Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Journal: N54 Total Engine Rebuild & Upgraded Internals
      12-29-2010, 11:55 PM   #155
m6pwr
m6pwr's Avatar
38
Drives: '14 335i M sport
Originally Posted by JB135MDCT View Post
Question is will this one clean as well as the Shell oil you are using: http://oilstore.stores.yahoo.net/peuleu5wfusy.html
Well look at how clean it got my dog. Its the latest and greatest from Shell. Shell says so.
'14 328d, '13 M3 ZCP, '12 535i, '11 335d, '09 Z4 DINAN Stage II, '05 330i ZHP, '05 M3 ZCP, '02 M3, '91 328i, '90 535i, '88 528e, '88 M5, '87 M6, '95 Z3, 95 M3, '93 M5, '87 325e, '89 535i, '86 635i, '73 Bavaria.
      12-30-2010, 12:33 AM   #156
JB135MDCT
I'm just a cook
JB135MDCT's Avatar
Drives: 2011 135i DCT
I see 3 black spots. ... I was wondering if the ferrari penzoil will clean as well as the shell. Shell is not available in MD.
      12-30-2010, 09:40 AM   #157
m6pwr
m6pwr's Avatar
38
Shell/Penzoil, Pennzoil/Shell, its all the same company, same family. I think Shell elected to market the new oil in the U.S. under the Pennzoil brand because it has greater name recognition here. As far as I know the Ultra is Shell's latest, newest formulation, with the best deposit control - - that's the hype. The same identical oil is sold as Shell Helix Ultra 5w40 in Europe. That's the Ferrari factory fill/service fill in Europe.
      12-30-2010, 11:13 AM   #158
Brandon26pdx
Drives: 2011 135i
I may give this a try. I've got a 1200 mile oil service needing done in the next 600 miles or so. (Was planning to use German Castrol.)
      12-30-2010, 11:13 AM   #159
Turkeybaster115
Drives: 335I
What do you guys think about using motor flushes in N54 powered vehicles, at least every other oil change. They are pretty heavily kerosine based, and do a good job from my esperience. I've used them in my 335I, and Audi A6 3.2. I would think if the op used them in his vehicle, the sludge build up might have been a lot less. This approach might even be better, than using an oil catch can.
      12-30-2010, 11:14 AM   #160
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
the more i think about this and by looking at your engine i am convinced that the status of your pistons and block are definitely a result of heavy tracking at the ring . As you mentioned you probably hit some bends that made the oil pick up stop and together with high temp the motor suffered.
with 5000 miles less than you my engine was in pristine conditions (minus the piston number 2 grenated) . I tracked very very little but drive quite hard. I will try to take some pictures of my other 5 pistons and post them here for comparison. i also had very very little carbon build up and i wonder if meth is really what made the difference here.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      12-30-2010, 11:31 AM   #161
Penn999
Penn999's Avatar
49
Drives: 335i coupe
Im interested to see your pics, also the theory about the meth...do you think that has helped keep your engine cleaner(better burn)?
07' MT, Quaife LSD, BMW Performance LED Steering Wheel, HPF FMIC, AA BOV, HPF Exhaust, DCI, Procede V5, AR Stage 1 oil cooler, AR OCC, AR CL DP's, Vishnu Meth Kit, UUC SSK+DSSR, UUC Shift knob, (19 inch)VMR V715's/Yokohama Advan AD08's, Hartge Pedals and Floor Mats. Awaiting Install: M3 Rear Subframe Bushings, Full M3 suspension bits, AST 4100's, DSS axles. Future plans: Vishnu Single turbo kit
      12-30-2010, 01:29 PM   #162
onefastman
Drives: 2009 135i 2011 e92m dct
It helps clean the valves.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
      12-30-2010, 03:50 PM   #163
Penn999
Penn999's Avatar
49
Drives: 335i coupe
Thanks, I have yet to go down that path. I am just worried about the daily maintenence, how often are checks warranted?
      12-30-2010, 06:41 PM   #164
m6pwr
m6pwr's Avatar
38
Remember that anything you put in the gas in a di engine winds up in the oil, too. I guess that's how meth injection will help clean the intake valves in a N54. I have to admit I know practically nothing about meth injection. But from what I've read, it was never intended as a valve cleaner or deposit cleaner in an engine. It can be be a pretty strong solvent. Having said that, here is a link to an N54 run on some kind of meth injection. I would be very, very happy if my N54 valves look this (right side of intake port) after 12k miles of hard running -
http://www.n54tech.com/forums/showth...ntake+deposits
Also here's a link to a fuel additive designed to prevent and clean up intake deposits. Note that it was tested in a twin turbo di engine. I'm not saying this stuff works. Frankly, I'm skeptical -
http://www.bgfueltest.com/
      12-31-2010, 06:04 AM   #165
vladberca
vladberca's Avatar
Romania
763
Drives: '18 octavia 2.0 tdi dsg
      12-31-2010, 08:39 AM   #166
bavarian19
General
bavarian19's Avatar
Drives: Car
      12-31-2010, 11:09 AM   #167
JB135MDCT
I'm just a cook
JB135MDCT's Avatar
I too, but 5w30 LLO1 for the winter and 5w40 in the hot. Have been using BMW oil in all my toys for the last 10 years.
