BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > Off-Topic Discussions Board > Some More Physics for you smart guys.
ARMA SPEED
      05-30-2007, 02:56 AM   #23
schneid4323
Drives: 335i, M6
Problem 1:
Ball A is dropped from the top of a building. One second later, ball B is dropped from the same building. Consider the balls while they are both in flight. You may ignore air resistance. Which statements are true about this situation?
True- Both are in free fall
True - As time progresses, the difference between their accelerations increases
False- As time progresses, the distance between them stays constant
False- As time progresses, the difference between their velocities decreases
True - Ball B will hit the ground after ball A
9.8= acceleration due to gravity if you constantly square that the difference in accellerations will increase the distance will change because they will never be at the same velocity/acceleration the velocity difference will increase because they are at a constant acceleration
Problem 2:
You bring a large cannon along with you on a voyage to a distant planet. You set the cannon on a high cliff and you fire a cannonball horizontally off the cliff into an ocean. The cannonball follows projectile motion until it splashes into the water. Which of the following factors will determine the time that the cannonball is in flight? You should ignore atmospheric ("air") resistance.
yes- height of cliff
Depeneds if the force is conatant probably no im guessing- mass of cannonball
yes- planet's acceleration due to gravity
yes- initial velocity of cannonball
no we are ignoring air risitance- radius of cannonball
Problem 3:
Three forces in the x-y plane act on a 4.50 kg mass: 15.10 N directed at 51o, 9.00 N directed at 142o, and 5.60 N directed at 219o. All angles are measured from the positive x-axis, with positive angles in the Counter-Clockwise direction. Calculate the magnitude of the acceleration.
I got the answer for this: 3.086 m/s^2
Draw the graph, connect the vector and it is your answer, the vector solution solution goes from head to head (Length of the resultant is your magnitude)
Calculate the direction of the resultant force using the same sign convention as above (in degrees).
But how do i do this?
Resolve the vector and that will give you the degree
BTW im a little inebreated but that is how you do it, it may not make any sense though
      05-30-2007, 02:57 AM   #24
ksfrogman
ksfrogman's Avatar
Drives: E90 330i 6MT
2006 330i  [0.00]
2006 330i  [0.00]
Y = (gt^2)/2 + (v)t + h
where g = gravity (i.e., -32 ft/sec or -9.8 m/sec)
v = initial velocity
h= initial height
t = time in seconds
Veloicity = 1st derivative of Y = gt + v
      05-30-2007, 03:02 AM   #25
schneid4323
Drives: 335i, M6
got the first 2. Still need number 3 and this:
A fire helicopter carries a 561 kg bucket of water at the end of a 24.9 m long cable. Flying back from a fire at a constant speed of 43.6 m/s, the cable makes an angle of 48.4° with respect to the vertical. Determine the force of air resistance on the bucket.
Vectors are your friends. change the weight and speed into force
and this:
A 2016-kg elevator moves with an upward acceleration of 1.86 m/s2. What is the tension in the cable that supports the elevator?
f= m x a equal but opposite force is tension dont forget to get the acceleration of gravity force either you need both
      05-30-2007, 08:31 AM   #26
Josh49
Drives: E90 325xi
You all set or need help still?
E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER.
      05-30-2007, 08:35 AM   #27
Josh49
Drives: E90 325xi
I think the key to you getting these problems right is to draw a Free Body Diagram for each of these, with every force and direction. It will really clear things up for you..
And also think about it in a real world sense to check your answers. The elevator for example. If you were holding an elevator by a string, you would need to hold the weight of the elevator to keep it static. Then to accelerate it upwards you would need to exert even more force. So you pulling upwards (or tension) should be the gravitational weight plus the force you are using to accelerate it.
FBD's FTW though. They really help you see the hole picture..
      05-30-2007, 01:14 PM   #28
SoYank
SoYank's Avatar
Drives: 2009 E90 335i MT
h= initial height
t = time in seconds
Calculus and alcohol don't mix. Never drink and derive.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7
European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor
Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269
      05-30-2007, 01:27 PM   #29
sixspeed
Z4M CSL
sixspeed's Avatar
31
Drives: Alpine White Z4M Coupe
My brain isn't up to digesting those questions - but seeing as this post was titled "some more physics..." I guess there's been some previous threads like these. Just wondered if this forum had "suffered" the plane/conveyor belt debate yet?
      05-30-2007, 01:43 PM   #30
Josh49
Drives: E90 325xi
It hasn't. Keep it that way..
      05-30-2007, 02:08 PM   #31
just4kickz
boku no namae ha...
Drives: 2006 BS 330i
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
2006 E90 330i  [0.00]
good one... haha depends tho... if its easy calculus i can still do it... if its hard... i just end up getting headaches from overthinking
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!"
      05-30-2007, 04:48 PM   #32
BMWPower06
A^M=G is nothing w/o the Power of ///M
BMWPower06's Avatar
Drives: ///M5 & ///M3
thanks guys, im done with that, ill likely have more questions tonite, seeing as i have more hw. I might end up IMing you smart guys
Anyways thanks for the help again
Indianapolis Red BMW ///M5
      05-30-2007, 04:53 PM   #33
Driv3r
Driv3r's Avatar
Drives: 2006 E46 M3 ZCP
2006 325i  [0.00]
Originally Posted by BMWPower06 View Post
Yea this is about the first week of level one college physics. I go to George Washington University in DC. Where are you going?
Not going anywhere yet..But thats a pretty tough school to get into...im sure its going to get MUCH MUCH harder...Good Luck with it..
2006 E46 M3 ZCP 6SPD-Interlagos Blue - 6SPD - SSK - AA Headers -AA Tune - Navigation w/ Splashscreen Mod - 3M Crystalline Series 60 - Carbon Splitters - Swissvax Treated - Bridgestone
2012 Yamaha FZ8 - Matte Black/Grey - Michelin Pilot Pure 2CT - Vortex Rear Sets - Yoshimura R-77D & Fender Delete - Spectro Race Oil - GP Reverse Shifting
      05-30-2007, 04:57 PM   #34
BMWPower06
BMWPower06's Avatar
actually the semester is almost half over, its summer semester. Then ive got Physics 2 for the second summer semester. Its called physics for non-physics majors so hopefully it wont get too much harder
