Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > N52 engine build :)
      01-09-2016, 11:58 PM   #1
hassmaschine
Drives: "NBO" 330i
N52 engine build :)
Been looking forward to this for a long time! Finally picked up an N52 to build. This is going into an E30, not an E90, but you guys might appreciate it.
for $800 I got basically a running core motor. it's actually pretty clean inside - I was expecting the worst, it has 258,000 miles, but things like the intake ports are flawless, and even inside the head only has minor carbon buildup.
It definitely has a valve cover leak, OFHG leak, and oil pan leak. The engine is really clean on the passenger side, but the front and drivers side are covered in oil, likely from the OFHG.
I think the rear main seal is still good, it's just the oil pan leak that's been spread around everywhere!
sitting on a HF dolly.. E30 in the background. First job was to get it onto a stand, which was tough - I have access to an engine hoist, but at this point I don't want it taking up space in my garage, so I made it work with pulleys and a couple friends.
On the stand.. and that's about it for now. I have to leave on a work trip all week next week so I can't really tear into it. But I have plans, and a parts list.
There's actually some more parts I got that aren't pictured, including the engine harness. I'm not using any of the stock N52 intake so I didn't care about that, and of course I'm not using stock N52 exhaust manifolds.
Appreciate 12
      01-10-2016, 12:04 AM   #2
SDemetris
FSAE Dude
Drives: E90 328xi
omgomg you're doing it... this is exactly what i want in my e30 except i would probably prefer an n53 since it will probably be easier to tune without valvetronic. what ecu you plan on using?.. good luck man!
2007 TiAg 328xi: AA Tune, AFE intake, Full exhaust, 335xi Brakes, H&R RSB, UUC FSB, H&R Sports, Billy Sports...BBS SR 17x8
1985 Gazelle Beige 325e: Poly everything, e24 3.25 LSD, 225 lb weight reduction, Corbeau FX1, Shifter machined by me, roll bar, harness, all the other goodies. My "Racecar"...15x7 BBS RA
      01-10-2016, 12:11 AM   #3
SDemetris
FSAE Dude
Drives: E90 328xi
looks like the oil pan might not fit with the subframe after my quick research. E30 M20 pan has the pump and lower section in the front but yours is towards the rear.. I thought i read someone needed a E60 530xi oil pan.... hopefully whatever you choose isnt too low
      01-10-2016, 12:43 AM   #4
hassmaschine
Drives: "NBO" 330i
why would it be easier to tune? valvetronic is only like 2 tables. it's just lift.. that's it.
it's not a RWD E30 so the oil pan will be way different anyway. I'd look into modifying the subframe and oil pan - Arcasylum does some really nice stuff for E30 S54 swaps that I think could be applied to the N52. The oil pan design of the RWD E30 sucks ass anyway - it hangs too low and gets broken all the time, and seems more prone to starvation.
      01-10-2016, 08:06 AM   #5
Dan Bilzerian
Dan Bilzerian's Avatar
355
Drives: E90 325i 6MT
How much is the E30 going to weigh roughly you think?
      01-10-2016, 08:35 AM   #6
Mike.
Mike: Everyone's Pal
Mike.'s Avatar
2044
Drives: F80 M3
2013 BMW 335xi  [10.00]
Subscribed!
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix
      01-10-2016, 09:28 AM   #7
hassmaschine
Drives: "NBO" 330i
2750lbs. I weighed my 330i the other day, it was 3400lbs, and thats one of the lighter E90s - the wagon is 3700lbs lol.
      01-10-2016, 09:33 AM   #8
Dan Bilzerian
355
Damn, that's going to fly!
      01-10-2016, 09:46 AM   #9
E90joee
Drives: 2011 335i xdrive
I was thinking about doing this next summer..will buy an e30 in a couple months and start gathering parts by next summer..cant wait to see the out come! Are you going to do 3IM and AA headers or SC?
      01-10-2016, 10:41 AM   #10
Tom Droze
Drives: 2012 BMW 328i (e92)
You should have bought a N54 motor!
Okay, okay, someone was bound to say it sooner or later, now that it is out of the way. . . I am officially subscribed.
