      02-09-2023, 07:25 PM   #1
heywatchit
Drives: 2013 X1, 2015 328d, 2009 328i
2013 BMW X1 S drive  [0.00]
2015 BMW 328d  [0.00]
2011 BMW  [0.00]
128i What to repair first?
2011 128i
88k miles
Just had front brakes replaced. Tech said the following needed:
Oil filter housing gasket
Oil pan gasket
Main belt worn
What is the order of priority? Thanks.
Scott
      02-09-2023, 08:16 PM   #2
BMWCCA1
BMW Owner Since 1971
2258
Drives: 1964 700 Sport Cabriolet
2013 BMW 128i  [10.00]
Pretty easy to do the OFHG at the same time as belt replacement. Lots of duplication of work.
They all leak. Big leaks can hurt the belt. Minor leaks can go forever with the residual benefit of preventing rust!
      02-09-2023, 09:24 PM   #3
ResinThirteen
ResinThirteen's Avatar
191
Drives: 09 135i
2009 BMW 135i  [0.00]
Agreed. Belt and oil filter housing gasket are priority.
Later on, you can tackle the oil pan gasket and plan for other things while you’re there if needed, like engine mounts, etc.
      02-10-2023, 12:57 AM   #4
Almuliman
Drives: 2013 LMB 6MT 128i
Mickey Mouse flange (preventative, not a repair as such – when it becomes a repair, it'll strand you on the side of the road first). When were the plugs last replaced?
But yes, definitely OFHG, belt, and pulleys. N52s (and 51s) eat belts if they break.
