BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > one wheel sticks out more than the other
      09-12-2011, 06:46 PM   #1
tofu-
Drives: 335i Jet Black/Coral Red
rear driver's side sticks out more than the rear passenger side
what could be broken? car drives fine otherwise. noticed this after after coilover install and car was lowered
      09-12-2011, 07:02 PM   #2
Dr. G
Dr. G's Avatar
278
Drives: Black e92 335i
e92 BMW 335i  [8.84]
Did you do an alignment?
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
      09-12-2011, 07:11 PM   #3
tofu-
yup car was aligned after coilover install. -2.5 camber 0 toe in the rear
      09-12-2011, 07:13 PM   #4
TroyDeJ
Drives: around aimlessly
mine does the same thing, i cant figure it out
      09-12-2011, 07:19 PM   #5
tofu-
it was less noticeable before, but now that i put spacers on, one wheel is pretty much flush and the other looks slightly tucked in
      09-12-2011, 07:26 PM   #6
Tee212
Drives: yes
2010 335  [8.00]
pix or it happened but only you saw it
      09-12-2011, 07:30 PM   #7
tofu-
well, not as flush as yours, but..
      09-12-2011, 07:33 PM   #8
Tee212
Drives: yes
2010 335  [8.00]
no seriously? lol throw up some pix, something is not right.
      09-12-2011, 07:37 PM   #9
tofu-
will do tomorrow. too dark now. no garage
      09-13-2011, 11:44 AM   #10
tofu-
can't really tell from my photos, and the street is at an angle so one side is higher than the other due to the weight shifting
maybe i'll just leave it alone.
but, out of curiousity, in my last pic, is my toe angle correct? both tires clear fine (just fender liner rubbing), but it's like i have so much room under the top arch of the quarter panels, but none where the quarter panel meets the bumper.
      09-13-2011, 11:51 AM   #11
Tee212
Drives: yes
2010 335  [8.00]
hm ya its hard to tell but the gap from fender to tire seems about them same to me?
      09-13-2011, 11:56 AM   #12
tofu-
i talked to matt@cambertoe and he told me it may just be an uneven height issue..
hopefully i'm imagining things and the solution is that simple
      10-11-2011, 05:33 PM   #13
tofu-
so i'm revisiting this issue. put air in the tires today so i took more time to scrutinize.
the side that is supposed to be higher (driver side) actually has less room between the tire and fender. this leads me to believe it isn't just a height issue. if it was, i'd have more room between tire and fender than the sunken side.
ugh
      10-12-2011, 10:50 AM   #14
anerbe
Drives: Red E90M 6MT
Some potential causes:
1. Wrong tire/wheel combination. Probably not the case if you didn't get new tires installed, but it can happen where they mistakenly install the front wheel on the rear tire with a staggered setup.
2. Different heights/alignment between the rear axles. While the vehicle is on level ground:
Measure and compare the distance from the center of the hub and the top of the fender. If they are different, get them adjusted. Note that on my E46M, the left side was always a bit higher than my right when I got the heights adjusted to account for driver only weight. I don't know how the shop set up your coilover system.
General rule, if both sides are set at equal camber at equal heights, the side that lowers(loading on a turn or uneven road), the more negative camber.
      10-12-2011, 05:08 PM   #15
tofu-
found the problem
compare the position of the two bolts
      10-12-2011, 05:21 PM   #16
The HACK
Midlife Crises Racing Silent but Deadly Class
The HACK's Avatar
1821
Drives: 2006 MZ4C, 2021 Tesla Model 3
What about the position of the 2 bolts?
They're "eccentric" bolts, meaning the fat part of the washer will determine how much further OUT the top arm is pushed. Looks like the bolts are set at the same with the fat part of the washer sticking either straight up or down. It doesn't matter what the "position" of the bolt is at. It matters, what the offset portion of the washer on the bolt is pointed to.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
      10-12-2011, 05:24 PM   #17
tofu-
ugh.. my shop told me that's the reason, and that it's making my camber way off. they said the top bolt should be on the bottom on both sides
never an easy fix
      10-12-2011, 05:31 PM   #18
tofu-
this one
      10-13-2011, 07:29 AM   #19
anerbe
never an easy fix
so, the shop did not set up your camber right in the first place, or did it shift?
Either way, it should've been done right the first time.
      10-13-2011, 09:20 AM   #20
tofu-
Nah, was getting an oil change and asked them to check it out while it was on a lift. I had my suspension and alignment work done elsewhere.
the person who did my susp/alignment agrees with the above poster that the eccentric bolts really won't ever look similar.
Back to the drawing board.
      10-13-2011, 09:43 AM   #21
brokemywallet
Slaveaholic
Drives: 2006 330I
i'd say that the offset of the wheels are not similar for the rear....... Definitely a noticeable difference
      10-13-2011, 09:47 AM   #22
tofu-
they only come in one offset. The dtmrack diamond cut alufelgens don't come in m3 sizes.
