09-30-2021, 08:55 AM | #375 |
Rep 4,180
deansbimmer i just installed the undertray. For the life of me I could not push the PS hard pipe high enough to clear the tray. I used as much strength as I dared and it would not bend.
In the end I unscrewed the bracket holding the pipe so that the pipe is not fixed and can move upwards. Then I wrapped it with some foam and now it's resting on the undertray. Is it safe to use in this manner? |
09-30-2021, 04:41 PM | #376 | |
3771
Rep 2,912
Drives: 2011 E93 M3
It appears as if you're also missing the oil cooler duct, part number 51718040950. I'd get that installed as that makes a huge difference in how the oil is cooled. |
09-30-2021, 06:33 PM | #377 |
Rep 4,180
Thanks for the heads up on the missing duct. I was wondering why the tray rubber seal didn't mate up to the oil cooler.
On bending the PS pipe, I tried to bend it by hand using as much force as I dared. I think the pipe is stainless cos it is really hard, and I'm not sure if it's stock or not. Is it safe to use a bar for leverage to bend a stainless pipe? |
10-28-2021, 11:08 PM | #379 | |
Rep 4,180
I'm getting custom hoses done up to clear the tray. |
10-29-2021, 10:31 PM | #380 |
Rep 46
Hi deansbimmer - Just picked up a E93 today and the undertray is hanging on by a thread (or two LOL). Wanted to place an order but looks like this is on back-order? Any estimate on when more will be available?
10-30-2021, 08:18 AM | #381 | |||
3771
Rep 2,912
Drives: 2011 E93 M3
11-06-2021, 10:27 PM | #383 |
49
Rep 117
Finally installed my shield today & i love it. Quality piece with great instruction all the hardware you’ll need & zero issues on the install. Word is it pairs well with the HARROP which is coming soon! Thanks again Dean.
deansbimmer3770.50 |
12-02-2021, 06:41 PM | #384 |
Rep 1,070
Just installed mine today. I too had to bend the power steering pipe. Couldn't get it to move by hand. Had to use a pry bar.
Was kind of surprised how much pressure is put on the bottom of the oil cooler and duct, but i suppose that is necessary to get a good seal. |
12-02-2021, 07:39 PM | #385 | |
Rep 1,134
Drives: 2009 E92 M3 Dakar Yellow II
12-02-2021, 08:26 PM | #386 | |
Rep 1,070
I'm also slightly confused if the seals on the undertray are supposed to make contact on the bottom of the oil cooler and duct, or on the back of it. I suspect its the bottom where contact is supposed to be made, but other pictures have me doubting it. |
12-03-2021, 12:25 PM | #387 |
Rep 1,070
Just called mporium and confirmed the seals are supposed to make contact on the bottom- so looks like its all good.
Awfully confused why nearly every picture here is seemingly not doing that. |
12-07-2021, 12:14 PM | #388 |
Rep 1,070
Does anybody else have issues with the wheel wells not flush in the bottom corner due to it having nothing to bolt to?
What did you do to solve it? |
12-07-2021, 01:45 PM | #389 |
3771
Rep 2,912
Drives: 2011 E93 M3
If you're referring to the fender liner, there are locations for securing, there should be no gap when installed correctly. The beauty of the design allows the installer to add as many screw locations as needed. The installer will have ultimate say over the quality of fitment. Differences and variations from car to car will also determine how much the installer will have to work to get all areas to line up well. Cars that have had no undertray for some time and have settled may even need the bumper removed and repositioned. The tray must be slid up into the bumper sufficiently, and the bumper corners pulled up flush against the edge of the undertray corner. The undertray shouldn't extend back past the bumper cover edge. See below of how the fender liner should fit at the corner.
bhowelett125.00 |
12-07-2021, 01:45 PM | #390 | |
125
Rep 126
Drives: '08 MR E93 M3 DCT
I'm at work right now but can send pictures this evening when I'm home if you want them. |
12-07-2021, 03:37 PM | #391 |
Rep 1,070
Yes, the finder liner is what I am referring to.
In the stock setup, the bit circled in red connects to the undertray which keeps the fender liner flush. Without this attachment point, it wants to bow out a little bit. The aluminum L piece that the fender liner bolts to, does not extend out this far, so there's no provision to attach this bottom corner to anything, hence the bowing. The instructions say that this attachment point is unused. I am missing the plugs there, so I need to go fix that real quick, but getting that bit to actually attach to something would make it sit flush. |
12-07-2021, 03:46 PM | #392 |
Rep 1,070
Actually, looking at it again- You've got 3 bolts on the L bracket, and if I had a 3rd one where you've added yours, it will allow it to sit flush, so that is probably the answer here.
12-07-2021, 04:03 PM | #393 |
3771
Rep 2,912
Drives: 2011 E93 M3
In my photo above, there is no screw that far outboard in the fender liner, and its sitting flush. Utilize the vertical lip of the bumper cover. When you adjust everything to keep the fender liner forward of that lip, the fender liner is retained with no screws necessary. This is how we install them here in our shop.
The L bracket may be notched in the undertray if you need it to move forward more so that the fender liner is retained forward of the edge of the bumper cover. Add as many screws as you like. The deteriorated condition of some aging fender liners may require more work. |
bhowelett125.00 |
12-12-2021, 11:36 PM | #394 |
Rep 1,134
Mine went on without much drama when I bent the PS lines up a little. I had the same concerns as drwankel but the fit improved enough when I pushed the L brackets as far inward as the slots allowed and tightened everything down. I'm not too worried about not having that corner fully secured anymore.
12-13-2021, 01:52 AM | #395 | |
Rep 4,180
12-21-2021, 08:40 AM | #396 |
Rep 642
Any updates on shipping/stock? I ordered it last week hoping to get it by xmas and the shipping info was updated and was set to be delivered yesterday, but I checked again today and it's just pending and haven't shipped yet?
