost exactly 75,000 miles.
My first VCG gasket went at 90k, so I am expecting on having to do that one too pretty soon.
      07-10-2023, 07:14 AM   #6
Efthreeoh
General
Drives: The E90 + Z4 Coupe & Z3 R'ster
No need to do the belt and tensioner. I'd have the shop source the t-stat hose with the aluminum flange already assembled in the hose. Shops like to replace parts for warranty purposes.
      07-10-2023, 07:59 AM   #7
denn69
Drives: BMW 328XI
https://www.fcpeuro.com/products/bmw-coolant-hose-with-flange-rein-11537545890
Here is the link to the hose at FCP. Def change it. If you want to torque the OFHG correctly u have to take it off anyway. Mine was broken on both my cars.
      07-10-2023, 08:40 AM   #8
Suvorovo
Suvorovo's Avatar
254
Drives: Broken e90 330xi 6MT
Agreed with everyone, I also purchased an OEM gasket and OEM bolt set. Someone on the forums recommended not getting the Rein one. They mentioned that the Rein flange started leaking shortly after installation. Unfortunately for me, the job was already done using a rein flange.
      07-10-2023, 09:06 AM   #9
StradaRedlands
2006 Mazda3  [5.50]
My Rein flange/gasket has been fine so far (Done last September).
https://www.fcpeuro.com/products/bmw...in-11537545890
I did have a small leak from Rein upper radiator hose at the the heater hose junction, but it sealed up after the O ring expanded a bit.
      07-10-2023, 10:13 AM   #10
lowrydr310
Robot
1686
Drives: 2006 330i, 2007 E93 335i
Careful with the terminology there. I think you're referring to the VANOS solenoid o-rings, which are easy to change.
"VANOS seals" in the context of BMW usually refers to the internal gaskets on the VANOS adjusters for the M52TU, M56, and M54 engines, and require a valve cover removal along with a bit of time to replace.
These do not apply to the N52, N51, N52k, N54 or N55 motors found in E90s.
      07-10-2023, 12:07 PM   #11
StradaRedlands
2006 Mazda3  [5.50]
You are correct! VANOS O-rings or gaskets!
https://www.fcpeuro.com/products/bmw...-11367548459oe
      04-15-2024, 09:34 PM   #12
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2008 BMW 135i  [9.50]
2006 330i  [6.75]
You guys like my new Souvenir?? Lasted me 17 yrs. Cant complaint.
Appreciate 5
      04-16-2024, 01:16 PM   #13
lordnikon
lordnikon's Avatar
367
Drives: Break My Wallet
You won the lottery that it didn't break into pieces.
