BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Need some help for understanding the warranty on struts.
Studio RSR
      05-02-2019, 03:36 PM   #1
KG_F30
Drives: BMW 340i F-30 M-Sprt AlpWhite
Question Need some help for understanding the warranty on struts.
So I have a 2018 340 x drive, had Dinan lowering springs installed. The car has close to 20, 000 miles. I was getting some rattling noise, gave the car for regular service and wanted to get it checked, the service guy at the BMW service center called me and said the struts need to be changed as they are the ones making the noise and they are not covered under the warranty because of the lowering springs.
So wanted to ask if anyone else had a similar issue, and should it be covered under the warranty or not?
I thought Dinan was an approved manufacturer and the warranty doesn't get voided with their parts.
Please let me know your thoughts.
Thank You!
      05-02-2019, 04:49 PM   #2
torkles
Drives: 2013 335i MSport 6mt
if bmw would have covered the struts as part of its new car warranty (not sure on that point), they definitely won't cover them now because the lowering springs can be blamed for blowing your stock shocks.
as far as warranties go, it's not the bmw warranty that covers things if a dinan part causes an issue, it's the dinan warranty. it might be worth calling dinan to figure out if dinan will cover new struts, but i wouldn't hold my breath.
2013 335i M-Sport 6MT, MPE, VRSF CP and IC, BM3 Stage 1
2006 330i 6MT, Sport Package - sold
KG_F307.00
      05-02-2019, 04:50 PM   #3
anotheran
Sedan Driver
389
Drives: A nice car
Contact Dinan as Dinan matches BMW new car warranty for any BMW parts it may affect
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK
BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug
KG_F307.00
      05-02-2019, 06:33 PM   #4
KG_F30
Thanks a lot, did contact the dinan dealer I got the springs from, will have him check and work with Dinan to see if the can do something about it.
      05-02-2019, 06:34 PM   #5
KG_F30
Sounds good, will contact Dinan. Thanks a lot
      05-05-2019, 01:36 PM   #6
EggoEspada
Drives: BMW 340i '18
Is the strut covered under the warranty in the first place? I have a similar issue with no aftermarket parts. But the exact issue is it’s purportedly bent, so it may be different from your situation. 🤷🏽*♂️
      05-05-2019, 04:37 PM   #7
exE36M3
BMW CCA Member
exE36M3's Avatar
490
Drives: 2015 435i M Sport
OK silly idea BUT... assuming you ONLY had 20k miles on your stock struts/shocks when you had them installed... AND you put maybe 20k miles on the car... that STILL isn't enough miles to blow out a stock shock normally.
If you heard a rattling noise within the first few thousand miles... I suggest checking the installation job.
Why? I had Hotchkis springs on my BRZ by a reputable BMW shop and they discover that one of the stock struts was blown. The shop that did the spring install (ASE certified shop) documented it. I had Subaru replace the strut under warranty. BUT as I was driving away from the dealership, the car was rattling - BAD.
The Subaru tech claimed it was because of the springs.
I got home, took a half day off work and checked ALL the bolts and nuts. And guess what. The top strut nut was NOT torqued down. It was loose. I got out my torque wrench and put it to the 14.5lb spec. And... no more rattle. (And a *nice* email to Subaru was sent.)
Before you go down the hellhole that is warranty service... bring the car back to the installer. Rattles are usually pretty easy fixes.
BTW A blown front strut/shock is pretty obvious, the car will corner like crap on the offending side.
dinan, lowering springs f30, suspension, warranty
