Cheap and easy 1b file from CIC
03-11-2016, 07:01 PM | #89 |
Rep 37
I have a somewhat complicated setup and trying to get this to work. I'm running a Macbook Pro with a Thunderbolt to Ethernet adapter. Then Ethernet to ODB port. I manually put the settings in the OP within my Macbook's network settings. Those settings automatically transfer to Windows XP (running within Parallels). I can get the login prompt when I type in the FTP address into a browser or FTP client, but the "root" login and the 2 password options do not work. Both give me an error that it's the incorrect password. Any clue what I can try? Thanks guys.
I also tried doing it directly within Safari in OSx with the same issue. Wouldn't accept the login/password. I have a 2011 E90 M3 LCI. UPDATE: I'm an idiot, I was only seeing 7 characters, and not the last ). Was able to pull the file. Last edited by lickwid; 03-12-2016 at 12:20 AM.. |
03-14-2016, 09:31 PM | #91 |
Rep 749
Drives: 335i xDrive
03-15-2016, 11:47 AM | #92 |
Rep 24
1B
03-19-2016, 08:22 PM | #93 |
Rep 2
1B file from CIC using E-Sys cable
Folks,
Could it be that password to root has been changed? I tried it on E-series today following this procedure. I connected E-Sys cable and assigned required IP address to my PC (169.254.199.98). I was able to ping the car and even connect to it via FTP (169.254.199.99) but the authentication didn't work. I tried root with those two passwords (cic0803 or Hm83stN), no luck |
03-20-2016, 02:06 PM | #95 |
Rep 2
03-22-2016, 10:39 AM | #96 |
Rep 37
I finally updated my CIC maps to Premium 2016-2. Took about an hour with 2 flash drives. Put 1 and 2 on first one, and 3 and 4 on second one. Worked like a charm.
If anyone in the Bay Area needs their maps updated, I have it on my Macbook that I can share. And I also have the E-Sys cable if you need to borrow. Just PM me. |
03-26-2016, 09:25 PM | #97 |
Rep 37
Thought I'd post my experience updating a 2010 E90 M3. I had a bitch of a time figuring it out, but in the end, we got it to work. The first method, I logged in using "root" and pw "cic0803", and it allowed me to download the "generalPersistencyData_DiagnosticSWTControlle r", but after generating the FSC code, it kept giving me the incorrect code error. After re-trying this method a few times, I tried the 3rd method and logged in anonymously instead. Pulled the "data03" file instead. Edited it in the same method as described to create the 1b file. Generated a different FSC code and this time it worked.
03-27-2016, 03:37 AM | #98 |
Rep 20
Drives: BMW 330d Xdrive 2010
Hi all,
Previously i got successfully 1b file from my CIC and i updated the nav to 2016-1. My question is: If i want to update to 2016-2, can i use the same 1b file or have i get again the 1b file from my CIC? |
03-27-2016, 07:00 PM | #99 | |
Rep 629
Can someone tell me where I can find the Fsc.exe?? thanks,
2009 335i E93 /// BSM /// Sport /// Premium /// /// 19" M pack 225 wheels /// M6 wheels winter set /// 35% Tint /// Gloss Black Grills /// PE Exhaust /// Lux H8 V3 /// Interior LEDs /// JB4-DCI /// Combox & CIC Retrofit /// M3 side skirts /// M3 front bumper ///
03-29-2016, 08:40 AM | #100 |
32
Rep 209
03-29-2016, 05:41 PM | #101 |
Rep 37
04-04-2016, 08:28 AM | #103 |
Rep 5,319
Worked perfectly! Thank you!
04-04-2016, 12:53 PM | #104 |
218
Rep 245
You only need to get the file once. If you follow the directions in this thread the car will simply accept all future updates without ever asking for new codes. If you follow other directions you will have to generate and enter a new code for each update, but this can be done with the original 1b file.
04-06-2016, 01:24 PM | #105 |
Rep 629
Thanks a lot! Much appreciated!!
04-12-2016, 01:35 PM | #107 |
Rep 9
hi everyone, just wanna thanks the author !!!
works like a charm. the car didn't ask for password so it was a faster process only issue, i use Macbook 64bit, and unable to install seven 32bit on it. till 2015 seven is no longer supported and everybody near me are running on 64bit i was looking for a generator 64 compatible and no success. the FSC.EXE won't start. so can i ask for some favor??? do you guess? if someone could help me with his 32bit platform it will be great fsc a.hex 0x28 0xFF > code.txt west europe version |
04-12-2016, 11:11 PM | #108 | |
Rep 37
04-13-2016, 01:58 AM | #109 |
Rep 9
much appreciate lickwid
I'll try as soon as possible Edit: lickwid you're my Savior greetings from Nīmes France Last edited by danaite; 04-13-2016 at 07:21 AM.. |
04-13-2016, 09:10 AM | #110 |
Rep 37
