03-19-2022, 10:43 PM | #23 |
101
Rep 69
Aldor2788.00 B58 _gran_coupe_640.00 |
03-20-2022, 08:54 PM | #24 |
Rep 1,463
Thoughts on this? Another Dinan and MST type of intake? Lid can be installed or removed for personal preference.
https://x-ph.com/vr-performance-carb...-vr-m340i-110/ |
03-24-2022, 08:23 PM | #25 | |
F36 440i Gran coupe
21
Rep 81
How is your experience with the intake so far & anything to know while installing it since I saw you have it on a 440i gran coupe as well.. thanks my man |
03-26-2022, 12:06 PM | #26 | |
101
Rep 69
1. The clamp holding the intake tube to the turbo inlet can be a pain in the arse to get to. Have a small (very small) flat head handy because working space is minimal. 2. Definitely cover your turbo inlet while working. My 10mm ratchet adapter disconnected from the head and slid down the turbo inlet. I let out the biggest "FU*K!!" the neighborhood ever heard but thank God theres a little lip that stopped it from rolling in all the way and I was able to get it out. Other than that it's super easy. With the right tools you should be able to do it in 40mins. Good luck and enjoy your new sounds! |
03-26-2022, 12:19 PM | #27 | |
Novice
315
Rep 697
03-26-2022, 06:06 PM | #28 |
101
Rep 69
Did some heat wrapping today.
03-26-2022, 09:57 PM | #30 |
F36 440i Gran coupe
21
Rep 81
03-26-2022, 11:00 PM | #31 |
Rep 1,463
You guys can always run this heat shield. I have one. I'm sure it helps a bit!
https://www.rossrperformance.com/pro...ld-heat-shield |
03-27-2022, 03:44 AM | #32 | |
F36 440i Gran coupe
21
Rep 81
03-27-2022, 06:51 AM | #33 |
Rep 452
Just like the MST intake, I'd be concerned with the pipe diameter increase where the MAF sensor is. See here:
https://f30.bimmerpost.com/forums/sh...54&postcount=9 |
03-27-2022, 07:56 AM | #34 | ||
Rep 1,463
03-28-2022, 01:24 AM | #35 | |
F36 440i Gran coupe
21
Rep 81
03-28-2022, 09:16 AM | #36 | |
70
Rep 79
That said, I have no idea what the ID of the tube here is. Someone could measure it. I posted the ID of the stock tube in that quote above. |
Th3Walrus349.50 |
03-28-2022, 11:15 AM | #37 |
F36 440i Gran coupe
21
Rep 81
Thanks for the response ! If I installed it and the MAF sensor wasn’t functioning with the same flow as you state it should, would it throw a code saying it isn’t functioning good or let me know it’s running lean ? & sorry for the noob questions, but would it damage anything or just run lean/waste more gas?
03-29-2022, 03:59 AM | #38 | |
Rep 565
I think if anyone ran a before and after data log then they could easily establish if this mod causes bad readings or not but it's not something I've ever read about or experienced (that I'm aware of!) In nearly 25 years of messing with cars. That said, I can see the principle being true. Also, as someone previously stated, our cars will have the safety features built in and should throttle back to protect things unlike older and less sophisticated systems. Last edited by B58 _gran_coupe_; 03-29-2022 at 04:05 AM.. |
03-29-2022, 05:47 AM | #39 |
Rep 452
Since I brought it up, I did a search and the developer of JB4 said the MAF on BMWs is only used during open loop startup for cold idle, until the O2 sensors reach temperature. The MAF is used upon startup and low load, and shouldn't cause issues under load/boost/WOT.
That said, can one of you who purchased this recently measure the ID of the stock housing near the MAF, and the ID for this one? |
Iflaw016.00 |
05-11-2022, 06:07 AM | #40 |
Rep 452
SRB440IGC Still happy with this intake?
Also do you have a link where you bought it? All the ones I find on ebay ship from China and are going to take 4-6 weeks. edit: found this one, but doesn't ship to Canada. https://www.ebay.com/itm/185182237380 Last edited by Th3Walrus; 05-11-2022 at 06:34 AM.. |
SRB440IGC100.50 |
05-11-2022, 02:15 PM | #41 |
101
Rep 69
No issues, no CELs. Car runs strong and sounds great. I noticed every once in a while the US sellers will run out of inventory and you'll need to wait for them to "restock". I'm not sure how often they do this. I heard they also sell on AliExpress but I'm not too familiar with their sellers.
06-03-2022, 05:54 AM | #42 |
Rep 452
SRB440IGC I contacted that seller that ships from Houston, they are in China and won't ship from Houston to Canada. They sent me a link for one shipping from China for $233, but I found another seller with it for $200. Received from China in 4 days.
From your initial pic, it looks like you put the smaller edge trim on the hole for the inlet? The larger trim with the balloon edge should go there to seal the hole. The smaller trim should go on the arc of the wheel well to prevent rubbing, but I found it didn't touch, so I actually put it on the 90 lip that rests on the body, the lip with the hole that gets attached by the airbox ball. I found that lip was rubbing and squeaking. Question.. does your filter slightly touch the wheel well? I couldn't get the intake pipe positioned in any way where it wasn't touching. |
06-04-2022, 03:11 PM | #44 | |
36
Rep 15
Tried for a good hour playing around with the piping but couldn't figure it out. |
