How long have your secondary cats lasted w/ catless DP's
10-07-2015, 02:58 PM | #23 | |
Guest
Rep n/a
Drives:
I would imagine that OTS maps target richer values as opposed to custom, etc. Too many variables in this instance, but certainly an interesting observation, especially if both maps were custom in your case. |
10-07-2015, 04:16 PM | #24 | |
291
Rep 2,189
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
10-07-2015, 09:42 PM | #25 | |
Rep 1,903
Drives: e92 335i 6MT
Can you post some pics of the old cats? |
10-09-2015, 09:36 AM | #26 |
Rep 2,704
10-09-2015, 03:09 PM | #27 |
Rep 1,910
Earlier this week, i cut my stock secondary cats out and welded in some 100 cell high flow metallic cats from MBS. Didnt take any pics of the stock cats, but when held up to light, you could not really see through them. the 100 cells.....light passes right through lol. also, there is a lot more "backspool" noise as you let off the gas and the rpms are floating back down to idle after a rev. just cruising around, the car remains just as quiet as it did with the stock secondaries in there, and up top there is maybe a little bit more power. a lot less torque down low due to the freed up exhaust and less backpressure it seems. my car has 102k miles on it, fwiw.
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
10-10-2015, 11:00 PM | #28 |
Rep 1,903
10-10-2015, 11:08 PM | #29 | |
Rep 1,903
http://mandrelbendingsolutions.com/m...ace-converter/ Is there any smell after making the switch? |
10-11-2015, 02:10 AM | #30 | |
Rep 1,910
10-11-2015, 10:22 AM | #31 | |
Rep 2,704
$400 + tax Amazon has em for around $130 bucks each. Last edited by marcvtec; 10-24-2015 at 01:44 PM.. |
10-24-2015, 12:56 PM | #32 |
Rep 1,903
Stucks marcvtec
Any increase in exhaust smell from running the HFC's? |
10-24-2015, 01:41 PM | #33 | |
Rep 2,704
Exhaust note slightly louder, which I like and yes now the car does seem slightly quicker, mind u I am also pro tuning it at the same time, but maybe it needed a little break in period and adaption. Overall glad I did it for peace of mind. |
10-25-2015, 03:53 AM | #34 | |
Rep 1,693
10-26-2015, 07:51 AM | #36 | |
Rep 1,910
maybe its just the butt dyno, but it feels faster on the top end, and not so much down low. midrange feels faster as well.
02-21-2017, 04:24 PM | #38 | |
Rep 1,693
What makes you think they'd shit themselves? They have a less dense cell count than the primary cats so less likely to get clogged. Our engines have perfect closed-loop fuelling so they're always running sensible AFR as long as your tune isn't crap so no clogging from overly rich mixtures. They're a sufficient distance from the engine that they won't be damaged from heat. Do you have any evidence of the good gains and throttle response above 4000rpm from removing the secondary cats? |
Bimmer 808170.00 |
02-21-2017, 05:08 PM | #39 | |
Rep 2,825
http://www.e90post.com/forums/showthread.php?t=1029980 I got this link from the first page of this thread. Yes, I have evidence from deleting my own secondary cats... Maybe 4hp gain. more engine sound. better throttle response above 4000rpm and a noticeably stronger top end pull. |
02-21-2017, 05:30 PM | #40 |
Rep 1,693
Unless you have back-to-back dyno pulls, it's probably just placebo from the added sound.
02-21-2017, 05:33 PM | #41 |
Rep 2,825
you definitely feel a couple of HP in the high end, it pulls to redline more freely then before. the added sound and gains really isnt much to write home about, but the added performance is there (albeit fairly minor)
02-21-2017, 05:46 PM | #42 | |
185
Rep 202
02-22-2017, 08:48 AM | #43 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
Calling them theories is giving way too much credit. #alternativefacts
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
03-05-2020, 05:19 PM | #44 |
Rep 713
Thread revival for people running catless dp with OEM midcats.
I know that we are numerous still running OEM midcats with tune (MHD Stage 2/2+ or custom) for multiple years and many miles now. Any concern? (my concern is that it could be partially plugged, if it's totally plugged, i guess you can not reach boost target and it became obvious) I would like to check mine without disassembling/cutting them, i don't know what is the best way. I thought about the vacuum gauge test, but it's turbo, so it's probably better to disable turbo operation first by unplugging vacuum canister, so wastegates open, and measure vacuum at the intake manifold at idle and at 2500rpm steady for 30sec on warm engine. If anyone want to make the test with me, so we can compare our value it could be helpful. (even people fully catless, it could be a good way to see exhaust restriction difference between cat and no cat) Any better idea to check them is appreciated too. There is also probably some way to check them with reading logs, like AFRs ? but i am not expert with those values. |