2012 Jet Black 328i Coupe / ESS Tuning Gen. 2 Supercharger / Evolution Racewerks Oil Cooler / BMS Oil Catch Can / BMW Performance Exhaust with Dinan Y Pipe / Eibach Pro Kit Springs / Koni FSD Shocks / MFactory LSD & Differential Bushings / Performance Rear Trailing Arms / BMW Performance Strut Brace / Stop Tech Slotted Rotors / Hawk HPS 5.0 / SS Brake Lines / Brass Guide Pins / M3 Front Control Arms, 28 MM FSB, Engine Cowl, and DCT Paddle Shifters / Michelin PSS / APEX ARC-8
      01-10-2016, 11:18 AM   #11
Love The Drive
Love The Drive's Avatar
Drives: E90 MT N51
Pictures of the E30 please! Subd
2011 E90 328i | CDV Delete | BMW PE | Bilstein B12 Pro-Kit | 17x9 ET30 APEX ARC-8's | 255/40
      01-10-2016, 11:48 AM   #12
Eagle1oh7
Eagle1oh7's Avatar
Drives: '11 328i Sedan
Nice! SC too?
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod
      01-10-2016, 11:50 AM   #13
codinge90
Drives: e92 M3
Subd
      01-10-2016, 12:07 PM   #14
E90joee
If you have instagram i can show you the page of someone who has a n54 in a e30 painted santorini blue
      01-10-2016, 12:54 PM   #15
hassmaschine
Drives: "NBO" 330i
lol. you won't be the last, I'm sure - but to be honest, if I wanted a motor that was as heavy as an N54, I would just go with my original S54 plan. If I wanted a turbo, it would be far easier and cheaper to turbo the M20 that's in it.. and it's lighter, too!
Anyway, no plans on a SC, I'm on the fence whether that is really a good idea long term or not. The pistons are certainly not made for boost. Everyone always talks about the block, but the block isn't the issue in my mind. the rods are significantly lighter than N54 rods too - even the bolts are smaller!
No 3 stage IM either - I'm going to 3D print a flange and use open trumpets. A 3 stage would be nice for smooth driving, but it won't support the power I want. This car has short gearing (4.10s and no overdrive), so I need something that will rev. also, the 3 stage will almost certainly not clear the brake booster, but the trumpets should. That actually saves me some money on an expensive manual pedal/MC setup. Eventually I want to vacuum form a plenum so I can run a panel filter. Or if I win the lottery, adapt a CSL airbox..
The goal is 8,000rpm and around 300bhp, with an engine that is lighter than the M20 it's replacing. I haven't even torn down the engine yet, the condition of the bores will sort of determine how far I take it. Original plan was to use stock pistons and rods, now I'm not too sure.
Talking to a buddy of mine in Florida who has a flowbench to see if he can test the N52 head and see what improvements can be made. The ports are CNC'd but they look to me like a little cleanup would go a long way.
First thing I want to do is run a compression test, the second thing is to see how much piston/valve clearance there is at TDC - to see if retarding the stock intake cam 5-10 degrees is a valid idea.
      01-10-2016, 12:55 PM   #16
hassmaschine
Drives: "NBO" 330i
the imitator is doing it into a 323i. I don't know if it's the same car or not. He's basically transferring all the wiring & modules over, even swapping in the gas tank. It should run like a stock car when he's done. I'm only going to be running the DME, EKP, fan controller, and battery sensor.
      01-10-2016, 01:28 PM   #17
SDemetris
FSAE Dude
Drives: E90 328xi
This should make for nice weight reduction. Put this engine in to loose some pounds then take the trunk tar out to balance it out
      01-10-2016, 01:40 PM   #18
hassmaschine
Drives: "NBO" 330i
My e30 never had trunk tar - later production models came without it.
      01-10-2016, 02:00 PM   #19
E90joee
This is the one i was talking about not to sure if its the same one
Dan@BPC40.00
      01-10-2016, 04:16 PM   #20
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Drives: 06 SGM E90, 15 BSM E84
This should be very interesting! Sub'd
| 3-IM | AA Headers | Eurocharged Stage-3 | BMW PI |
      01-10-2016, 08:43 PM   #21
justpete
Drives: '11 328i '19 M6
2019 BMW M6  [10.00]
2011 BMW 328i  [9.00]
sub'd
Hoping to do exactly the same thing to an N52 with somewhat lower miles...
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
      01-10-2016, 08:56 PM   #22
808AWD325xi
Ballin' out of control.
808AWD325xi's Avatar
520
Drives: 2009 335i
Sweet...congrats !! Is the E30 build thread on R3V?
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