      12-31-2010, 11:23 AM   #168
Alpina_B3_Lux
Alpina_B3_Lux's Avatar
263
Drives: Audi R8 LMX, BMW M550i xDrive
2009 335i  [8.90]
Originally Posted by E92Fan View Post
Honestly, I wouldn't order a 335i for use on the 'Ring if you are a dedicated 'Ringer and know how to drive properly there. It depends how many laps you will be doing, and how fast you'll be driving. The N54 engine needs so much modification to make it reliable and suitable for the track. You're better off springing the extra 10k for an M3 if 'Ringing is your main aim for the car.
Having said that, Marcel (Alpina_B3_Lux) has a fully modified 335i (everything except engine internals) with an all-aluminium radiator as well and he does maybe 50 laps of the 'Ring a year and his car seems fine so far.
Yes, I've done around 90-100 laps with my car so far (since 2009) in a number of different configurations, and it's running very well (except for a new HPFP at the beginning of this year, but this should be unrelated). I haven't noticed any problems with the engine so far.
However, I don't drive it as hard as Tony does, so it's probably under less stress than his - and it's some years newer, too. Mine isn't intended to be a track tool either (as it is and will be my daily driver), but with the current power level and suspension set-up I can have loads of fun - and the torque is great for daily driving too.
Considering that I'll keep my car for a rather long time, I will probably also go down the road of modified internals in the medium term, but right now I'm more of a mind to learn to properly use the immense power the car puts out right now (GIAC stage 2 race with meth).
It's very interesting to see and read all this, of course. And I'm looking forward to see the car in person early next year!
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
      12-31-2010, 11:43 AM   #169
m6pwr
m6pwr's Avatar
38
If you're talking about using the Ultra 5w30, DO NOT use it in your BMW. Neither of the Ultra 5w30 oils (there are two versions) meet BMW LL-01 and both are the low SAPS (low phosphorous, fuel economy) oils. The Ultra 5w30 Euro does meet BMW LL-04 specs which is ok if you have a diesel but that is no good for a gas BMW in North America. However, they would work quite well in your Chevy Tahoe.
If you're going to use Ultra, stick with the 5w40 year 'round. It flows just as easily when cold as the 5w30 and when your oil temp gets up to operating temp, it is a tad thicker which is good in the N54.
      12-31-2010, 12:13 PM   #170
JB135MDCT
I'm just a cook
JB135MDCT's Avatar
I have N55 and thanks for doing my homework. Euro L is LLO4.
      12-31-2010, 01:20 PM   #171
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
Update pictures
Block all bored and honed beautifully - vertical score marks all gone and the bores are totally true. Just waiting for the big end bearing shells to arrive, then the block can go back together. Should have the cylinder head back in a few days.
The crank has been cleaned up and blueprinted.
Name:  _D3X4471 Small.jpg
Name:  _D3X4476 Small.jpg
Name:  _D3X4468 Small Over.jpg
Name:  _D3X4468 Small.jpg
Name:  _D3X4479 Small.jpg
Name:  _D3X4477 Small.jpg
Name:  _D3X4478 Small.jpg
Name:  _D3X4481 Small.jpg
Name:  _D3X4483 Small.jpg
Name:  _D3X4484 Small.jpg
Name:  _D3X4485 Small.jpg
Name:  _D3X4472 Small.jpg
Name:  _D3X4475 Small.jpg
Name:  _D3X4487 Small.jpg
      12-31-2010, 02:09 PM   #172
Penn999
Penn999's Avatar
49
Drives: 335i coupe
Gorgeous, I will do this as soon as she starts running bad, I plan on keeping the car for a looong time.
      12-31-2010, 02:34 PM   #173
dzenno
273
Drives:
OMG awesome!
      12-31-2010, 04:16 PM   #174
BrianMN
Drives: 4 Door Family Sedan
How much material did you have to take off the crank to get it perfect?
So you did zero boring? The reason I ask is because honing doesn't usually get you to a perfectly round cylinder, rather it just fine cleans and finishes the walls. This is assuming they just used 300 -> 500 grit stone to get a 35 RA (roughness average) or RK. So it's hard to say you got a perfectly round cylinder with just honing.
Would CP think about making a .10 or .20 over piston? I would think many of us rebuilding would like to bore at least 10 over to ensure perfect roundness and clean walls.
I'm really excited for you to get this back together, and curious to see how the brand new engine feels and runs compared to how it was before. Thanks for the updates.
EDIT: Just saw in the first post you had this bored and putting in a one-oversized piston in....do you know exactly how much larger it is?
      12-31-2010, 04:19 PM   #175
BrianMN
And that last picture with the car on the lift with parts underneath is awesome. Looks like a nice place to do all this.
      12-31-2010, 04:36 PM   #176
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
Absolutely minimal. More finishing of the surface than anything.
The oversize is 0.5mm. And yes, it's bored using Serdi equipment.
carbon, cylinder head, engine, intake, n54, n54 engine, piston, rebuild, valve
