BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > No crank after TU HPFP install
Extreme Powerhouse
      04-07-2024, 11:37 PM   #1
Chris8575
Drives: 2018 740i
I purchased a Tu HPFP for my gen 1 B58 I installed it myself and once i went to start my car it wouldn’t Crank didn’t do anything, after a bit in trying to figure out the problem I went and put back the Stock HPFP and sadly enough It didn’t crank either what’s the issue that i’m running into ? someone please help thank you. Oh and i’m getting no fault codes only the “Drive train Malfunction” alert
      04-08-2024, 02:38 AM   #2
Shirazkhan
28
Drives: bmw
If theres a drive train fault,then there should be a dtc.What scanner are you using?Did u remove the positive/red cable by the jump point?near the strut bar?check if thats in.Check fuses as well.
      04-08-2024, 05:26 AM   #3
Chris8575
Drives: 2018 740i
it’s not and actually scanner I’m using, it’s the dongle of my boot mod 3 tune and it scans no fault codes, i’ll check fuses today but i if not i might just have it towed. Yes i completely disconnected the battery but didn’t help either.
