05-25-2016, 10:23 PM | #46 |
General
10447
Rep 40,805
05-25-2016, 11:47 PM | #47 | |
Rep 3,945
Drives: 2015 M4 MG/SO
- some error where the PC and the car lost connectivity due to multiple reasons: APIPA, link layer, physical connection, ignition off. One way to be sure is use a static IP or setup a DHCP server like you said on PC. I use Win7/Bootcamp/Macbook Air and an Apple USB to ethernet adapter. - Ignition off: Although it is said that once TAL Execution starts, that ignition remains on, I did notice that as soon the cdDeploy started, the car iDrive came back, and then the problem happened. I need to understand the ignition ON/Off behavior... The errors are similar to what other people had when they connected using Direct or wrong target (not my case obviously), calling it a night but it bothers me not really knowing what happened (maybe I'll wireshark the next flashing session ...) Last edited by aboulfad; 05-29-2016 at 07:30 AM.. |
05-26-2016, 10:38 AM | #48 |
Rep 3,945
Small progress, I wanted to prove there was a loss of network connectivity, so I fired up Esys and during a "Read Coding Data" on ASD, I disconnected the ENET cable from my laptop and I got the same type of error (ECU_ID_ETHERNET):
Code:
CPS read from ECU "ECUId:ASD_0x3F" failed! [C070] negative response error: code: TIMEOUT P2/T2 occurred description: T2 timeout on Service RDBI_CPS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2008][VendorCodeDescription=T2 timeout occured]; ECU: ASD_3F_ETHERNET severity: ERROR Code:
[GHAS - F] - [Exception - GHAS - f] negative response error: description: P2 timeout on Service RDBI_SVK has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; ECU: GHAS_0F_ETHERNET severity: ERROR Code:
[VDC1 - 76] - [Exception - VDC1 - 76] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service DSC has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; ECU: VDC1_76_ETHERNET severity: ERROR Last edited by aboulfad; 05-26-2016 at 10:55 AM.. |
05-26-2016, 11:00 AM | #49 | |
Rep 1,132
I have a Windows 7 Dell with an ssd and an ethernet port that I can send your way to borrow if you would like. PM me if your interested. |
05-26-2016, 11:06 AM | #50 |
Rep 3,945
Thank you but I am quite happy with my MBA, it works perfect! Not to digress, many people use MacBook and Win/bootcamp, you get best of both worlds. So far, there is no evidence that the issue I had is related to my setup as I have used it for the past one year day in and day out to code and diagnose.
05-26-2016, 02:45 PM | #52 | |
Rep 3,945
So now its confirmed even further that either the ignition went Off or loss of connectivity during the TAL execution cdDeploy phase! Code:
NCD read from ECU "ECUId:KOMBI_0x60" for CAF "cafd_000009c8-006_003_053" failed! [C069] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_PLAIN has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; ECU: KOMBI_60_ETHERNET severity: ERROR |
05-26-2016, 03:43 PM | #53 |
Rep 1,514
Its better to have separated Win installation not to mess with your work, or your work not to mess with coding/diagnosis. Also INSTAA is messing with some Win settings I read somewhere. I have it on another disk I swap when I need on my laptop. No need of another licence as I'm using cloned Win.
05-26-2016, 04:40 PM | #54 |
Rep 3,945
I guess it's an inherent benefit of using bootcamp on a Mac as that gives you the isolation you want and the performance would be better than a virtualized OS! in any case my MacBook Air evil personality (Windoze) is dedicated for my BMW tools
05-26-2016, 05:28 PM | #55 | |
163
Rep 387
I also have Rheingold in another VM. |
05-26-2016, 08:02 PM | #56 | ||
Useful Idiot
1330
Rep 1,777
Drives: My wife and kids insane.
I haven't paid for software (out of my own pocket anyway) in over a decade.
05-28-2016, 06:09 AM | #57 | ||
Rep 3,945
1. if FA was modified and written to the car, then the VO coding is done using that modified written FA to car, right? That's what I came to in my post #15 here. So what happens when a user writes the modified FAs for NGHB post flash? 2. if FA is saved offline but not written to car, then the VO coding is done using the original FA and all changes are lost and the user has to VO code using the saved FA and re-code. Thanks! |
05-28-2016, 07:54 AM | #58 | |
Rep 1,481
So basically this is consistent with both statements 1. and 2. above.
2015 Mineral Grey ///M4 6MT
05-30-2016, 07:00 AM | #59 |
Rep 1,481
Well, Bluex provided additional information last night about what codings were or were not reset by the dealer-performed I-step update, and his experience is not consistent with the ECUs being simply VO coded after the flash. It appears that ISTA-P does take additional steps to preserve the coding in place before the update whenever possible.
05-30-2016, 07:20 AM | #60 |
Rep 3,945
^^^^ interesting and puzzling, not sure what to make of it, there may be some relationship to modified written FA to car and/or using ISTA/P? Using Esys, out of the 7 ECUs I flashed, only DSC had coded parameters (EuroMDM) and they were all reset.
terahertz, thisisdave did you loose all your coding when you fully upgraded your car with Esys? did you have any FA modification written to car or just saved offline ? |
05-30-2016, 07:29 AM | #61 | |
Rep 1,481
05-30-2016, 07:33 AM | #62 |
Useful Idiot
1330
Rep 1,777
To be clear, I did not lose any of my LED coding in the LHM 43,44 modules. All modified werte values were set to their appropriate EU values.
I lost all coding (except 1 value) in FEM_BODY, and a few other things. LHM was what was left untouched, even though we did confirm that the CAFD was upgraded as well.
05-30-2016, 07:33 AM | #63 |
Rep 3,945
I have my 15k km service planned for this week, I won't ask for an update but if they do I'll check. And I am no longer planning to flash the rest of my ECUs without knowing is there's a real benefit to the remaining ones...
05-30-2016, 11:31 AM | #64 | ||
21
Rep 59
Well I finally flashed the DME, DSC and ICM to 58.3. I had a hell of a time last night getting it to flash and kept getting the following error message.
I also had the following error. Quote:
The flash took about 10 minutes. My single homebrew PSU worked albeit during the initial part of the flash the water pump ran for about 4 minutes and the battery voltage dropped from about 13.28 volts down to about 13.12 volts which had me worried. After that stage the voltage rose back to about 13.16 and stayed there. The multimeter integrated with my PSU was showing a solid 13.6 volts and around 10 amps. I was under the impression that this thing should be putting out 20+ amps during a flash. I'm wondering if the voltage drop through my leads is causing more drain on the battery and the PSU to output less current that it should. Maybe time for some shorter and larger leads. I cleared the errors and the transport mode. Now I just need to go for a drive. |
05-30-2016, 11:42 AM | #65 |
Rep 3,945
@HDDMark , glad it worked out for you. I'll update the first post and make a mention to use latest Esys version. Which one were you using?
As for the PSU, I'll copy paste your comments in the other thread to continue the discussion |
05-30-2016, 12:51 PM | #66 |
21
Rep 59
Aboulfad,
I was on 3.26.XXX before. Evidently from PSdZdata 58.0 onward you need E-SYS 3.27.1. http://cartechnology.co.uk/printthread.php?tid=13675 |
